Poly 318 Timing Chain - How Slack is Too Slack?
Rob
Posted 2020-09-21 6:14 PM (#603431)
Subject: Poly 318 Timing Chain - How Slack is Too Slack?
500100100100100252525
I had to replace the fuel pump on my '58 Plymouth poly 318.
While the pump is out, I stuck a finger into the fuel pump hole, I can really move that timing chain. At what point should I be concerned about the chain being too loose?
Posted 2020-09-21 10:48 PM (#603441 - in reply to #603431)
Subject: Re: Poly 318 Timing Chain - How Slack is Too Slack?
50002000200050010025
Check the play at the distributor as you move the motor back and forth. If the play is more than 10-15 degrees, you should definitely change it.
Edited by Powerflite 2020-09-21 10:49 PM
Rob
Posted 2020-09-23 9:04 PM (#603530 - in reply to #603431)
Thank you, Powerflite.
