56 Firedome shift cable
NYFDX
Posted 2020-09-21 8:43 PM (#603435)
Subject: 56 Firedome shift cable
Having difficulty re installing the shift cable for the powerflite. I’m trying to go by the shop manual but it’s a bit vague.
The cable goes thru the trans housing into a “tube” (cannot remember the nomenclature been a long day) and it’s held into position with a spring clip. Having difficulty getting the spring into the correct position to where it holds the cable into the case.
Any thoughts are appreciated.
Attachments 9AE1130D-A6B8-4ED6-84EA-91E83B8739EB.jpeg (113KB - 207 downloads)
Posted 2020-09-22 2:23 PM (#603477 - in reply to #603435)
Subject: RE: 56 Firedome shift cable
200010005001001002525
Is the shifter in L when trying to install the cable? This extends the inner cable the maximum amount.
Posted 2020-09-22 4:15 PM (#603482 - in reply to #603435)
NYFDX - 2020-09-21 5:43 PM
The spring clip is used to hold the tip of the shifter cable to the shifter "comb" inside the transmission. The cable is held to the transmission case by an "L" shaped bracket and a bolt. The adjustment of the cable in/out is based on the elongated slot in the upper end of that bracket. Don't forget that you need a 3/8" O-ring on the cable at the transmission end in order to keep the fluid from leaking out.
Photos courtesy of Per E. in Sweden:
(PF2-20191126_181933.jpg)
(TF-PF-20191126_181540.jpg)
(PF1-20191126_181559.jpg)
Attachments PF2-20191126_181933.jpg (147KB - 214 downloads)
Attachments TF-PF-20191126_181540.jpg (112KB - 205 downloads)
Attachments PF1-20191126_181559.jpg (101KB - 193 downloads)
NYFDX
Posted 2020-09-25 11:29 AM (#603573 - in reply to #603435)
Subject: Re: 56 Firedome shift cable
Thanks all
Can’t figure out how to get the spring clip to hold the tip of the cable inside the trans to the shifter comb
normsclassicradio
Posted 2020-09-25 12:16 PM (#603575 - in reply to #603573)
100100252525
FSM states have someone in the car holding the "1" first gear button down while pushing the cable into place. Maybe remove the bracket temporarily to get that last little distance.
Posted 2020-09-25 12:28 PM (#603576 - in reply to #603573)
NYFDX - 2020-09-25 8:29 AM
Not sure if this will help you or not:
When I was investigating the early Torqueflite vs Powerflite shifter boxes and how they moved the shifter cable with each push of their respective buttons, I learned that for the Powerflite boxes, the Reverse button pulls the cable back the most. This means that the shifter comb is twisted back towards the point where the cable enters the casing the most. In contrast, the Low button pushes the cable out towards the transmission (and shifter comb) the most. So having the shifter comb in the R position and the cable in the L position provides the greatest likelihood that the tip of the cable will engage the comb mechanism and the locking spring.
REFERENCE (with photos): http://www.forwardlook.net/forums/forums/thread-view.asp?tid=70947&...
So that helps (in my mind) to explain why the 56 Chrysler Factory Service Manual, in regard to installing the Powerflite shifter cable, says:
"b. Installing Cable
Push in Low (L) push button. The transmission manual valve lever should be in Reverse (R) position—if not so positioned, move neutral switch contact part of lever (full travel) towards rear of car manually, by using screw driver (or other suitable tool) in neutral starting switch hole. With Low (L) push button held tightly in (full travel), insert cable assembly into transmission case engaging cable ferrule groove with lock spring in cable adapter. Push and pull the cable, using light pressure, to be sure groove in cable ferrule has engaged lock spring. Replace adjustable mounting bracket and tighten cap screw finger tight."
Edited by 56D500boy 2020-09-25 12:33 PM
(56ChryslerPowerFliteControlBoxDiagrams.jpg)
(56ChryslerPowerFliteShifterCableInstallationRemoval_1.jpg)
(56ChryslerPowerFliteShifterCableInstallationRemoval_2.jpg)
Attachments 56ChryslerPowerFliteControlBoxDiagrams.jpg (166KB - 194 downloads)
Attachments 56ChryslerPowerFliteShifterCableInstallationRemoval_1.jpg (242KB - 202 downloads)
Attachments 56ChryslerPowerFliteShifterCableInstallationRemoval_2.jpg (236KB - 198 downloads)
NYFDX
Posted 2020-09-25 3:03 PM (#603581 - in reply to #603435)
That’s great thanks
However I think I need a new retaining clip anyone have a part number for it?
Posted 2020-09-25 4:34 PM (#603585 - in reply to #603581)
NYFDX - 2020-09-25 12:03 PM
Why yes I do!
1673 184 and Len Dawson has one at his website (*BUT* I think that you could find a similar workable spring clips elsewhere, maybe even HomeDepot or Lowes or McMaster-Carr or Auveco)
UPDATES:
1. 1673 184 was also used in the early Torqueflites
2. Using the technique that I suggested previously for finding things in the Auveco parts catalogue, I found what looks to be the right type of clip on page 193 (see below)
REFERENCE: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=74648&...
3. Unless the spring really looks like this:
Edited by 56D500boy 2020-09-25 11:09 PM
(PowerFliteCableSpringClipLocationIndentifier.jpg)
(PowerFliteCableSpringClipPN1673184.jpg)
(PowerFliteCableSpringClipPN1673184_AtLenDawsonsWebsite.jpg)
(Potential1673184EquivalentAtAuveco.jpg)
Attachments PowerFliteCableSpringClipLocationIndentifier.jpg (158KB - 198 downloads)
Attachments PowerFliteCableSpringClipPN1673184.jpg (179KB - 192 downloads)
Attachments PowerFliteCableSpringClipPN1673184_AtLenDawsonsWebsite.jpg (121KB - 199 downloads)
Attachments Potential1673184EquivalentAtAuveco.jpg (157KB - 201 downloads)
NYFDX
Posted 2020-09-25 10:45 PM (#603595 - in reply to #603435)
56D:
Thanks so much again this is great information.
Posted 2020-09-25 11:08 PM (#603596 - in reply to #603595)
NYFDX - 2020-09-25 7:45 PM
Just be aware that there are two styles of spring clips and that I don't know which one you have. (??)
Hopefully, you or your transmission person does/will.
Posted 2020-09-26 12:33 PM (#603606 - in reply to #603596)
The spring clip isn't a standard hardware part.
(Clip.jpg)
Attachments Clip.jpg (23KB - 201 downloads)
Posted 2020-09-26 1:58 PM (#603610 - in reply to #603606)
57chizler - 2020-09-26 9:33 AM
Thanks for posting that John. Obviously the diagram that I posted above that shows a clip in the 55-58 Mopar Parts Catalogue was done with the first Generation clip. The second generation equally obviously (now) is quite different.
I couldn't find Pat Blais directly but I did find one on eBay just now:
https://www.ebay.com/itm/Torqueflite-SHIFT-PARK-Cable-Adapters-SPRIN...
NYFDX
Posted 2020-10-04 5:27 PM (#603970 - in reply to #603435)
Well I ordered a new spring and it’s the correct part but unfortunately it still does not work. When I get the cable into the shifter comb the spring does not hold it into the comb securely, it is easily pulled out. So any other suggestions are appreciated. I’m thinking of trying to find a new cable, maybe that’s the issue.
Posted 2020-10-04 8:54 PM (#603983 - in reply to #603970)
NYFDX - 2020-10-04 2:27 PM I’m thinking of trying to find a new cable, maybe that’s the issue.
There must be an issue with end of your cable. Is there no groove like the end of this Powerflite cable?
Edited by 56D500boy 2020-10-04 8:55 PM
Posted 2020-10-05 1:16 PM (#604016 - in reply to #603970)
Can you hear a distinct "click" when you push the cable core in?
