King Pin Upright Nuts Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Plazaman |
Member Posts: 39 | I need two nuts for the upright bushings on my 1955 Suburban. I would like to replace all four if I could. They are an odd size and thread. | ||
Expert 5K+ Posts: 9900 Location: Lower Mainland BC | Plazaman - 2020-10-05 4:54 PM I need two nuts for the upright bushings on my 1955 Suburban. I would like to replace all four if I could. They are an odd size and thread. Unless I am mistaken, you are looking for the Pins and Nuts listed in 2-08-4 and 2-10-4 in the diagram below and shown in Wizard's (Sven's) photo (below). The nuts are not available as a separate part The 2-10-4 pin and nut are PN 1241500 (an old part that started used as early as 1941 and then improved in 1952 and used until 1956). This one is available at Hiltop Mopar: https://www.hiltopautoparts.com/product/nos-mopar-upper-control-arm-... In checking 2-08-4, the PN for the Pin and Nut is the same 1241500 (???). Might be. The difference would be in the camber bushings (2-08-3) on the upper connection That would be 1321 130, which I found on eBay: https://www.ebay.com/itm/41-56-Ply-Dodge-Chry-NOS-MoPar-Upper-Contro... Edited by 56D500boy 2020-10-05 9:42 PM | ||
Plazaman |
Member Posts: 39 | 56D500boy, thanks for the info. I am after the nuts only at this time. I already have everything else new. The new parts didn't come with the nuts. | ||
Expert 5K+ Posts: 9654 Location: So. Cal | If you don't mind used, contact BigM auto. | ||
Expert 5K+ Posts: 9900 Location: Lower Mainland BC | Plazaman - 2020-10-06 1:49 PM 56D500boy, thanks for the info. I am after the nuts only at this time. I already have everything else new. The new parts didn't come with the nuts. Strange. Based on the 55-58 Parts Catalog and the photo of the NOS 1241 500 parts, they were only sold as a matching set, "pin" and nut. I'm guessing that if anything wore, it was the "pin" and the nut would be fine to reuse (maybe with a few drops of LocTite) Edited by 56D500boy 2020-10-06 7:36 PM (1241500PinAndNut_UpperControlArm.jpg) (1241500PinAndNut_LowerControlArm.jpg) Attachments ---------------- 1241500PinAndNut_UpperControlArm.jpg (228KB - 230 downloads) 1241500PinAndNut_LowerControlArm.jpg (210KB - 228 downloads) | ||
Plazaman |
Member Posts: 39 | 56D500boy I bought a "complete" bushing kit online. Everything was there except the nuts. I have two of the original nuts that are usable, The other two are rusted beyond use. | ||
Plazaman |
Member Posts: 39 | Powerflight, thanks for the info. Do you have Big M's contact info? | ||
Expert 5K+ Posts: 9900 Location: Lower Mainland BC | . I'm not Nathan (Powerflite) but I have bought from John at Big M so: http://www.bigmauto.com/ They officially open at 9 AM PDT. Good Luck | ||
Plazaman |
Member Posts: 39 | 56D500boy, thanks for the help! | ||
