1960 Station Wagon gas tank strap
jboymechanic
Posted 2020-10-19 3:47 PM (#604644)
Subject: 1960 Station Wagon gas tank strap
2000100252525
I recently had a new tank strap laser cut from sheet metal for my 1960 Plymouth wagon, I carefully measured my rusty old one and made a flat template. The .dxf file attached will let any metal fabricator with a laser table cut you one, then you just have to bend it up and drill a hole on the end for the 3/8" bolt. I made the strap a little long so I could put the hole where I needed it and trim off the excess length. I was able to bend mine by hand with a vice and an old tractor axle tube. I used 14 gauge 302 stainless steel for mine. Guessing this will fit wagons up to 1964. For a picture of the final strap, you can find it in my build thread linked below:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=72926&...
Edited by jboymechanic 2020-10-19 3:51 PM
Attachments 1960 Plymouth Gas Tank Strap.DXF (66KB - 173 downloads)
NicksGarage
Posted 2020-10-19 5:43 PM (#604651 - in reply to #604644)
Subject: Re: 1960 Station Wagon gas tank strap
1000100100
Thanks for sharing that. And yes, the strap is the same for full size wagons from 1960-1964. I got one from a '64 and compared it to my '60 and it is exactly the same.
I'm reposting your strap picture here.
(tank_strap.jpg)
Attachments tank_strap.jpg (205KB - 173 downloads)
