55 NY'er Power Seats.
1955NYer
Posted 2020-12-03 11:01 PM (#606341)
Subject: 55 NY'er Power Seats.
55 NY'er Power Seats.....anyone have a place to start in troubleshooting. Seemingly no response when you toggle the switch.
Posted 2020-12-04 2:04 AM (#606343 - in reply to #606341)
Subject: RE: 55 NY'er Power Seats.
500020002000500100100100100
1955NYer - 2020-12-03 8:01 PM
You're going to need a multimeter to check the circuit. My first guess would be that the 30 amp circuit breaker is faulty but it could just be a broken wire.
Have fun.
(55ChryslerPowerSeatDiagram_1.jpg)
Attachments 55ChryslerPowerSeatDiagram_1.jpg (98KB - 196 downloads)
Posted 2020-12-04 7:47 PM (#606374 - in reply to #606341)
Subject: Re: 55 NY'er Power Seats.
5000200020005001002525
Typically, the cable inside them freezes up from rust and when the motor is turned on, it can burn up if not stopped, or it can blow the fuse if you are lucky. Solution is to remove the cable, lube it up, check the motor and check the fuse.
