58+ Steering Box valve assembly O-rings
Posted 2020-12-26 3:41 PM (#607154)
Subject: 58+ Steering Box valve assembly O-rings
50002000100100100252525
Looks like my steering box developed the first leak in 61 years. Not a big leak, it doesn't drop oil on the floor, but I would like to fix it. Does someone know where to get the proper 0-rings? 2 small and a big one. I drive my car 12 month a year so I got to have them at hand, for a quick repair.
Posted 2020-12-26 4:01 PM (#607156 - in reply to #607154)
Subject: Re: 58+ Steering Box valve assembly O-rings
500050002000100025
RockAuto has the kits Sid.
That said, I bought an assortment of green viton o- rings, inch sizes and I found the suitible ones there.
I've notised that the Gates kits have o-rings that barely make a seal and needle bearings with half the amount of rollers as the oem ones.
Posted 2020-12-26 4:19 PM (#607157 - in reply to #607154)
Thanks for the info Sven, but at Rockauto I can find only a complete seal kit from "Sungsong"....
Posted 2020-12-26 5:13 PM (#607158 - in reply to #607154)
500050002000100025
Here Sid https://www.rockauto.com/en/catalog/chrysler,1958,saratoga,5.8l+354c...
Posted 2020-12-27 11:33 AM (#607173 - in reply to #607158)
Thanks! These didn't show up under 60 Dodge Dart/Steering, which randomly picked, knowing it is the same as 60 Plymouth. I hope they are the same!
Posted 2020-12-27 12:37 PM (#607176 - in reply to #607154)
500050002000100025
I have renovated 4 steering gears Sid, '59 and '60 and they're all the same. If there are some differences on the '58, then it's the valve, but I do think the housing and the o-rings are the same.
Posted 2021-01-23 6:33 PM (#608095 - in reply to #607154)
Turned out to be only the neck hsg O-rings, not the valve hsg, so no adjustments afterwards. I thought it is a gasket but there are O-rings too. 7mm id x 2mm and 16mm id x 2mm (which actually measured more like 16.7x2) worked. So a few cents and a few minutes for the 1rst ever repair for a 61+ y.o. ps box did it. Got to love these cars.
I remember our 2000 Opel family car that was still running like new after 140K miles and 9 years but the faulty, intermittent ps system was its doom, too expensive to repair....
Edited by 1960fury 2021-01-23 6:35 PM
58coupe
Posted 2021-01-24 12:08 PM (#608111 - in reply to #607154)
100050010010025
i had a 72 Opel 1900 ( same as Manta ) before they started making them in Japan. Loved that car but a little small for the family, ex wife got it.
Posted 2021-01-24 4:12 PM (#608123 - in reply to #608111)
58coupe - 2021-01-24 12:08 PM
Yes, nice, but I never understood why Americans bought or drove German cars, with all that Detroit glory around
