354 poly to recent 727 Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Rockkers |
Member Posts: 28 Location: Canada / Quebec | hay everyone really really new to this, been on the web and searching for answers for a month or so. i juste bought a 1956 dodge regent and a 1957 354 poly engine, looking to put a more recent 727 on it. i know they make an adaptor plate for it, i think i have one but i am not sure. part : 1612344 centr-o-cast seems to have a logo of DCPD same as the original parts.... trying to make sense of the real info and the possibilities. could gat a 1979 727 that was on a 360 thanks in advance!!! | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | Only transmissions manufactured in 1961 and earlier will fit that engine. In 1962, Chrysler changed the bellhousing dowel pin location and the crank shaft mounting flange. You can buy an adapter kit from Hot Hemi Heads that will allow an newer 727 TF trans to be attached to your '57 engine, but then you have to figure out how to actually select gears (your original push buttons won't work). | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | . That adapter plate is for the Powerflites and the early A-466 Cast Iron torqueflites. The later 727 torqueflites require something else entirely. Your project is NOT as simple as you might think. You should read Dave Homstad's 727 into a 56 American Dodge (behind a D500 315 hemi) blog: https://web.archive.org/web/20100715212727/http://webpages.charter.n... Have fun. Edited by 56D500boy 2021-01-18 11:07 PM | ||
Rockkers |
Member Posts: 28 Location: Canada / Quebec | Will do! And the car had a 3 speed manual on it so i already knew that i would figure out a linkage modification | ||
58coupe |
Expert Posts: 1740 Location: Alaska | One of our members makes the proper adapters to do your project. his website is quality engineered components.com You need the bell housing adapter and the crankshaft adapter to fit the newer 727 to the 354 that he sells. I used his bell housing adapter to fit a newer BH to my 354 and an 833 4 speed.I had to modify an older flywheel to work with this. | ||
Rockkers |
Member Posts: 28 Location: Canada / Quebec | Thank a lot very nice website, i will have to take some measure but it looks good, even a link for brake kits!! | ||
Expert Posts: 3777 Location: NorCal | The problem with a 727 swap in any FL is the loss of the tail-mounted parking brake. To get a parking brake you have to swap in a later rear end or find the one-year-only '62 727 with the tail-mounted parking brake. These came only in big block full-sized cars so the tail would have to be swapped into a small block case to make the conversion. | ||
Rockkers |
Member Posts: 28 Location: Canada / Quebec | Yes i read that a lot but my axle has an axle striped so i was thinking of changing the whole thing and get something younger. On a 1979 727 from a 360 it would have a parking pawl as well? | ||
Expert 5K+ Posts: 9667 Location: So. Cal | Yes, all automatic transmissions 1963 and up have a parking pawl, except for the truck transmissions stated below. In the small block world, all the truck auto transmissions from '62-'64 & maybe '65 have the parking brake on the back of them. So that's a way to get it as well if you want it. Edited by Powerflite 2021-01-20 3:01 PM | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | 58coupe - 2021-01-19 11:09 AM Gary is a great guy. I've used his twice now.One of our members makes the proper adapters to do your project. his website is quality engineered components.com You need the bell housing adapter and the crankshaft adapter to fit the newer 727 to the 354 that he sells. I used his bell housing adapter to fit a newer BH to my 354 and an 833 4 speed.I had to modify an older flywheel to work with this. | ||
RICKYMOPAR |
Veteran Posts: 292 Location: Colorful Colorado skier on the license plate | Just finished this type of change over, It's chronicled in the 59 Plymouth Forum, under garage. | ||
Rockkers |
Member Posts: 28 Location: Canada / Quebec | Thank you!! Will check it out! But can't seem to find the garage link or i missed something hahaha Edited by Rockkers 2021-02-09 10:11 PM | ||
RICKYMOPAR |
Veteran Posts: 292 Location: Colorful Colorado skier on the license plate | http://www.59plymouth.net/59forum/ Hope this helps | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | RICKYMOPAR - 2021-02-09 5:45 PM Just finished this type of change over, It's chronicled in the 59 Plymouth Forum, under garage. This one? http://www.59plymouth.net/59forum/viewtopic.php?f=45&t=3457 | ||
RICKYMOPAR |
Veteran Posts: 292 Location: Colorful Colorado skier on the license plate | Yes, this will work. http://www.59plymouth.net/59forum/viewtopic.php?f=45&t=3457 | ||
Stroller |
Extreme Veteran Posts: 371 | Me wondering something. Are you trying to go to a cuolum or floor shifter doing this? When I had my 354 and it's cast iron cuz sitting out I looked at the difference in bell housing comparing the alcoa and cast versions. All I was thinking was Chrysler was cruel in changing stuff and what a bummer. Think of the diet you could put car on just getting out that cast iron monster. | ||
RICKYMOPAR |
Veteran Posts: 292 Location: Colorful Colorado skier on the license plate | This is going to a push-button shifted vehicle, I have another on my stand now. floor lever shifted valve bodies have a different manual valve, not a problem. | ||
Rockkers |
Member Posts: 28 Location: Canada / Quebec | Well the car had a column shifter and i would like to keep it for the 727 i will put in i ordered an adapter to mate it and will make a reliable linkage to it if i can hahahah if not i will go floor shift i guess | ||
wayfarer |
Elite Veteran Posts: 888 Location: Peoples Republic of Oregon | Remember that you will need to fab/install linkage for the kick-down. Trans will die if driven long w/o it. | ||
wayfarer |
RICKYMOPAR |
Veteran Posts: 292 Location: Colorful Colorado skier on the license plate | We were able to use the older original linkage with a minor readjustment. | ||
Rockkers |
Member Posts: 28 Location: Canada / Quebec | Well i have none so i will look for that too hahaha | ||
