Forward Look Trucks Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 9648 Location: So. Cal | This thread is meant to capture information in one place, on an often over-looked entity of our group - the trucks. One of the most surprising things about the trucks is that for some odd reason, Dodge decided that in 1957, they would not provide a VIN number plate on the truck. Instead, they put the VIN information on a paper card in the glove box. Good idea! The VIN (or partial VIN) is also located on the front left part of the frame behind the front bumper. Don't mess with that section of your frame or you are screwed! And I am not sure if it is only a motor number or the actual VIN number. Best to verify before you swap motors in your truck. Fortunately, they didn't carry this insanity forward beyond 1957 and very early '58. I don't know how you would actually do a VIN verification on '57 trucks because I've never known them to scrub frames, looking for numbers. You'd probably have to make it visible for them and give them lots of guidance. You can also have a new VIN card made up for $10 and put anything you want on it to show to the DMV, and they wouldn't be able to scoff at it because its just like the original. https://www.ebay.com/itm/193230585925 Townwagon.com is a good resource for these trucks, but they mainly center on the 4x4 & panel trucks. https://www.townwagon.com/pgpws/index.htm (1957papervin.jpg) (57-58 Dodge VIN Locations.jpg) Attachments ---------------- 1957papervin.jpg (26KB - 222 downloads) 57-58 Dodge VIN Locations.jpg (103KB - 213 downloads) | ||
Expert 5K+ Posts: 9648 Location: So. Cal | In my '57-'58 truck parts book, the different models are laid out. Many of the newer style of truck bodies hadn't come out yet like the Low Cab Forward (LCF) that came out in 1960 or the tilt-cab that came out in 1964. So most of the forwardlook trucks followed the following basic designations. A lot of the 4x4 and some 6x6 trucks are actually the flat fendered military style Power Wagons that are more popular than the regular trucks today. But Dodge did start making civilian styled 4x4 power wagons & town wagons starting in 1957 and on too. D = Conventional Model W = 4 Wheel Drive C = Cab Over Engine (COE) P = Forward Controls (Commercial Panel like a milk or mail truck) S = School Bus T = 6 Wheel Drive ("T" Probably stands for Tractor) 100 = 1/2 Ton 200 = 3/4 Ton L300 = 3/4 Ton 300 = 1 Ton L400 = 1 Ton 400 = 1 1/2 Ton L500 = 1 1/2 Ton 500 = 2 Ton L600 = 1 1/2 Ton 600 = 2 1/2 Ton L700 = 1 1/2 Ton 700 = 2 1/2 Ton L800 = 2 Ton 800 = 3 Ton L900 = 2 Ton 900 = 4 Ton The L here seems to indicate that it is a light duty version, but what are the real differences between them? The parts list states: "Parts for special models (the "Lx00") preceded by an asterisk (*) are the same as the standard models... (without an L in front of it). " So essentially all DL400 models use the same parts as the D400 etc. for each of the different models. If that's true, then why specify a different model that has a lower stated capacity? Pretty weird, and I don't really understand this. But I can confirm that it seems to be true with my truck. It's a '57 D200 3/4 ton truck with a 315 poly V8, a flatbed and a dually axle. Usually dually axles define it as a 1 ton truck, not 3/4 ton. I checked the engine number and expected to see a VT536 for a D200, but instead found a VT538 for a D300 or DL300. The DL300 is the correct designation for my truck, and as such it is defined as a 3/4 ton with D200 badges, and 3/4 ton written on the title, yet with all the equipment and parts to physically be a 1 ton truck. So you have to be careful when ordering parts. You may have D200 or something else on the title, but really need to order D300 or some other parts to get the right ones. Also notice that there are 3 models for 2 Ton and 4 models for 1 1/2 ton trucks. These labels aren't as straightforward as they may at first seem. Checking the engine number and comparing it to the model that refers to is probably the best way to figure out what you have if you aren't familiar with the different variations. (57D200.jpg) (small Truck Back.JPG) Attachments ---------------- 57D200.jpg (127KB - 206 downloads) small Truck Back.JPG (100KB - 218 downloads) | ||
58coupe |
Expert Posts: 1740 Location: Alaska | I have 2 56 dodge 1/2 ton trucks (one for parts). Fortunately I have a title for the one I am restoring.There is another possibility for the "L" in the model number, these trucks were made both with a short and long wheelbase and box. Not sure how this was shown in the vin. | ||
Expert 5K+ Posts: 9648 Location: So. Cal | A wheelbase designation would sort-of make sense, except that I believe even the D100 had short & long wheelbase options, but the D100 designation doesn't have a DL100 listed, or a DL200 for that matter either. Also, why would a long wheelbase truck lower its carrying capacity? Part of my problem is my truck doesn't have a VIN to refer to... | ||
Expert 5K+ Posts: 9648 Location: So. Cal | I mentioned that it's best to check the motor number to fully identify which truck you have, especially for 1957, which likely has no VIN information with it. The only place I know where to get that info is in the parts catalog, which I don’t believe is posted anywhere. So I am posting the important first couple of pages here for people’s reference. Quality Engineered Component’s website has a list of the different truck motor IDs, but his list is a little lacking and some of the information is wrong. There are a lot of other motor prefixes that he doesn't have listed, and I don't have his VT576 for 1958 anywhere on here. Also, that designation has got to be wrong because it isn't using the proper L8-XX code for 1958. Notice that there are no 331 hemi motors listed in trucks in '57-'58, in contradiction to what he has listed as well. I have tabulated all of the 354 hemi motors for future convenience. They are all in the heavy duty 700-900 sized trucks, none in the smaller ones, but it was probably optional to put one into a smaller truck, but I don't know what restrictions there were on it. All of the 354 hemi motors that are listed for 1957-58 are: VT548, L8-D7 D(L)700 VTS548, L8-S7 S700 VT560, L8-C7 C(L)700 VT562, L8-T7 T(L)700 VT550, L8-D8 D(L)800 VT566, L8-T8 T(L)800 VT552, L8-D9 D(L)900 VT568, L8-T9 T(L)900 Edited by Powerflite 2021-01-22 2:54 AM (57-58 Dodge Truck Models Pg2.jpg) (57-58 Dodge Truck Models Pg3.jpg) (57-58 Dodge Truck Models Pg4.jpg) (57-58 Dodge Truck Models Pg5.jpg) Attachments ---------------- 57-58 Dodge Truck Models Pg2.jpg (238KB - 214 downloads) 57-58 Dodge Truck Models Pg3.jpg (245KB - 216 downloads) 57-58 Dodge Truck Models Pg4.jpg (237KB - 226 downloads) 57-58 Dodge Truck Models Pg5.jpg (120KB - 214 downloads) | ||
Expert 5K+ Posts: 9648 Location: So. Cal | Further digging into my own truck, it looks like I may be wrong. I measured a 116 in wheelbase on it, which matches the D200 description. The VIN number on the title has an obvious error in it (That's going to be a whole lot of fun to fix!) but it looks to match more to the D200 numbers than to the DL300. So I'm not sure what to think, but it looks like it is indeed a D200 that was ordered with dually wheels and received a VT538 motor stamp for some reason. I am only the 3rd owner of this truck so I know the history reasonably well. I know the 2nd owner didn't swap anything around on it, but I'm not sure about the 1st owner (the parks municipal service) that owned it for the longest period of time. | ||
Expert 5K+ Posts: 9648 Location: So. Cal | On page 9-15, the parts catalog describes the different engine options. This looks to describe which models could have been ordered with the optional 315 hemi motor, and which models came with it standard. In 1957, it is described as a "Premium 8 cylinder 315", and in 1958, as a "double rocker shaft 315 engine". This is what it says: Note 5: Refers to K series (1957) only. A premium 8 cylinder 315 (314.61) cubic inch displacement engine is standard for the following models: K8-D600, K8-C600. This engine is available for models K8-D500 (Fitting choice! ), K8-C500, and K8-W500 as extra equipment. This engine is stamped with the letter "P" at the oil filler spout, in addition to the regular stamp, denoting it is a premium engine. Note 6: Refers to L series (1958). An 8 cylinder 315 (314.61) cubic displacement SINGLE ROCKER SHAFT engine is standard for models: L8-W300, L8-D400, L8-D500, L8-C500, L8-W500 (and optional on all lower models, but not stated here). Identification: on the single rocker shaft engine the spark plugs are located ALONGSIDE the cylinder head cover. Note 7: Refers to L series (1958). An 8 cylinder 315 (314.61) cubic displacement DOUBLE ROCKER SHAFT engine is standard for models: L8-D600, L8-C600. This engine is optional extra equipment for models L8-D400, L8-D500, L8-C500, L8-W500. Identification: on the double rocker shaft engine the spark plugs are located UNDER the cylinder head cover. Where no mention of notes occur, parts for the single and double rocker shaft engines are the same. Therefore, the 315 hemi truck motors had number stampings: P-VT546, L8-D6 D600 standard P-VT558, L8-C6 C600 standard P-VT544, L8-D5 D500 optional P-VT556, L8-C5 C500 optional P-VT504, L8-W5 W500 optional L8-D4 D400 (1958 only) optional The premium "P" marking makes it easy to determine which 315 motors were originally hemi motors in '57, but in '58, you can't tell. For the '58 D400, D500, C500, & W500, it could have been either one and it isn't denoted on the block. They don't mention the school buses or panel vans so I assume those were all powered by poly motors, except for the S700 school bus which was powered by a 354 hemi. | ||
Expert 5K+ Posts: 9895 Location: Lower Mainland BC | Powerflite - 2021-01-21 6:42 PM On page 9-15, the parts catalog describes the different engine options. This looks to describe which models could have been ordered with the optional 315 hemi motor, and which models came with it standard. In 1957, it is described as a "Premium 8 cylinder 315", and in 1958, as a "double rocker shaft 315 engine". I just remembered that I had these: (58DodgeSweptSideWith315PowerGiant.jpg) (315PowerGiantInA1958DodgeSweptSidePickup.jpg) (1958DodgeSweptsideColdAirInductionIntakeforAC_3.jpg) Attachments ---------------- 58DodgeSweptSideWith315PowerGiant.jpg (151KB - 223 downloads) 315PowerGiantInA1958DodgeSweptSidePickup.jpg (83KB - 212 downloads) 1958DodgeSweptsideColdAirInductionIntakeforAC_3.jpg (95KB - 211 downloads) | ||
Expert 5K+ Posts: 9648 Location: So. Cal | This is a Dodge hemi motor from a '55 1.5 Ton truck. The seller claims it is a 359. Does he mean 259? I suspect it really is a 270, but not sure. The motor number on it is VTX-342-2372. https://www.ebay.com/itm/294020922367 (55 Dodge Truck Hemi VTX342.jpg) (55 Dodge Truck Hemi VTX342 front.jpg) Attachments ---------------- 55 Dodge Truck Hemi VTX342.jpg (95KB - 194 downloads) 55 Dodge Truck Hemi VTX342 front.jpg (108KB - 185 downloads) | ||
Expert 5K+ Posts: 9895 Location: Lower Mainland BC | Powerflite - 2021-02-20 8:05 AM This is a Dodge hemi motor from a '55 1.5 Ton truck. The seller claims it is a 359. Does he mean 259? I suspect it really is a 270, but not sure. The motor number on it is VTX-342-2372. https://www.ebay.com/itm/294020922367 Nathan: The closest thing to VTX 342 in your list above is VTS 542 for a K8-S400 1.5 ton. I couldn't find a VTX or a 342, let alone together. That said, I might be blind. However in Googling "VTX 342", I found this eBay auction for a 2 bbl Stromberg carb that says: "Fitment: 1955-56 Dodge Truck VT-338 VT-344 VT-346 VTX-342 VTX-346 MT with 270ci engines" https://hartbroscore.com/products/1955-56-dodge-truck-vt-338-344-346... Edited by 56D500boy 2021-02-20 11:41 AM | ||
Expert 5K+ Posts: 9648 Location: So. Cal | Keep in mind that my list above is for 1957 and 1958 only. So the fact that a '55 truck motor number doesn't show up on it should come as no surprise. The number does sound similar to the '57 school bus. But the truck seems to be painted red though, not school bus yellow. Someone needs to purchase a '55-'56 book and post the info from it. '59-'61 would be nice too. | ||
Expert 5K+ Posts: 9648 Location: So. Cal | Here are the different models listed in the '59 truck catalog. 1959 was the last year for hemi motors inside trucks. The 315's were reserved for 2-2.5 ton trucks (500-600), with the 354 used in 2.5-4 ton trucks (700-900). There are light duty 1.5 ton frames in there too, but with the same 500-900 model designation. The 318 poly motor was used in the light duty V8 trucks. 315 hemi: M8-C5, M8-D6, M8-S6, M8-C6 354 hemi: M8-D7, M8-S7, M8-C7, M8-T7, M8-D8, M8-T8, M8-D9, M8-T9 (1959 Truck Models 10.jpg) (1959 Truck Models 20.jpg) Attachments ---------------- 1959 Truck Models 10.jpg (233KB - 116 downloads) 1959 Truck Models 20.jpg (224KB - 129 downloads) | ||
56 Cruiser |
Extreme Veteran Posts: 329 Location: Claremore, Okla. | My dad's 59 (My Early Days of Hot Rodding 011.jpg) Attachments ---------------- My Early Days of Hot Rodding 011.jpg (139KB - 127 downloads) | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | Powerflite - 2021-01-21 11:29 AM A wheelbase designation would sort-of make sense, except that I believe even the D100 had short & long wheelbase options, but the D100 designation doesn't have a DL100 listed, or a DL200 for that matter either. Also, why would a long wheelbase truck lower its carrying capacity? Part of my problem is my truck doesn't have a VIN to refer to... Your parts book is showing that the "L" designated trucks and "non-L" versions share the same wheelbase options. Seems pretty clear that "L" denotes "Light" for the 300+ series trucks, as in every case the only difference is the reduced load capacity. I have to assume it's a softer spring for trucks that were going to be driven on the road more, as these things were notorious for... driving like an old truck. | ||
Expert 5K+ Posts: 9648 Location: So. Cal | These are the different bodies shown in the '57-'58 parts catalog. The '59 catalog doesn't have any body types shown in pictures. 1957 KD100 Express (Pickup) 1957 KW100 & KW200 4-wheel drive Power Wagon 1957 KD100 Panel & Town Wagon Edited by Powerflite 2021-08-27 12:55 PM (57 KD100 Pickup_s.jpg) (57 KW100 Pickup_s.jpg) (57 KD100 Panel_s.jpg) (KD100 Wagon Rear_s.jpg) Attachments ---------------- 57 KD100 Pickup_s.jpg (139KB - 107 downloads) 57 KW100 Pickup_s.jpg (132KB - 103 downloads) 57 KD100 Panel_s.jpg (154KB - 103 downloads) KD100 Wagon Rear_s.jpg (158KB - 105 downloads) | ||
Expert 5K+ Posts: 9648 Location: So. Cal | 1958 LD100 Express (pickup) 1958 LD100 Town Wagon & Panel Edited by Powerflite 2021-08-27 11:20 AM (58 LD100 Pickup_s.jpg) (58 LD100 Wagon_s.jpg) (LD100 Panel Rear_s.jpg) Attachments ---------------- 58 LD100 Pickup_s.jpg (139KB - 115 downloads) 58 LD100 Wagon_s.jpg (179KB - 111 downloads) LD100 Panel Rear_s.jpg (170KB - 107 downloads) | ||
Expert 5K+ Posts: 9648 Location: So. Cal | KD200 Flat Face Cowl K(L)P300, K(L)P400 Forward Control KD400 Platform & Stake Bed KW300(M) 4 wheel drive military Power Wagon (57 KD200 Flat Face Cowl_s.jpg) (57 KP300 Forward Control_s.jpg) (57 KD400 Platform & Stake_s.jpg) (57 KW300 Pickup_s.jpg) Attachments ---------------- 57 KD200 Flat Face Cowl_s.jpg (124KB - 112 downloads) 57 KP300 Forward Control_s.jpg (112KB - 97 downloads) 57 KD400 Platform & Stake_s.jpg (159KB - 102 downloads) 57 KW300 Pickup_s.jpg (181KB - 123 downloads) | ||
Expert 5K+ Posts: 9648 Location: So. Cal | KC500 Cab Over KD500 KW500 4 wheel drive LD500 (57 KC500 Cabover_s.jpg) (57 KD500 Standard Cab_s.jpg) (57 KW500_s.jpg) (58 LD500_s.jpg) Attachments ---------------- 57 KC500 Cabover_s.jpg (156KB - 114 downloads) 57 KD500 Standard Cab_s.jpg (155KB - 101 downloads) 57 KW500_s.jpg (147KB - 109 downloads) 58 LD500_s.jpg (136KB - 105 downloads) | ||
Expert 5K+ Posts: 9648 Location: So. Cal | The '54-'56 trucks were labeled as the C-series with '54 - mid '55 as C1, and mid '55 to '56 as C3. The change from C1 to C3 in the middle of 1955 was due to a re-design of the cab with a more curved wrap-around front windshield. Officially, the C-series continued on to 1960 while the cab design was still being used on the light duty pickups. But the parts books no longer named them with the "C" in front of the model, starting in '57 with the introduction of the Power Giant name. The mid C3 cab continued to be used in heavy duty trucks well into the late '60's, but I'm not sure when they stopped using it. I've listed all of the truck models that used V8 motors during these years. Not all of them are dual rocker hemi motors though. I suspect that the 259/260 motor was the same poly motor that was used in the '55 Plymouth. Some of the 270 motors listed here might be poly motors as well, but unlike the '57-'58 parts book, I have no way to tell from the description listed in the '54-'56 parts books. Getting information from these years is more chaotic than the later years as well. You have to search through multiple supplements and later editions to get all the information. The later editions don't include much of the information in the earlier editions either, so you can't just look at one book. You'll notice there is a discrepancy in the C3-J models where the earlier book listed the motor as a 260, but the later edition listed the same engine number as a 270. I suspect that they really are 270 motors, assuming that the later edition corrected the error, but it should be verified. It's possible that they used both motors as well and introduced the 270 with the same engine stamp at a later date. Also, notice that a specific engine stamp isn't unique to a specific size of Dodge engine. All the Chrysler engines had unique engine stamps, but the Dodge engines seemed to be stamped more for the model than the engine. Also notice that this list includes two 4x4 trucks. They are designated with the "W" in the model. Civilian style 4x4 trucks weren't supposed to have started until 1957, but it seems that there were a couple of 4x4 heavy duty trucks earlier than that - the C3-HW8 and K8W500. The last one has more of a '57 model number, so not sure why it was included in these older books. The "S" in a model designates a school bus, similar to the newer trucks. Unfortunately, the book doesn't give a full explanation of what all the different models represent, but some of them are revealed in the pictures, and the rest would need to be found through truck sales brochures or other places. _____By Truck Model____________________By Engine Stamp______ Model_____Engine____Size ------------- Model____Engine_____Size C1-B8_____ VT334___ 241 ------------- C1-B8_____ VT334___ 241 C1-D8_____ VT338___ 241 ------------- C3-B8_____ VT334___ 260 C1-G8_____ VTX342__ 241 ------------- C3-C8_____ VT336___ 260 C1-GA8____ VTX342__ 241 ------------- C1-D8_____ VT338___ 241 C1-H8_____ VT344___ 241 ------------- C3-D8_____ VT338___ 260 C1-HA8____ VT344___ 241 ------------- C3-DL8____ VT338___ 260 C1-HAL8___ VT344___ 241 ------------- C3-F8_____ VT342___ 260 C1-HL8____ VT344___ 241 ------------- C3-FL8____ VT342___ 260 C1-J8_____ VT346___ 241 ------------- C3-FS8____ VTS342__ 260 C1-JA8____ VT346___ 241 ------------- C1-G8_____ VTX342__ 241 C1-JAL8___ VT346___ 241 ------------- C1-GA8____ VTX342__ 241 C1-JL8____ VT346___ 241 ------------- C3-G8_____ VTX342__ 260 C1-K8_____ VTX346__ 241 ------------- C3-GL8____ VTX342__ 260 C1-KA8____ VTX346__ 241 ------------- C1-H8_____ VT344___ 241 C1-KAL8___ VTX346__ 241 ------------- C1-HA8____ VT344___ 241 C1-KL8____ VTX346__ 241 ------------- C1-HAL8___ VT344___ 241 C1-R8_____ VT348___ 331 ------------- C1-HL8____ VT344___ 241 C1-RA8____ VT348___ 331 ------------- C3-H8_____ VT344___ 260 C1-RAL8___ VT348___ 331 ------------- C3-HA8____ VT344___ 260 C1-RL8____ VT348___ 331 ------------- C3-HAL8___ VT344___ 260 C1-RS8____ VTS348__ 331 ------------- C3-HL8____ VT344___ 260 C1-T8_____ VT350___ 331 ------------- C3-HS8____ VTS344__ 260 C1-TA8____ VT350___ 331 ------------- C3-HH8____ VTX344__ 260 C1-TAL8___ VT350___ 331 ------------- C3-HHA8___ VTX344__ 260 C1-TL8____ VT350___ 331 ------------- C3-HHAL8__ VTX344__ 260 C1-V8_____ VTX350__ 331 ------------- C3-HHL8___ VTX344__ 260 C1-VA8____ VTX350__ 331 ------------- C3-JA8____ VT346__ 260 C1-VAL8___ VTX350__ 331 ------------- C3-JAL8___ VT346__ 270 C1-VL8____ VTX350__ 331 ------------- C3-JAL8___ VT346__ 260 C3-B8_____ VT334___ 260 ------------- C3-JL8____ VT346__ 270 C3-B8_____ VT434___ 270 ------------- C3-JL8____ VT346__ 260 C3-C8_____ VT336___ 260 ------------- C1-J8_____ VT346___ 241 C3-D8_____ VT338___ 260 ------------- C1-JA8____ VT346___ 241 C3-D8_____ VT438___ 270 ------------- C1-JAL8___ VT346___ 241 C3-DL8____ VT338___ 260 ------------- C1-JL8____ VT346___ 241 C3-DL8____ VT438___ 270 ------------- C3-J8_____ VT346___ 270 C3-DN8____ VT418___ 270 ------------- C3-J8_____ VT346___ 260 C3-DNL8___ VT418___ 270 ------------- C3-JA8____ VT346___ 270 C3-F8_____ VT342___ 260 ------------- C3-JS8____ VTS346__ 260 C3-FL8____ VT342___ 260 ------------- C3-JS8____ VTS346__ 270 C3-FS8____ VTS342__ 260 ------------- C1-K8_____ VTX346__ 241 C3-G8_____ VT442___ 270 ------------- C1-KA8____ VTX346__ 241 C3-G8_____ VTX342__ 260 ------------- C1-KAL8___ VTX346__ 241 C3-GA8____ VT442___ 270 ------------- C1-KL8____ VTX346__ 241 C3-GAL8___ VT442___ 270 ------------- C3-K8_____ VTX346__ 270 C3-GL8____ VT442___ 270 ------------- C3-KA8____ VTX346__ 270 C3-GL8____ VTX342__ 260 ------------- C3-KAL8___ VTX346__ 270 C3-GN8____ VT422___ 270 ------------- C3-KL8____ VTX346__ 270 C3-GNL8___ VT422___ 270 ------------- C3-KS8____ VTXS346_ 270 C3-GS8____ VTS442__ 270 ------------- C1-R8_____ VT348___ 331 C3-H8_____ VT344___ 260 ------------- C1-RA8____ VT348___ 331 C3-H8_____ VT444___ 270 ------------- C1-RAL8___ VT348___ 331 C3-HA8____ VT344___ 260 ------------- C1-RL8____ VT348___ 331 C3-HA8____ VT444___ 270 ------------- C3-R8_____ VT348___ 331 C3-HAL8___ VT344___ 260 ------------- C3-RA8____ VT348___ 331 C3-HAL8___ VT444___ 270 ------------- C3-RAL8___ VT348___ 331 C3-HH8____ VT446___ 270 ------------- C3-RL8____ VT348___ 331 C3-HH8____ VTX344__ 260 ------------- C1-RS8____ VTS348__ 331 C3-HHA8___ VT446___ 270 ------------- C3-RS8____ VTS348__ 331 C3-HHA8___ VTX344__ 260 ------------- C1-T8_____ VT350___ 331 C3-HHAL8__ VT446___ 270 ------------- C1-TA8____ VT350___ 331 C3-HHAL8__ VTX344__ 260 ------------- C1-TAL8___ VT350___ 331 C3-HHL8___ VT446___ 270 ------------- C1-TL8____ VT350___ 331 C3-HHL8___ VTX344__ 260 ------------- C3-T8_____ VT350___ 331 C3-HHM8___ VT458___ 270 ------------- C3-TA8____ VT350___ 331 C3-HHMA8__ VT458___ 270 ------------- C3-TAL8___ VT350___ 331 C3-HHMAL8_ VT458___ 270 ------------- C3-TL8____ VT350___ 331 C3-HHML8__ VT458___ 270 ------------- C1-V8_____ VTX350__ 331 C3-HHS8___ VTS446__ 270 ------------- C1-VA8____ VTX350__ 331 C3-HL8____ VT344___ 260 ------------- C1-VAL8___ VTX350__ 331 C3-HL8____ VT444___ 270 ------------- C1-VL8____ VTX350__ 331 C3-HM8____ VT456___ 270 ------------- C3-V8_____ VTX350__ 331 C3-HMA8___ VT456___ 270 ------------- C3-VA8____ VTX350__ 331 C3-HMAL8__ VT456___ 270 ------------- C3-VAL8___ VTX350__ 331 C3-HML8___ VT456___ 270 ------------- C3-VL8____ VTX350__ 331 C3-HS8____ VTS344__ 260 ------------- C3-HW8____ VT404___ 270 C3-HS8____ VTS444__ 270 ------------- C3-DN8____ VT418___ 270 C3-HW8___ VT404___ 270 ------------- C3-DNL8___ VT418___ 270 C3-J8_____ VT346___ 270 ------------- C3-GN8____ VT422___ 270 C3-J8_____ VT346___ 260 ------------- C3-GNL8___ VT422___ 270 C3-JA8____ VT346___ 270 ------------- C3-B8_____ VT434___ 270 C3-JA8____ VT346___ 260 ------------- C3-D8_____ VT438___ 270 C3-JAL8___ VT346___ 270 ------------- C3-DL8____ VT438___ 270 C3-JAL8___ VT346___ 260 ------------- C3-G8_____ VT442___ 270 C3-JL8____ VT346___ 270 ------------- C3-GA8____ VT442___ 270 C3-JL8____ VT346___ 260 ------------- C3-GAL8___ VT442___ 270 C3-JS8____ VTS346__ 270 ------------- C3-GL8____ VT442___ 270 C3-JS8____ VTS346__ 260 ------------- C3-GS8____ VTS442__ 270 C3-K8_____ VT448___ 331 ------------- C3-H8_____ VT444___ 270 C3-K8_____ VTX346__ 270 ------------- C3-HA8____ VT444___ 270 C3-KA8____ VT448___ 331 ------------- C3-HAL8___ VT444___ 270 C3-KA8____ VTX346__ 270 ------------- C3-HL8____ VT444___ 270 C3-KAL8___ VT448___ 331 ------------- C3-HS8____ VTS444__ 270 C3-KAL8___ VTX346__ 270 ------------- C3-HH8____ VT446___ 270 C3-KL8____ VT448___ 331 ------------- C3-HHA8___ VT446___ 270 C3-KL8____ VTX346__ 270 ------------- C3-HHAL8__ VT446___ 270 C3-KM8____ VT460___ 331 ------------- C3-HHL8___ VT446___ 270 C3-KMA8___ VT460___ 331 ------------- C3-HHS8___ VTS446__ 270 C3-KMAL8__ VT460___ 331 ------------- C3-K8_____ VT448___ 331 C3-KML8___ VT460___ 331 ------------- C3-KA8____ VT448___ 331 C3-KS8____ VTS448__ 331 ------------- C3-KAL8___ VT448___ 331 C3-KS8____ VTXS346_ 270 ------------- C3-KL8____ VT448___ 331 C3-KX8____ VT462___ 331 ------------- C3-KS8____ VTS448__ 331 C3-KXL8___ VT462___ 331 ------------- C3-T8_____ VT450___ 331 C3-R8_____ VT348___ 331 ------------- C3-TA8____ VT450___ 331 C3-RA8____ VT348___ 331 ------------- C3-TAL8___ VT450___ 331 C3-RAL8___ VT348___ 331 ------------- C3-TL8____ VT450___ 331 C3-RL8____ VT348___ 331 ------------- C3-Y8_____ VT452___ 354 C3-RS8____ VTS348__ 331 ------------- C3-YA8____ VT452___ 354 C3-T8_____ VT350___ 331 ------------- C3-YAL8___ VT452___ 354 C3-T8_____ VT450___ 331 ------------- C3-YL8____ VT452___ 354 C3-TA8____ VT350___ 331 ------------- C3-HM8____ VT456___ 270 C3-TA8____ VT450___ 331 ------------- C3-HMA8___ VT456___ 270 C3-TAL8___ VT350___ 331 ------------- C3-HMAL8__ VT456___ 270 C3-TAL8___ VT450___ 331 ------------- C3-HML8___ VT456___ 270 C3-TL8____ VT350___ 331 ------------- C3-HHM8___ VT458___ 270 C3-TL8____ VT450___ 331 ------------- C3-HHMA8__ VT458___ 270 C3-TX8____ VT466___ 331 ------------- C3-HHMAL8_ VT458___ 270 C3-TXL8___ VT466___ 331 ------------- C3-HHML8__ VT458___ 270 C3-V8_____ VTX350__ 331 ------------- C3-KM8____ VT460___ 331 C3-VA8____ VTX350__ 331 ------------- C3-KMA8___ VT460___ 331 C3-VAL8___ VTX350__ 331 ------------- C3-KMAL8__ VT460___ 331 C3-VL8____ VTX350__ 331 ------------- C3-KML8___ VT460___ 331 C3-Y8_____ VT452___ 354 ------------- C3-KX8____ VT462___ 331 C3-YA8____ VT452___ 354 ------------- C3-KXL8___ VT462___ 331 C3-YAL8___ VT452___ 354 ------------- C3-TX8____ VT466___ 331 C3-YL8____ VT452___ 354 ------------- C3-TXL8___ VT466___ 331 C3-YX8____ VT468___ 354 ------------- C3-YX8____ VT468___ 354 C3-YXL8___ VT468___ 354 ------------- C3-YXL8___ VT468___ 354 K8-W500__ VT504___ 315 ------------- K8-W500___ VT504___ 315 Edited by Powerflite 2022-12-26 11:44 AM | ||
horace |
Extreme Veteran Posts: 471 Location: MN | Yes, there is more to forward look than cars. This is my 57 Dodge W 100 Power Wagon, with astounding options like 2 tone paint, 315 V8, ashtray, cigar liter, oil filter, & long stem exterior mirror! The others my 79 Macho Power Wagon & 18 Laramie with Ram Boxes, sure grip & all kinds of too much (LARL Detroit Lakes_20230105_115313_0001.jpg) (LARL Detroit Lakes_20230105_115313_0001.jpg) Attachments ---------------- LARL Detroit Lakes_20230105_115313_0001.jpg (179KB - 53 downloads) LARL Detroit Lakes_20230105_115313_0001.jpg (179KB - 48 downloads) | ||
horace |
Extreme Veteran Posts: 471 Location: MN | There were heavier than "light duty" 4x4 trucks offered before '57 | ||
Expert 5K+ Posts: 9648 Location: So. Cal | Nice truck Horace! It's funny that a rear view mirror, radio, cigar lighter & ashtray are highly prized options for these trucks, but they are all very rare to get! Dodge truck buyers seemed to be quite poor. I wasn't very thrilled with the reproduction VIN card for my '57 Dodge truck that wasn't cleaned up very well before printing. So I made a new vector image that can be scaled up very high. I had to hand make the "DODGE TRUCKS" font and some of it needs a little tweaking still. I also made the "DODGE" text in the circle, but I just had to modify another font that was close, so it came out better. I'm going to print this out on card stock and put it in my truck with the proper information on it. That way I can present it to the DMV personnel that intend to do VIN inspection on my truck. (57 Dodge Truck VIN Card-s.jpg) (57 Dodge Truck Vector Vin Card.jpg) Attachments ---------------- 57 Dodge Truck VIN Card-s.jpg (192KB - 44 downloads) 57 Dodge Truck Vector Vin Card.jpg (85KB - 55 downloads) | ||
horace |
Extreme Veteran Posts: 471 Location: MN | I didn't replace the tailgate w/ the nifty but expensive embossed ones that are available. I took a picture of an old tailgate had it blown up by a print shop. I'll post a rear pic some day | ||
horace |
Extreme Veteran Posts: 471 Location: MN | Here's a pic of my tailgate, I just had a decal made but the embossed tailgates are soooo much better but this works. Sorry for the extra detritus there Edited by horace 2023-02-23 2:30 PM (dodge.jpg) (trucks.jpg) Attachments ---------------- dodge.jpg (157KB - 38 downloads) trucks.jpg (390KB - 37 downloads) | ||
