1955-1956 Plymouth parts for sale Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Forward Look Swap Meet -> For Sale - PARTS | Message format |
jerrybev |
Elite Veteran Posts: 689 Location: Winston Salem, N.C. | 1955 NOS dash gages: temp, oil pressure, NOS "Savoy" body script, $30 each. Used Powerflite " trunk emblems $50, $100, owners manual $10, gas door $10, free steering column. 1956 parts for sale: NOS : "Savoy" body script, $30; Carb rebuild kit for Carter WCFG fits all Chrysler Corp cars 1955-1957, SBI 2 oil seals, $5, brake wheel cyl. repair kit NAPA # 291 & 212, $5 each, voltage regulator $20, Wagner wheel cyl. kit WK11345 $5, ignition resistor V8 # from A.L. Wells Co. #795 $5,Napa Rotor #AL125, $2, generator brushes Tungsten E46X $5, rotor button Borg WArner D-13 SHD $5, idler arm repair kit $20, distributor #1688647 $20, thermostat $10, USED: Hollywood steering wheel center with full horn ring $150, Used Powerflite " trunk emblems $50, $100, dash radio speaker plate $10, ash tray $10, gas door $5, cigarette lighter $5, temp gage dash knob $5 Have exterior stainless trim body spears, inquire. $25, hood bird $35, headlight switch $15, 4 bbl Carter Carb WCFB 2202SA $70, 2 318"poly valve covers, $25 pr, new fuel pump V8, $45, shift cables for powerflite trans. $12, powerflite shifter, working condition $75, dip stick tube, powerflite $10, carb choke $5, oil breather cap $5, generator fan double pulley cast iron $25, crank shaft damper pulley (2 grooves) for 8 cyl $12, water pump double pulley 8 cyl $12, generator $25, left rear bumper bracket for 55-56 car $15, single water pump pulley, clean $20, water pump rebuilt for V8 $20, water pump bypass hose with clamp $10, crankshaft pulley, single, clean, $20, seat tracks for front $10 pr, heater core no leaks $20, inside & outside heater blower box with motor $20, manual steering linkage $25, outer gas door $10, cigarette lighter complete unit $25, winston salem, NC 27103, 336-749-5922 leave message. email: jerrybev1@yahoo.com (2 pulleys.JPG) (16 length oil dip stick small.JPG) (1956 ply pulleys 5.5 and 7 inches.JPG) (1956 heater blower assembly.JPG) (1956 under hood 3.JPG) (lighter assembly 2 for cigar.JPG) (powerflite 3 pieces 2.JPG) (NOS thermostat.JPG) (oil cap.JPG) (wings, 56 wagon.JPG) (carb kit 2.JPG) (number 18 picture 2.JPG) (ash tray.JPG) Attachments ---------------- 2 pulleys.JPG (176KB - 97 downloads) 16 length oil dip stick small.JPG (78KB - 96 downloads) 1956 ply pulleys 5.5 and 7 inches.JPG (207KB - 92 downloads) 1956 heater blower assembly.JPG (101KB - 97 downloads) 1956 under hood 3.JPG (192KB - 91 downloads) lighter assembly 2 for cigar.JPG (142KB - 93 downloads) powerflite 3 pieces 2.JPG (137KB - 92 downloads) NOS thermostat.JPG (173KB - 90 downloads) oil cap.JPG (130KB - 96 downloads) wings, 56 wagon.JPG (191KB - 92 downloads) carb kit 2.JPG (110KB - 97 downloads) number 18 picture 2.JPG (193KB - 92 downloads) ash tray.JPG (140KB - 93 downloads) | ||
Plazaman |
Member Posts: 39 | Do you have a picture of the 2-groove crank pulley? | ||
jerrybev |
Elite Veteran Posts: 689 Location: Winston Salem, N.C. | hi 2 groove pulley is gone, do have two single pulley ones thanks jerry | ||
jerrybev |
