Oil Seals, Rear Axle, Pinion
dels56
Posted 2021-03-15 12:50 PM (#609887)
Subject: Oil Seals, Rear Axle, Pinion
1001001002525
If anyone is looking for a pinion Seal or Rear Axle Seal or for that matter any other canned oil/grease seal, Take a look at this SKF Interchange look-up.
http://www2.chicago-rawhide.com/popup_parts_lookup_457012.htm
Plug in the Chrysler Part Number or a number you may have off the seal and the SKF interchange number will be shown along with every other manufacture of that seal. In most instances your local bearing house will be able to pick the seal off the shelf.
I did not know where else to post this/
Del S
AndreaPeters
Posted 2021-06-07 12:42 PM (#612521 - in reply to #609887)
Subject: Re: Oil Seals, Rear Axle, Pinion
New User
It's ok. Thx for information. Maybe your post will help to others like me
Edited by AndreaPeters 2021-06-07 12:43 PM
