1962 Plymouth Belvedere Carpet
furvedere
Posted 2021-03-18 5:46 PM (#610102)
Subject: 1962 Plymouth Belvedere Carpet
100100252525
I know Im a year past FL mopars but does anyone know if 80/20 Rayon/Nylon Loop Carpet-500 series would have been standard for 62 B-bodies. I want to order carpet and the supplier sent me samples. The other samples are of a Cut Pile Carpet-800 series. My gut tells me the 80/20 Loop is correct but just want to make sure. Thanks, Bob
ABloch
Posted 2021-03-18 10:22 PM (#610111 - in reply to #610102)
Subject: Re: 1962 Plymouth Belvedere Carpet
1000100100100100252525
Factory issue was cut pile. Unfortunately I have tried two vendors and neither one was very good as far as color match. ACC was the closest to the correct cut and appearance.
Edited by ABloch 2021-03-18 10:23 PM
furvedere
Posted 2021-03-19 11:03 AM (#610129 - in reply to #610111)
100100252525
ABloch - 2021-03-18 10:22 PM
Oh ok, can you tell me when 80/20 loop was factory. Pretty sure my 68-69-70 c-bodies had it. Thought my 57-58 Plymouth Belvederes did too. Thanks, Bob
ABloch
Posted 2021-03-20 3:02 PM (#610176 - in reply to #610102)
Subject: RE: 1962 Plymouth Belvedere Carpet
I can not tell you when this happened. It's been so long that I had to look and see what I ended up with.
I ended up with the loop for my '62 Fury because the cut pile wasn't available in the color that I needed.
Here's a swatch I cut of the original material.
(carpet.jpg)
Attachments carpet.jpg (144KB - 148 downloads)
