Emergency brake
slow2learn
Posted 2021-05-16 9:07 AM (#612031)
Subject: Emergency brake
Hi,
Would anyone one know of a source for the large retaining springs (not sure of the proper names) in the emergency brake drum of a CAST IRON TOQUEFLITE?
Thanks in advance for any help.
Posted 2021-05-16 1:00 PM (#612039 - in reply to #612031)
Subject: RE: Emergency brake
5000200020005001001001002525
One or both of these??
slow2learn
Posted 2021-05-16 1:32 PM (#612041 - in reply to #612031)
Subject: Re: Emergency brake
Yes both the grease shield spring and the brake shoe return spring. I don't know how but they came loose and got destroyed inside the drum. Thank you for posting the pics.
MSS73
Posted 2021-09-28 11:41 AM (#615410 - in reply to #612031)
Is that back plate bolted somewhere?
In my car that whole plate with shoes moves inside of drum.
Everything seems to work, but noise is awful.
I have service manual, but i don't understand what keeps it in place.
Can it be only with spacer and spring?
Here is link to my youtube video.
https://youtu.be/UJROx4UvmUo
My car is Desoto Firesweep 1958
Edited by MSS73 2021-09-28 11:43 AM
Posted 2021-09-28 4:43 PM (#615418 - in reply to #612031)
500020002000500100
That little spring in the center is the one that holds it onto the tail of the transmission. If you are missing parts, I suggest that you contact BigM Auto for good used ones. But take yours apart first to see if you need any more parts due to damage etc., so you are only paying for shipping once.
Edited by Powerflite 2021-09-28 4:45 PM
MSS73
Posted 2021-09-30 3:25 PM (#615490 - in reply to #612031)
I put my brake drum to pieces today and one spring was in two pieces.
Im going to made new springs, but another thing seems to be wrong.
[img]https://i.postimg.cc/q6z5Z2CY/v-lys.jpg[/img]
I think that there should no be gap between grease shield and backplate ???
Edited by MSS73 2021-09-30 3:27 PM
MSS73
Posted 2021-10-02 10:33 AM (#615536 - in reply to #615490)
MSS73 - 2021-09-30 10:25 PM
Grese cap wasn't deep enough, there was reason for gap.
Look's that someone has built that break wrong way earlier.
