Source for a 19 tooth Powerflite speedometer pinion
green monster
Posted 2021-05-24 1:32 PM (#612212)
Subject: Source for a 19 tooth Powerflite speedometer pinion
I,m looking for a 19 tooth Powerflite speedometer pinion.
I have a 17 tooth in there now and the speedometer is 10 mph off.
The engine and trans were changed from a different car before I owned it.
I hope somebody here has a new/used one..
Dan
Posted 2021-05-24 2:50 PM (#612214 - in reply to #612212)
Subject: RE: Source for a 19 tooth Powerflite speedometer pinion
500020002000500100100100100
What you have is a 1559 395 Orange 17 tooth pinion. What you see is a 1559 396 Blue 19 tooth pinion. The "Atlas" (after market) numbers are 817-233 (17 tooth) and 817-232 (19 tooth).
Reference: http://atlasobsoleteparts.homestead.com/files/xref1to1599.htm
Nothing at Len Dawson Mopar or Hiltop Mopar.
Edited by 56D500boy 2021-05-24 2:53 PM
Posted 2021-05-26 2:09 PM (#612255 - in reply to #612212)
20001000500100100252525
Before changing the pinion, check the odometer reading over a known distance. If the odometer is fairly accurate, the speedo error is in the head, not the pinion.
green monster
Posted 2021-06-04 8:01 AM (#612453 - in reply to #612212)
Subject: Re: Source for a 19 tooth Powerflite speedometer pinion
The odometer is also off...
green monster
Posted 2021-06-26 3:30 PM (#613114 - in reply to #612212)
UPDATE:
Got a 19 tooth speedometer pinion from Fatsco and now the speedometer and odometer read correctly.
If anybody is searching for a 17 tooth pinion wiith the carrier, I have 2.
Edited by green monster 2021-06-26 3:32 PM
imp610
Posted 2021-10-06 9:43 AM (#615619 - in reply to #613114)
green monster - 2021-06-26 3:30 PM
Hi, I need one ! How can I get it? PM sent.
Edited by imp610 2021-10-06 9:51 AM
jboymechanic
Posted 2021-10-06 11:02 AM (#615620 - in reply to #612212)
2000100252525
I'm actually looking for one as well. PM sent
