1956 Royal 4 door sedan drivers roll down window replacement
green monster
Posted 2021-08-11 9:46 PM (#614168)
Subject: 1956 Royal 4 door sedan drivers roll down window replacement
I'm searching for a replacement drivers side roll down window since mine is cracked.
The passenger side may work too if I cant find the drivers side.
Does anyone know of other model and years of dodge and plymouth 4 door sedans that will fit this?
I suspect the 1955 dodge, 1955 and 1956 plymouth may fit if I can find them in the same tint level.
I may have a 55 plymouth 4 door to try in a local salvage yard.
Posted 2021-08-12 2:14 AM (#614171 - in reply to #614168)
Subject: RE: 1956 Royal 4 door sedan drivers roll down window replacement
500020002000500100100100100
Despite the difference in wheelbases between the 1955-56 Dodge and Plymouths (120" Dodge and 115" Plymouth (and Canadian Dodges)), the front doors of the 4 dr sedans are basically the same. (The rear doors are not)
As a result, any 1955 or 1956 Dodge or Plymouth 4dr sedan or wagon could be a front door glass donor. Furthermore, there is no left and right.
1591 634 Clear (non-tinted Solex) 1591 637 tinted (Solex)
Good luck.
Edited by 56D500boy 2021-08-12 2:18 PM
(55-56DodgeAndPlymouth4drFrontDoorWindowGlassPNs.jpg)
Attachments 55-56DodgeAndPlymouth4drFrontDoorWindowGlassPNs.jpg (147KB - 76 downloads)
green monster
Posted 2021-08-12 11:08 PM (#614183 - in reply to #614168)
Subject: Re: 1956 Royal 4 door sedan drivers roll down window replacement
Thank you for the info.
Posted 2021-08-12 11:15 PM (#614184 - in reply to #614183)
green monster - 2021-08-12 8:08 PM
Hope you can find what you need.
This thread has some info that might help you with the install/door rehab
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=72267&...
