Starter Relay Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Lancer Mike |
Location: The Mile High City | Does anyone have a spare (new or used)? (starter relay.JPG) Attachments ---------------- starter relay.JPG (76KB - 55 downloads) | ||
Lancer Mike |
Expert 5K+ Posts: 9902 Location: Lower Mainland BC | Lancer Mike - 2021-09-11 10:30 AM Does anyone have a spare (new or used)? Um...Mike. Is that the horn relay, not the starter relay? It is important to starting but it DOES NOT transfer power from the battery to the starter. It does provide a point in the engine bay to get power from the battery to the ignition coil, which is important. There are new ones out there to be had. Or you can open yours up and determine whether the issue is contact points or a broken wire. REFERENCE: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=75311&... Edited by 56D500boy 2021-09-11 6:16 PM | ||
springsweptwing |
Elite Veteran Posts: 1141 Location: Blackpool, United Kingdom. | Hi Mike, same relay used till early seventies, just a spade terminal instead off bullet on the neutral safety wire. | ||
springsweptwing |
Elite Veteran Posts: 1141 Location: Blackpool, United Kingdom. | 56D500boy - 2021-09-11 7:50 PM Lancer Mike - 2021-09-11 10:30 AM Does anyone have a spare (new or used)? Um...Mike. That is the horn relay, not the starter relay. It is important to starting but it DOES NOT transfer power from the battery to the starter. It does provide a point in the engine bay to get power from the battery to the ignition coil, which is important. There are new ones out there to be had. Or you can open yours up and determine whether the issue is contact points or a broken wire. REFERENCE: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=75311&... Hi Dave, That is the starter relay, horn relay is similar. (IMG_20210911_202019_copy_800x600.jpg) Attachments ---------------- IMG_20210911_202019_copy_800x600.jpg (103KB - 52 downloads) | ||
springsweptwing |
Elite Veteran Posts: 1141 Location: Blackpool, United Kingdom. | Horn relay looks like this (IMG_20210911_202105_copy_499x665.jpg) Attachments ---------------- IMG_20210911_202105_copy_499x665.jpg (205KB - 47 downloads) | ||
Expert 5K+ Posts: 9902 Location: Lower Mainland BC | springsweptwing - 2021-09-11 12:55 PM Hi Dave, That is the starter relay, horn relay is similar. Okay my bad. Sure looked like a horn relay (at least a 1956 horn relay). When I read "starter relay" in Mike's first post, I immediately thought "starter solenoid" which, apparently is different. Here is a 1956 era starter solenoid: I guess the difference is the starter in 1957 (??). Two wire, with the actual solenoid on the starter. Still I would have expected heavier connections on the "relay". Sorry. I was wrong. | ||
springsweptwing |
Elite Veteran Posts: 1141 Location: Blackpool, United Kingdom. | Hi Dave, It's for the starters that have the solenoid on top instead of the bendix drive type solenoid/relay like you're picture. The relay only energies the solenoid on the starter, there is no real load on the relay itself, just takes a power from the positive cable to work the relay and solenoid on starter. Edited by springsweptwing 2021-09-11 5:55 PM | ||
Lancer Mike |
Location: The Mile High City | springsweptwing - 2021-09-11 1:53 PM Hi Mike, same relay used till early seventies, just a spade terminal instead off bullet on the neutral safety wire. Thank you, fellas. I did get one of the later ones for $35, but the tabs go out to the sides. It works for now, but I'd like to get a correct replacement. I've found them on-line from $285 to about $95. | ||
springsweptwing |
Elite Veteran Posts: 1141 Location: Blackpool, United Kingdom. | Hi Mike, Can you not swap the cases over? | ||
Expert 5K+ Posts: 9902 Location: Lower Mainland BC | springsweptwing - 2021-09-11 3:21 PM Hi Mike, Can you not swap the cases over? Agree (to the possibility). Based on the similarity to my 56 Dodge horn relay, that might just work: | ||
Lancer Mike |
Location: The Mile High City | That may be the thing to do. Thought I would ask here if anyone had a spare they would sell first though...
b5rt |
Expert Posts: 2519 Location: central Illinois | Is this a match?? A little pricey, even for ebay. https://www.ebay.com/itm/203590219321?hash=item2f66ec3639:g:U6EAAOSw... | ||
Lancer Mike |
Location: The Mile High City | Yes, this is a match. It was the least expensive I found on the interwebs. | ||
Lancer Mike |
Location: The Mile High City | Here's the King Kong at $278.77 + shipping https://www.moparmall.com/1658997-1842546-1842550-RAM4001-RAM4002-relay-p/hs-76734.htm last time I checked, I was driving a De Soto - not a Duesenberg. Edited by Lancer Mike 2021-09-11 11:10 PM | ||
springsweptwing |
Elite Veteran Posts: 1141 Location: Blackpool, United Kingdom. | Hi Mike, For the price of a original you can alter one of these, https://www.ebay.com/itm/194002930177?hash=item2d2b79ca01:g:RVQAAOSw... Thanks Paul. | ||
Lancer Mike |
Location: The Mile High City | Thank you, Paul - that' s probably what I'll end up doing. Particularly if no one here has a spare. | ||
mobileparts |
Veteran Posts: 253 | I P.M.ed you that I have them back on August 3, 2020, when you first asked about them --- and you replied that "you were on vacation in the mountains and had spotty cell phone service" and "that you would call me when you got back"..... Over 13 months ago, I still haven't heard from you..... Are you still on vacation in the mountains ??? I have them BRAND NEW --- N.O.S. ---- at far less than $ 279..... They, are 100 % CORRECT, of course....... Edited by mobileparts 2021-09-14 7:44 PM | ||
Lancer Mike |
Location: The Mile High City | Hi, Craig: I am sorry about my poor communication efforts. What is your price? | ||
