1956 Chrysler New Yorker differential
aldoskivich
Posted 2021-10-26 7:17 AM (#616298)
Subject: 1956 Chrysler New Yorker differential
Where do I get parts for a 56 New Yorker differential?
Posted 2021-10-26 8:21 AM (#616299 - in reply to #616298)
Subject: Re: 1956 Chrysler New Yorker differential
50005000200050010010025
As for bearings, RockAuto has them…
Posted 2021-10-26 10:54 AM (#616301 - in reply to #616298)
Subject: RE: 1956 Chrysler New Yorker differential
5000200010001001001001002525
aldoskivich - 2021-10-26 4:17 AM
Anything specific?
(3_22_45PinionSealDiagram_1.jpg)
(RearAxleAssemblyDiagram_2.jpg)
Attachments 3_22_45PinionSealDiagram_1.jpg (143KB - 41 downloads)
Attachments RearAxleAssemblyDiagram_2.jpg (130KB - 40 downloads)
aldoskivich
Posted 2021-10-28 5:09 AM (#616346 - in reply to #616301)
Thanks for your reply. I have not assessed the condition of this differential. I am really trying to determine which diff it is....so i can replace it later on. I have a fresh built 392 going on in a few months. Can I purchase a posi traction entire assembly to install in the present carrier? If so, who makes this assembly..? Thank you for your help! Alan Thornton
58coupe
Posted 2021-10-28 11:25 AM (#616350 - in reply to #616298)
1000500100252525
No one makes a limited slip or posi unit that will fit your diff. The newer 8 3/4 diff. that was used from 57 on had this option from 58 on but it won't fit in your housing. You will need to change the complete rear to get this and I am not sure what rear will be the easiest to fit.
aldoskivich
Posted 2021-11-09 1:44 AM (#616664 - in reply to #616298)
Thanks. How about a non limited slip replacement? That will fit in my 56 new yorker housing. I`m not going to race this build, just a street rod.
