57 Dodge 2dr Wagon Cowl Data Tag Needs Decoding
   Forward Look Technical Discussions -> Fender/VIN Tag and Broadcast Sheet DecodingMessage format
Posted 2021-11-15 11:26 AM (#616860)
Subject: 57 Dodge 2dr Wagon Cowl Data Tag Needs Decoding
5000200020005001001001002525
resq302 - 2021-11-15 4:07 AM
Is there any way to decide a fender tag? I know there are pages for my 69 gtx fender tag to be decoded but since I’m new to the forward look era, I have no clue.
Thanks, Brian
Your photo is not a .jpg so it doesn't visibly load.
But I downloaded it separately and converted it from .jpeg to .jpg so it shows below (here) in the proper sub-forum: Fender/VIN tag decoding
Your vehicle was built on/around April 27, 1957
It is a 2167 = 2 dr Coronet Wagon
The paint code 3PLL = Gallant Gold and Glacier White
The trim code 110 = Pellon Vinyl and Silver Strata Fabric – Gold and Black
It has a torqueflite transmission (the 293 code)
I don't know the 324 or 487 codes but others will be by and tell you.
REFERENCES:
1. Body: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=74413&...
2. Paint: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=75119&...
3: Trim: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=74465&...
Edited by 56D500boy 2021-11-15 11:38 AM
(57Dodge2drWagonCowlTag.jpg)
Attachments 57Dodge2drWagonCowlTag.jpg (114KB - 150 downloads)
resq302
Posted 2021-11-15 12:59 PM (#616866 - in reply to #616860)
Subject: Re: 57 Dodge 2dr Wagon Cowl Data Tag Needs Decoding
Thanks. I appreciate it. The pic issue probably had something to do with loading it up as the pic is on my iPhone.
Posted 2021-11-15 1:07 PM (#616867 - in reply to #616866)
resq302 - 2021-11-15 9:59 AM
Hmm.... I thought that I had mentioned the .jpegs from iPhones DO NOT WORK.
You might want to read this thread regarding posting photos to this forum:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=64340&...
resq302
Posted 2021-11-15 3:32 PM (#616870 - in reply to #616860)
I didn’t read the thread on how to post photos. I was under the assumption the forum was like other forums I’ve been on in the past. My sincerest apologies.
Posted 2021-11-16 11:04 AM (#616890 - in reply to #616860)
Subject: RE: 57 Dodge 2dr Wagon Cowl Data Tag Needs Decoding
1000500100100100252525
Code 324 on the tag (order code 374) means Heater and Defroster
Code 487 on the tag (order code 677) means Delivery Route by Dealer’s Own Truck
