| Hi I have not got the keys for my 55 dodge coronet station wagon the door locks and tailgate locks are fitted ,is there any way of identifying and getting the correct keys ,or if not does anyone know where I can get new door locks and a tailgate lock thanks any help appreciated Phil |
Location: NorCal | Any competent mobile locksmith can make you keys. I've had it done several times. |
Location: Victoria, BC, on Vancouver Island, Canada | Arocket111 - 2021-12-20 12:45 AM
Phil,
Looks like you are in the UK.... you probably won't find a locksmith over there who can do them. However, if you want to send them across the Atlantic to me, I can make keys for them. I've been a forward look member since Moses was around, and a Locksmith since Adam and Eve were around. This page is my car key page on the company web site. https://www.acmesafe.ca/services/automotive
Other than that you might find some on line, here are some on Ebay.. https://www.ebay.ca/itm/284568827681?hash=item42419fb721:g:DMkAAOSwZ... |
| Hi thanks for the replies and help I will try locksmiths in the uk to see if I can get keys made as a first then if not go from there Phil |
New User
| When buying an auto part, you should also consider installing it: in the front or rear door, on the right, or on the left. It is necessary to consider the desired type of control (centralized or decentralized). Pay attention to the part's dimensions (length of the lock, diameter, and thread pitch): it is essential for correct installation. I missed this point and had to go to the Car key duplication online , which showed a clear example of replacing the entire locking mechanism, which usually involves removing the trim and disassembly of the door.
Edited by chrystekaib 2022-01-18 11:42 AM
