1956 Desoto wagon rear seat removal Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
NYFDX |
Regular Posts: 62 Location: NY | Before I do something stupid, any tips on the best way to remove the rear bench seat of a 56 desoto wagon? I could not find anything in the service manual and not much info online. Thanks in advance | ||
Expert 5K+ Posts: 9666 Location: So. Cal | I think you need to specify if you are talking about a 3rd seat or the 2nd rear seat. | ||
NYFDX |
Regular Posts: 62 Location: NY | Yes bench seat was the wrong term. It’s the removal of both rear seats for re covering | ||
Expert 5K+ Posts: 9666 Location: So. Cal | The bottom of the middle seat should push back and up to remove from the clips that hold it. That will reveal the mounts for the upper part. I'm not as certain on the 3rd seat during these years. | ||
Expert 5K+ Posts: 9903 Location: Lower Mainland BC | Powerflite - 2022-02-01 3:11 PM The bottom of the middle seat should push back and up to remove from the clips that hold it. That will reveal the mounts for the upper part. I'm not as certain on the 3rd seat during these years. I think that even the wagon rear seat bottom is held down differently than the sedans and hardtops. I am contacting Terrance D. (71charger_fan) to see if he can post answer (maybe with photos from his thread) here. Terrance's thread: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=63722&... Some photos. Not exactly the ones that are needed but... Edited by 56D500boy 2022-02-01 7:37 PM | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | If it's the same as my '55 Plymouth, the second seat's bottom lifts up where it's tucked under the back seat cushion. It can take a good yank to get it up. With that tipped up, you should have easy access to the attachment points to the body. | ||
Expert 5K+ Posts: 9903 Location: Lower Mainland BC | 71charger_fan - 2022-02-01 7:10 PM If it's the same as my '55 Plymouth, the second seat's bottom lifts up where it's tucked under the back seat cushion. It can take a good yank to get it up. With that tipped up, you should have easy access to the attachment points to the body. Terrance: Thanks for that. What about the normal back seat? I see some bolts on the rear floor pan brace/reinforcement. How do you access those to remove the bottom? | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | If I recall correctly, those are easily accessed when the rear seat cushion is down in the normal position for passengers. | ||
NYFDX |
Regular Posts: 62 Location: NY | Doesn’t look like you can push on the seats to remove them. Seems a bit more involved : | ||
Expert 5K+ Posts: 9903 Location: Lower Mainland BC | NYFDX - 2022-02-03 12:03 PM Doesn’t look like you can push on the seats to remove them. Seems a bit more involved. Like? 56D500boy - 2022-02-01 7:56 PM I see some bolts on the rear floor pan brace/reinforcement. How do you access those to remove the bottom? :) | ||
NYFDX |
Regular Posts: 62 Location: NY | Here’s some pics. Doesn’t look like you can push to remove them : | ||
NYFDX |
Regular Posts: 62 Location: NY | No pics, Won’t post | ||
Expert 5K+ Posts: 9666 Location: So. Cal | Maximum picture size is 250Kb. .jpg will show up directly, .jpeg will post as an attachment. | ||
NYFDX |
Regular Posts: 62 Location: NY | Ok I’ll have to figure the attachment part out, I couldn’t figure out how to attach multiple pics. I was able to remove the seats/seatbacks. Basically it’s just several screws that need to be removed from the seat hardware. I couldn’t see any bolts to remove from the floor pan as 56D stated. I’ve snapped a few more pictures when I figure out how to attach them I’ll submit another post. I the meantime I appreciate all the feedback. 56D and charger fan thanks for the pics | ||
Arocket111 |
Regular Posts: 64 | Hi I have a 1955 dodge coronet custom royale wagon ,I do not know if it is the same as mine only has one set of rear seats which are folding and can be removed by folding forward and unfastening the hinges and swivel on the upright part of the seat I am currently trying to download photos .photos now attached below I can’t seem to get them to be open on the thread. Edited by Arocket111 2022-02-04 10:44 AM Attachments ---------------- 4D8A0108-96EA-4025-8E7A-50D612C64D9E.jpeg (222KB - 72 downloads) 3CB7EF26-D03E-4060-A4E7-A48C4348C3DD.jpeg (217KB - 67 downloads) BD3AE92B-EB71-45A8-982A-D870663E7D14.jpeg (225KB - 67 downloads) 5E3F87FE-B5C0-4216-A8C9-B1AE817D3335.jpeg (196KB - 68 downloads) | ||
Expert 5K+ Posts: 9903 Location: Lower Mainland BC | Arocket111 - 2022-02-04 7:20 AM I am currently trying to download photos .photos now attached below I can’t seem to get them to be open on the thread. Phil: Thanks for posting those photos. The main reason that they would not open is because they are .jpeg photos from an iPhone or iPad, etc. They don't work here. Have to be .jpg. The other reason is they were too large. They need to be < 250 kB. I downloaded your photos and processed them to be 1024 x something so they were less than 250 kB and then saved them as .jpgs. Here they are, again, thanks. Should help in the future. (PS: They also confirm to me that your car's paint was definitely based on Heather Rose) Edited by 56D500boy 2022-02-04 11:22 AM (PhilLunds55DodgeWagonRearSeatRemovalDetail_1.jpg) (PhilLunds55DodgeWagonRearSeatRemovalDetail_2.jpg) (PhilLunds55DodgeWagonRearSeatRemovalDetail_3.jpg) (PhilLunds55DodgeWagonRearSeatRemovalDetail_4.jpg) Attachments ---------------- PhilLunds55DodgeWagonRearSeatRemovalDetail_1.jpg (174KB - 69 downloads) PhilLunds55DodgeWagonRearSeatRemovalDetail_2.jpg (220KB - 70 downloads) PhilLunds55DodgeWagonRearSeatRemovalDetail_3.jpg (148KB - 73 downloads) PhilLunds55DodgeWagonRearSeatRemovalDetail_4.jpg (86KB - 68 downloads) | ||
