Location: Winston Salem, N.C. | 1955 NOS dash gages: temp, oil pressure, NOS "Plaza " body script, $30 each. Used Powerflite trunk emblem $75, gas door $10,
1956 parts for sale: NOS : "Plaza" body script, $30; used hood letters I have available are: P Y M H $20 each
If you are going to use 12V electricals on your 1955, you may can use some of these 1956 parts: Carb rebuild kit for Carter WCFG fits all Chrysler Corp cars 1955-1957, SBI 2 oil seals, $5, brake wheel cyl. repair kit NAPA # 291 & 212, $5 each, voltage regulator $20, Wagner wheel cyl. kit WK11345 $5, ignition resistor V8 # from A.L. Wells Co. #795 $5,Napa Rotor #AL125, $2, generator brushes Tungsten E46X $5, rotor button Borg Warner D-13 SHD $5, idler arm repair kit $20, distributor #1688647 $20, , USED: Powerflite trunk emblem $75, dash radio speaker plate $10, ash tray $10, gas door $5, cigarette lighter $5, temp gage $30, dash knob $5, , Have exterior stainless trim body spears, 15-50.5" length, $15 each, inquire, $25, hood bird $35, headlight switch $15, oil breather cap $5, generator fan double pulley cast iron $30, crank shaft damper pulley (2 grooves) for 8 cyl $12, water pump double pulley 8 cyl $12, generator $25, left rear bumper bracket for 55-56 car $15, water pump bypass hose with clamp $10, , inside & outside heater blower box with no motor $20, , outer gas door $10, cigarette lighter complete unit $25, dash Temp knob $10 336-749-5922 leave message. for much quicker reply my direct email: jerrybev1@yahoo.com
sincerely
Jerry whitfield
winston salem NC
Edited by jerrybev 2022-03-10 7:25 PM
