325in dodge 3 groove lower pulley interchange?
tailfins
Posted 2022-08-11 8:47 PM (#623507)
Subject: 325in dodge 3 groove lower pulley interchange?
1000500100100252525
i need to find one for my 57 project...what other years, engines use the same one?
thanks
Posted 2022-08-11 9:10 PM (#623509 - in reply to #623507)
Subject: Re: 325in dodge 3 groove lower pulley interchange?
5000200020005001002525
Depends on if you have the dampener or not. I recommend that you use one regardless. If you choose to use a dampener from a 340, and mark it appropriately, then you could use more readily available pulleys from later years.
Edited by Powerflite 2022-08-11 9:13 PM
Posted 2022-08-11 9:21 PM (#623510 - in reply to #623507)
Subject: RE: 325in dodge 3 groove lower pulley interchange?
500020002000500100100100100
tailfins - 2022-08-11 5:47 PM
Which 57? There are a few 3 groove pulleys listed.
tailfins
Posted 2022-08-12 11:21 AM (#623517 - in reply to #623507)
1000500100100252525
325" hemi
Posted 2022-08-12 7:28 PM (#623524 - in reply to #623517)
tailfins - 2022-08-12 8:21 AM
325" hemi
Okay so 57 D500 which would have a harmonic balancer front crank pulley.
From the parts book, there were no 3 groove pulleys for a 57 Dodge. Only 2 groove.
Even with A/C, as per one of JohnS's D500s, there were only 2 groove. See below.
(I could be wrong but that is what I see in my files)
Edited by 56D500boy 2022-08-12 7:32 PM
(55-58ThreeGroovePulleyPNs.jpg)
(JohnSchuttes57RoyalD500Sedan_EngineBay.jpg)
Attachments 55-58ThreeGroovePulleyPNs.jpg (160KB - 66 downloads)
Attachments JohnSchuttes57RoyalD500Sedan_EngineBay.jpg (115KB - 66 downloads)
dels56
Posted 2022-08-13 10:27 AM (#623532 - in reply to #623507)
1001001002525
1958 Chrysler Windsor 325 Poly owned by a fellow here in BC has a 3 groove pulley on the water pump and a 2 groove on the crankshaft.
(20220723_102454.jpg)
Attachments 20220723_102454.jpg (50KB - 69 downloads)
wayfarer
Posted 2022-08-17 1:13 PM (#623591 - in reply to #623507)
500100100100252525
Our usual solution to most pulley related issues is to use a new LA dampener (rebroached keyway) and post-62 sheaves. It is not difficult to
trim off one or more un-needed grooves or trim to match the w/p sheave. Sometimes a spacer behind either top or bottom is needed for alignment.
