OIL filter/change 56 desoto 330 Hemi Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
NYFDX |
Regular Posts: 62 Location: NY | Any tips on the best way to change oil on a 56 desoto with a 330 Hemi? Issue is leaking around the stock (medieval) oil filter, can’t get it to stop. Tried 3-4 times now. Also tried a few aftermarket spin on adapters (Hot head hemi, etc) and none of them fit or have filter clearance from the motor. Just can’t get a good seal on the canister. Thanks | ||
Expert 5K+ Posts: 9902 Location: Lower Mainland BC | . I presume that your canister shell is not nicked or warped and that you have a new gasket for the bottom of the external canister where is contacts the OE filter adapter? I installed a Hot Heads spin-on adapter and a WIX filter with only a few minor issues: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=73721&... Edited by 56D500boy 2022-09-10 3:12 PM | ||
NYFDX |
Regular Posts: 62 Location: NY | Thanks 56D. Gasket seems to be installed correctly. Upon further inspection it appears to be leaking from the top part of shell where the bolt goes. I have a bronze washer between the bolt and shell and will double check the fit. Not enough clearance on my motor for the hot heads adapter but I will check out the thread. | ||
Expert 5K+ Posts: 9666 Location: So. Cal | Usually the 30 degree upward angled adapter fits without issue in our cars. | ||
Expert 5K+ Posts: 9902 Location: Lower Mainland BC | Powerflite - 2022-09-10 7:43 PM Usually the 30 degree upward angled adapter fits without issue in our cars. That is what I used. Works. Next oil change I am going to try a WIX 51515 (about 5" tall compared to the 51085 (about 4" tall) that I used) | ||
NYFDX |
Regular Posts: 62 Location: NY | Any idea where I can get a replacement shell and washer that goes between the bolt and shell? | ||
mstrug |
Expert 5K+ Posts: 6500 Location: Newark, Texas (Fort Worth) | https://marinepartssource.com/fiber-gasket-bolt-to-housing-chrysler-... | ||
ToMopar |
Elite Veteran Posts: 1159 Location: D-70199 Heslach | And where to get the 30° adapter for the 341 | ||
Expert 5K+ Posts: 9902 Location: Lower Mainland BC | ToMopar - 2022-09-12 3:46 AM. .And where to get the 30° adapter for the 341 Umm... Hot Hemi Heads, P/N 21002 https://www.hothemiheads.com/desoto/oiling_system/oil_filter_adapter... "(Modifications required for some DeSoto)" Talk to them: Hot Heads Research & Racing, Inc. 392 Walker's Hollow Trail Lowgap, NC 27024 Phone: (336) 352-4866 Fax: (336) 352-3892 E-mail: info@HotHemiHeads.com | ||
Richbo |
Veteran Posts: 242 Location: 33844 | My adapters have the filter straight out , if this helps. Found them on ebay years ago. | ||
Mopar1 |
Expert Posts: 3033 Location: N.W. Fla. | Richbo - 2022-09-25 9:33 AM typically you need the OEM up angle one HH sells to clear the torsion bars on those with them.My adapters have the filter straight out , if this helps. Found them on ebay years ago. | ||
