57-59 Wagon Rear Dome Light Wiring Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
FINS! |
Elite Veteran Posts: 943 | Have a '57 Dodge Suburban, I took out the rear dome light (above the 3rd row seat) many months ago to have the headliner done. Headliner is done and now I have forgotten how it's supposed to be wired.... Have 5 wires. Can anyone help? Shop manual doesn't show and no, it's not obvious from looking at it.... | ||
Expert 5K+ Posts: 9899 Location: Lower Mainland BC | . From page 79 in the 57 Dodge FSM: (57DodgeLampsAndSwithchesWiringDiagramFig7.jpg) (57DodgeLampsAndSwithchesWiringDiagramWagonDomeLight.jpg) Attachments ---------------- 57DodgeLampsAndSwithchesWiringDiagramFig7.jpg (105KB - 77 downloads) 57DodgeLampsAndSwithchesWiringDiagramWagonDomeLight.jpg (120KB - 74 downloads) | ||
Expert 5K+ Posts: 9650 Location: So. Cal | There is only one wire associated with the dome light, and on my cars is a pink color - check your FSM to verify. I suspect that the others route to the interior tailgate switch, that was used on a 9 passenger wagon. | ||
FINS! |
Elite Veteran Posts: 943 | No to the switch, it's wired and fully functional. I would think 1 wire is a ground, two to bulb and one to on/off switch? | ||
Expert 5K+ Posts: 9899 Location: Lower Mainland BC | . Based on the diagram that I posted (and repeated below), there would appear to be one hot (always Powered) wire to the rear most wagon dome light and one switch. I presume that the ground is through the frame of the dome light as it is screwed to a cross bar in the roof structure. One wire in. None out. It will be hot when the battery is connected. | ||
ToMopar |
Elite Veteran Posts: 1157 Location: D-70199 Heslach | On my wagon I use different to the upper wiring and different to recommondation all 4 door switches to switch on all the both dome lights & map light. Additional to this I have on map light switch and two dome light switches where I am able to switch on the dome lamps & map light too. If you need a picture of the dome lamp wires, let me know | ||
FINS! |
Elite Veteran Posts: 943 | Yes a photo would be very helpful. I'll post photos below of what the wiring looks like that I have. The shop manual diagram doesn't show it | ||
ToMopar |
Elite Veteran Posts: 1157 Location: D-70199 Heslach | Here are the picture of my domelamp wiring (1681a.jpg) Attachments ---------------- 1681a.jpg (92KB - 65 downloads) | ||
ToMopar |
Elite Veteran Posts: 1157 Location: D-70199 Heslach | And here is my "personal" wiring (Rear & Dome Lamp V07.jpg) Attachments ---------------- Rear & Dome Lamp V07.jpg (113KB - 69 downloads) | ||
FINS! |
Elite Veteran Posts: 943 | Ahh that looks more like mine, that really helps! (1957 dodge dome light.jpg) Attachments ---------------- 1957 dodge dome light.jpg (62KB - 62 downloads) | ||
FINS! |
Elite Veteran Posts: 943 | You're wiring diagram is great, the factory one is really poor, I'm going to print that one and laminate it to use. That ground screw goes to the dome light body itself? | ||
ToMopar |
Elite Veteran Posts: 1157 Location: D-70199 Heslach | Thanks, Garrett - I made the rear wiring by myself,- and that includes a wiring diagram too. It helps me afterwards to find (remember) all the wire colors, and so on......The left lower square in the wiring diagram is the plug behind kick panel But remember, MY wiring is differnt to OEM specification BTW,- the black ground wire goes/comes from the B-post. | ||
FINS! |
Elite Veteran Posts: 943 | That ground wire screws to the dome light housing correct? Do you know where I can get a new socket to replace the one in the dome light? Thanks | ||
Darryl T |
Extreme Veteran Posts: 427 Location: McCleary WA | FINS! - 2022-12-26 12:21 PM Do you know where I can get a new socket to replace the one in the dome light? Thanks Dorman 84738 dome light socket. I got mine from R and J Automotive, 39a Shelter Rock Rd, Danbury CT 06810, item #191553969, on ebay for $8.37 with free shipping. I used a generic grommet to hold it in place. | ||
FINS! |
Elite Veteran Posts: 943 | Thanks! | ||
