Door Jamb Switches 1957-59
FINS!
Posted 2023-01-09 4:25 PM (#626831)
Subject: Door Jamb Switches 1957-59
50010010010010025
Are reproduction door jamb switches available? This is for a 57 Dodge
Posted 2023-01-09 5:03 PM (#626832 - in reply to #626831)
Subject: Re: Door Jamb Switches 1957-59
500020002000500100
You can get them from Rockauto for about $10 each. They used to be a lot cheaper than that, but I guess you only need at most 4 of them.
FINS!
Posted 2023-01-12 11:28 AM (#626889 - in reply to #626831)
Subject: RE: Door Jamb Switches 1957-59
50010010010010025
Those look a little different than the original ones, I didn't know if they would work, thanks!
Posted 2023-01-12 12:03 PM (#626893 - in reply to #626831)
5000200020005001001001002525
Here are a couple of options:
https://www.moparmall.com/MoPar-PN-1971931-2770849-2822592-Dome-Ligh...
https://www.moparmall.com/MoPar-1571542-Plunger-Switch-p/838-203.htm
https://www.amazon.ca/Standard-Motor-Products-DS240-Switch/dp/B000C7...
