I previously (like 6 years ago) posted about a 315 D500 engine intake valve push rod that had issues. I've always wanted to replace that push rod. Recently I called out to a forum member who was generous enough to provide me with three 315 intake valve push rods to choose the best one from and install it in my engine. These arrived on Tuesday. (Thanks Dave N.)
Since then I have 1. soaked them overnight in solvent, 2. wiped them off, 3. put them in Rust Check brand Rust Wash overnight, 4. Brass-wire brushed them off, 5. Put them back in the Rust Wash for another overnight, and 6. Pulled them out and cleaned them with the Scotch Brite pad. In doing so, I now can see how the cone/socket female upper tip and round male tip were attached to the push rod tube (I am guessing silver solder). (A bit better than the red loctite that I used to "fix" that one 6 years ago).
All three roll nicely on a flat counter top. Two are better than the third (a bit of uneven noise but no visible bends). One of those two will go in the engine.
Thanks Dave N.
The process so far:
Edited by 56D500boy 2023-02-11 11:00 AM
(ThreeUsed56D500IntakeValvePushRodsAsReceived.jpg)
(ThreeUsed56D500IntakeValvePushRodsAfterASoakInSolvent.jpg)
(ThreeUsed56D500IntakeValvePushRodsSoakingInRustCheckRustWash.jpg)
(ThreeUsed56D500IntakeValvePushRodsAfterSoakingInRustCheckRustWashAndCleanedWithScotchBrite.jpg)
(ThreeUsed56D500IntakeValvePushRodsAfterSoakingInRustCheckRustWashAndCleanedWithScotchBrite_ConeAndTipAttachmentDetails.jpg)
Attachments ---------------- ThreeUsed56D500IntakeValvePushRodsAsReceived.jpg (147KB - 45 downloads) ThreeUsed56D500IntakeValvePushRodsAfterASoakInSolvent.jpg (148KB - 49 downloads) ThreeUsed56D500IntakeValvePushRodsSoakingInRustCheckRustWash.jpg (149KB - 48 downloads) ThreeUsed56D500IntakeValvePushRodsAfterSoakingInRustCheckRustWashAndCleanedWithScotchBrite.jpg (145KB - 47 downloads) ThreeUsed56D500IntakeValvePushRodsAfterSoakingInRustCheckRustWashAndCleanedWithScotchBrite_ConeAndTipAttachmentDetails.jpg (149KB - 41 downloads)
Location: Buena Park, CA | Happy I could help! Nice work here. |
Location: Palm Beach County Florida | Dave, how do you find time to research, design, take pictures and post all these topics. I can barely keep up just reading about all your projects. |
Location: Lower Mainland BC | JedRhule - 2023-02-13 5:21 PM
Easy. I don't have a life
(Actually, I really like making posts that help me (and maybe others) learn about their mid-50's Mopars, in my case a 56 Dodge)
Also there is a chance that I suffer from Adult onset ADHD.
Edited by 56D500boy 2023-02-14 11:21 PM
