PVC Conversion question Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
56newyorler07 |
New User Posts: 4 | 56 New Yorker w/ stock 354 Hemi - would like to convert to a PVC setup using Hot Heads P/N 29194 on the stock valley pan to replace the road draft setup and a set of breathers P/N 80506 on the valve covers. My question is do I need to do anything different with the oil fill tube cap which is the stock type breather cap? Thanks for the help. | ||
PolyJ |
Veteran Posts: 143 Location: Denver, Colorado, USA | This must be the year of PCV systems since I just got done commenting in another forum about converting to PCV. | ||
Expert Posts: 3776 Location: NorCal | I've always been leery of just drilling a hole in the VC's or valley cover and popping in a grommet to hold the PCV valve. Most factory installations using that setup have a baffle beneath the hole to prevent thrown-off oil from being sucked directly into the valve opening. | ||
56newyorler07 |
New User Posts: 4 | Thanks for the insights. I appreciate the help! | ||
Mopar1 |
Expert Posts: 3033 Location: N.W. Fla. | 57chizler - 2023-06-01 11:32 AM No direct route using the OEM valley cover. I replaced the steel wool looking stuff in the oil fill cap with a cut down lawn mower air cleaner, & ran the PCV hose up to the Edelbrock carb.Most factory installations using that setup have a baffle beneath the hole to prevent thrown-off oil from being sucked directly into the valve opening. | ||
samstrader |
Extreme Veteran Posts: 443 Location: Beaumont TX | http://www.forwardlook.net/forums/forums/thread-view.asp?tid=78257&... Look at this link. 56d500boy has been working on this conversion and there are a lot of thoughts on how to make the conversion and design issues discussed and explained. This is a good place to start for you car since Dave is making a conversion on a 56 dodge also. | ||
