PolyJ![]() |
Veteran Posts: 146 ![]() ![]() Location: Denver, Colorado, USA | I'm wrapping up compiling a database of Powerflite and A466 transmission ID numbers and notes and have a few numbers I found in manuals but without notes on the model of transmission and one without engines. I don't know if they are PowerFlite, A466, aluminum A904 (6-cylinder for 1960 - 1961) or standards. I place my specific questions at the end of each entry. Does anyone have documentation that answers the questions? Both digging through manuals and internet searches don't turn up anything. 2124725: 1960, 6 cylinder, Dodge, Plymouth after Serial P22118 (What transmission model? It could be an aluminum TF A904) 2125075: 1960, 6-cylinder, Dodge Dart, Plymouth (What transmission model? It could be an aluminum TF A904) 2229614: Late-1961 Truck, A466 LoadFlite (Did this transmission come behind both V8 and 6 or just V8)? Edited by PolyJ 2023-08-01 4:31 PM | ||
56D500boy![]() |
Exner Expert 10K+ Posts: 10546 ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Justin: As I think you know, the first two numbers you presented above were for six cylinder cars. With the introduction of the 6 cylinder Valiant in 1960 and its use of the Aluminum-cased 904, I would venture a guess that those PN numbers are for early 904s. Edited by 56D500boy 2023-08-01 5:11 PM (1960MoparTorqueflitePNs.jpg) Attachments ---------------- ![]() | ||
PolyJ![]() |
Veteran Posts: 146 ![]() ![]() Location: Denver, Colorado, USA | Thanks Dave, and I too lean strongly toward the A904. The 1960's parts manual you show is where I found the two numbers, but I cannot find them in multiple aluminum TorqueFlite manuals I have. The fact that, according to the parts manual, they apply only to Dodge and Plymouth with a 6 cylinder makes the case for an A904 since the A904 was offered only in the 1960 - 1961 Dodge Dart and Plymouth Valiant with Slant 6. Full-size Dodge and Plymouth didn't use the Slant 6 to my knowledge and continued using either the PowerFlite or A466 behind V8s. The remaining variable is that 1960 Dodge trucks offered the old L-head 6 backed with at least the PowerFlite and possibly the A466, but the 1961 Dodge truck used the Slant 6. Deduction says if the two transmissions under discussion fit a Plymouth with a 6 cylinder, said 6 cylinder is the Slant 6 which makes the transmissions the A904. It would be nice to see that spelled out somewhere, so maybe I should be content now that I spelled it out
As for the 2229614 LoadFlite, I've reached a similar conclusion in that, to my knowledge, the only 6-cylinder offered in any Chrysler Corporation car or truck in 1961 was the Slant 6 family. Any automatic transmission, therefore, would be the A904, so the A466 at question would have gone behind only V8s that year. All the photos I've found of a 1961 truck with a V8 and automatic also have a three-speed shifter.
Powerflite![]() |
Exner Expert 10K+ Posts: 10171 ![]() ![]() ![]() ![]() ![]() Location: So. Cal | PolyJ - 2023-08-01 7:50 PM ...The fact that, according to the parts manual, they apply only to Dodge and Plymouth with a 6 cylinder makes the case for an A904 since the A904 was offered only in the 1960 - 1961 Dodge Dart and Plymouth Valiant with Slant 6. Full-size Dodge and Plymouth didn't use the Slant 6 to my knowledge and continued using either the PowerFlite or A466 behind V8s... I'm pretty sure that it's a false conclusion to think that the slant six didn't come in the full size Plymouth. In fact, here is an example of one: https://barnfinds.com/finned-4-door-1960-plymouth-savoy/ I'm not sure about the full size Dodge, but I would think that was the no-option base line for the full size Dart as well. Remember that the '60-'61 Dart was intermediate or full size, not compact. Also, I would presume that any automatic transmissoin that went behind a slant six had to be the A904, as you have presumed. I assume that trucks would have used heavy duty versions, or maybe stick shift transmissions only. Edited by Powerflite 2023-08-02 12:20 AM | ||
56D500boy![]() |
Exner Expert 10K+ Posts: 10546 ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . I'm just going to drop these and then run away and hide (behind a rock or a tree). Note: What we call the "904" now was called the "TorqueFlite Six" back then. Edited by 56D500boy 2023-08-02 2:29 AM (60DodgeDartTransmissionOptions.jpg) (60PlymouthTransmissionOptions.jpg) Attachments ---------------- ![]() ![]() | ||
