1961 Chrysler Windsor vibration and almost stalling problem
Arocket111
Posted 2024-07-10 7:31 AM (#636090)
Subject: 1961 Chrysler Windsor vibration and almost stalling problem
Hi all just an up date on my previous thread what I thought was a gearbox problem / then a brake booster issue causing the engine to almost stall when stopping or parked with foot on the brake , after some great help from John (57 Chisler) and David (56D500boy) I found the mechanical fuel pump failing to be the cause of the problem , I fitted a temporary tank and electric fuel pump and the car is running like a clock again .
So I am fitting an electric fuel pump near the fuel tank and an in line pressure regulator under the bonnet
Thanks again for the great help received Phil
Posted 2024-07-10 11:22 AM (#636095 - in reply to #636090)
Subject: Re: 1961 Chrysler Windsor vibration and almost stalling problem
5000500025
In general, it's best to put the update with the original post so people can find it later. Having a separate post isn't going to be helpful to people later on.
