1956 Chrysler 300 Spark Plug Wires
rexc
Posted 2024-09-19 9:01 AM (#637056)
Subject: 1956 Chrysler 300 Spark Plug Wires
Dear Members,
A friend of mine is working on a very dilapidated '56 Chrysler 300, which needs a set of spark plug wires for a customer. At the moment the car is barely running with lots more work of all kinds to be done. Is it worthy buying the correct wires with insulators, or are there wires that will work just as well in the hemi motor? I see wires offered with the shorter insulators, but they look like they might be hard to deal with. Can someone point me in the right direction? Thanks, REx
Posted 2024-09-19 9:59 AM (#637057 - in reply to #637056)
Subject: RE: 1956 Chrysler 300 Spark Plug Wires
50005000100100100252525
I have a 56 Dodge D500 with the 260 hp 315 cu in "baby hemi" (double rocker) engine. I have been through this a few times.
Complete sets of OE style wires and plastic insulators are available from Mopar Mall:
https://www.moparmall.com/SearchResults.asp?Search=hemi+spark+plug+w...
and specifically
https://www.moparmall.com/MoPar-1450091-1752311-Hemi-Spark-Plug-Wire...
I have researched the insulator tubes and documented the research:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=79192&...
There are also sets of insulators, new and used, on eBay:
New:
https://www.ebay.com/itm/182855164934?
Used:
https://www.ebay.com/itm/326085286783?
HOWEVER, although the used sets are less expensive, they are all old plastic(ish) things and are fragile, as I discovered:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=79191&...
Personally, I would go for the complete set of wires and insulators as Plan A with Plan B being just new insulators and then making my own wire set.
Regardless, I , personally, would keep the 56 OE look and avoid using modern 426 hemi style sets.
Hope that helps
rexc
Posted 2024-09-19 2:06 PM (#637061 - in reply to #637057)
Thanks so much for this reply. Based on your research and generosity in sharing your knowledge, we have moved forward and purchased at new set from the source indicated. Rex
Posted 2024-09-19 2:32 PM (#637062 - in reply to #637056)
Subject: Re: 1956 Chrysler 300 Spark Plug Wires
50005000252525
I usually buy cheap big block Chevy wires with the tight straight boots on them. Then slip my Taylor plastic insulators over them. If I have the old boots, I'll buy any old wire set and swap the boots over with the insulators.
