Location: upstate new york | Hey Forward Lookers, What are these officially called and where can I get replacements? Oil pressure line?
Thanks,
billy
(IMG_9078.JPG)
Attachments ---------------- IMG_9078.JPG (162KB - 34 downloads)
Location: So. Cal | Do you have original A/C? The original air conditioning compressor had an oil line to them.
The best way to replace them is to take them to a good, preferably old, hose shop and have them make up new ones for you. |
Location: upstate new york | NYer does have original A/C...will do on the hose shop...just have to find the other ends of now...:) thanks for your help |
The HVAC recirculating door power piston is actuated by engine oil pressure tapped from the same source as the oil pressure gauge and is then returned to the oil pan.
(pp.PNG)
Attachments ---------------- pp.PNG (26KB - 34 downloads)
Location: So. Cal | That looks like a nightmare. One leak and you lose your engine and make a complete mess. |
My '57 300C had factory A/C and that cylinder leaked...positioned right above the gas pedal, it would drip on my foot. This was the early seventies and no replacement could be found, so I fabricated a sheet metal tray under it to funnel the leakage out through the firewall. |
Location: Finland | That was refreshing to read! I liked the funnel/tray...real seventies attitude... |
Location: Western Colorado | One nice thing was that the oil leak helped keep the drivers side floorboard from rusting. lol |
