T/S canceller
Stroller
Posted 2025-01-01 10:39 AM (#638424)
Subject: T/S canceller
100100100252525
Ok here is a weird something I need or an idea of how to fix. My '60 Fury Steering wheel. I would love to get what I need. It is the turn signal cancelling ring that is sort of pressed onto the steering wheel hub with the little bent out tab.
If anyone has successfully repaired this little do day please let me know how. Mine broke off right at the bend. I found some propane heat and a utility knife can get the ring off.
Anyone?
Posted 2025-01-01 3:48 PM (#638425 - in reply to #638424)
Subject: Re: T/S canceller
50005000500
I believe that ring is made from steel, so you should be able to weld it to fix it. Heat it up before pressing it back onto the wheel. But fixing that rubber seal for the horn contact is really difficult. Fortunately there are still some NOS parts for '60-'64?, but nothing for the '57-'59.
Posted 2025-01-01 4:44 PM (#638426 - in reply to #638425)
5000500010001002525
I agree that they are stamped steel. In the parts book they are called
"FINGER, Directional Signal Switch Cancelling"
In 1955-56 the PN was 1595 235 and it made no difference whether the steering was manual or Power-assisted.
From 1957 to at least 1959, the cancelling ring had two different PNs, one for PS and one for Manual
PS = 1769 326
Manual steering = 1769 325
Use 1769325 or 1769326 (no spaces) when searching.
Len Dawson Mopar Parts has a 1769325 for the Manual Steering cars
http://www.dpmotorparts.com/inventory_4_b.cfm
REFERENCE: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=69539&...
Stroller
Posted 2025-01-05 11:01 AM (#638467 - in reply to #638424)
100100100252525
Well I tried silver solder and nada. Managed to get it clamped so I can hit with a spot weld. See if that works. Thanks everyone.
Stroller
Posted 2025-01-08 10:43 AM (#638541 - in reply to #638424)
100100100252525
Well been trying to get ahold of that Len guy but no luck yet.
Posted 2025-01-08 2:44 PM (#638545 - in reply to #638541)
5000500010001002525
Stroller - 2025-01-08 7:43 AM
Well been trying to get a hold of that Len guy but no luck yet.
Three ways to contact Len Dawson:
Ordering Information"?
By Mail: 15541 Yokeko Drive, Anacortes, WA 98221
By Voice Mail: (360) 708-7329 - Len is hard of hearing; speak SLOWLY AND CLEARLY, furnish your email address, and don't get old!
By E-Mail: hilltownyankee@hotmail.com.
When using email to place orders show "MOPAR" on the subject line.
http://www.dpmotorparts.com/how_to_access_3.cfm
JJG1214
Posted 2025-05-30 6:22 PM (#640250 - in reply to #638424)
Anyone out there know why there is a different T/S canceller part for power steering?
It seems that the manual T/S canceller (P/N 1769325) would work fine with a PS turn signal switch.
I understand that the PS cars need the horn contact and ring parts to route the horn wiring.
But the rest of the turn signal switch looks to be the same for manual and PS cars.
It doesn't look like the manual T/S canceller would interfere with the horn contact, so shouldn't it
work with a PS turn signal switch?
The reason I ask, is that I'm in the process of switching over to PS and can't find a PS canceller (P/N 1769326).
I have the manual T/S canceller, horn contact and ring.
Posted 2025-05-30 7:20 PM (#640252 - in reply to #640250)
5000500010001002525
I can't find an image of either the 1769 326 or the 1769 325 cancelling rings but I am wondering whether the difference is the diameter of the inner "hole"
being different between the manual and the PS steering columns. (???)
JJG1214
Posted 2025-05-31 8:40 AM (#640258 - in reply to #638424)
I'm thinking that the PS version is the one shown in the picture next to the horn contact ring, since the horn contact ring is only used with PS.
I know what the manual cancelling ring looks like, since I have one and it is easy to find online. I'll try to post a picture of it.
(Turn Signal Canceling Finger - Manual Steering - side 1.jpg)
(Turn Signal Canceling Finger - Manual Steering - side 2.jpg)
Attachments Turn Signal Canceling Finger - Manual Steering - side 1.jpg (22KB - 254 downloads)
Attachments Turn Signal Canceling Finger - Manual Steering - side 2.jpg (32KB - 305 downloads)
Posted 2025-05-31 1:56 PM (#640266 - in reply to #640258)
5000500010001002525
John: Based on your comment the manual one was easy to find online, I searched on
"1769325 1957 Mopar signal light turn signal cancelling ring'
and found a couple including this:
https://www.ebay.ca/p/15051320796?iid=186850024760&fitmentTarget=Yea...
I then repeated that search but with 1769326:
"1769326 1957 Mopar signal light turn signal cancelling ring"
and got, as you already know, Bupkis.
Not even anything at Hiltop Mopar or Mopar Mall
https://hiltopautoparts.com/?s=1769326&post_type=product
https://www.moparmall.com/SearchResults.asp?Search=1769326&Submit=
However, the search did show up this:
https://www.robertsmotorparts.com/turn-signal-switch-1957-1958-plymo...
Close (LOL) but no ceegar
JJG1214
Posted 2025-06-01 9:58 AM (#640272 - in reply to #638424)
Well, I went ahead and installed the Manual T/S cancelling ring on my PS wheel yesterday.
Everything seems to work fine - turn signals cancel and horn works!
Still a mystery why the other PS part looks like or why it even exists?
