1957 savoy manual steering gear box
Blast
Posted 2025-09-12 1:23 PM (#641410)
Subject: 1957 savoy manual steering gear box
Does the 1957 Chrysler Windsor and Saratoga have the same manual gear box as the 1957 Plymouth Savoy?
Are they interchangable and will it work correctly
wheelcover
Posted 2025-11-24 7:40 PM (#642098 - in reply to #641410)
Subject: RE: 1957 savoy manual steering gear box
1002525
I can check part numbers when I get back to my parts book, but I would think that the Chrysler Windsor and Plymouth Savoy manual steering boxes are the same. I would assume the Saratoga would also be the same, but as it is on the larger chassis, there could be a change in part number. If I knew why you were asking, I might be able to answer the question better.
Posted 2025-11-24 11:43 PM (#642100 - in reply to #641410)
Subject: Re: 1957 savoy manual steering gear box
500050001001001001002525
The larger wheelbase cars won't work on it. They are longer. But the '58-'59 Windsor and '57-'59 Firesweep should work since they are small wheel base cars. The Saratoga won't work and neither will the '57 Windsor. They're longer like the New Yorker.
w.weiland
Posted 2025-11-26 5:03 PM (#642112 - in reply to #641410)
10005002525
if a 57 dodge is the same i have a rebuilt one for sale
