V8 Motor Mount Option
dels56
Posted 2025-10-26 7:21 PM (#641803)
Subject: V8 Motor Mount Option
100100100100252525
I did not dream this up myself. I saw where a fellow had already fixed his broken motor mount using the EN-1026 mounts for a 56 Chrysler & Desoto. I cannot remember where I saw it. I just thought I should relay the info and show how it turned out after a bit of work. The hardest part is removing the old rubber that was still attached to the metal. I carved most of the rubber off the metal with an old wood chisel, then a wire wheel in a cordless drill, and using acetone to clean the bits off. If I could remember where I saw the post I would thank he or she for leading the way.
Del
Edited by dels56 2025-10-26 7:31 PM
(Motor Mounts 2.jpg)
Attachments Motor Mounts 2.jpg (167KB - 130 downloads)
Posted 2025-11-01 10:11 AM (#641847 - in reply to #641803)
Subject: Re: V8 Motor Mount Option
5000500050025
Once you cut most of the rubber off, just fire up the wood fire grill and throw them in - after you cook your dinner, of course.
(57NY Couch Spot.jpg)
Attachments 57NY Couch Spot.jpg (178KB - 193 downloads)
dels56
Posted 2025-11-04 9:42 PM (#641863 - in reply to #641803)
100100100100252525
That would certainly work, if you like the smell of burning rubber from other than you rear tires.
Del
