60 Dodge Dart steering gear question
Todd
Posted 2025-11-10 9:57 AM (#641939)
Subject: 60 Dodge Dart steering gear question
1002525
Hello everyone.
I'm currently working on the steering gear. Does it come out in one piece with the steering tube? I can't find a coupling anywhere. Thank you in advance for your reply.
geoffs60
Posted 2025-11-10 1:52 PM (#641943 - in reply to #641939)
Subject: RE: 60 Dodge Dart steering gear question
100100
If its an Auto car, then it has the one piece S/box with shaft to the wheel, if manual then the column is separate from the S/Box and has a coupling.
Geoff
Todd
Posted 2025-11-11 12:50 PM (#641958 - in reply to #641939)
Subject: Re: 60 Dodge Dart steering gear question
1002525
Thank you so much, that helped me a lot!
Todd
Posted 2025-12-09 11:36 AM (#642244 - in reply to #641939)
Subject: Leaking steering gear
1002525
I removed the steering gear because it was leaking. It was leaking from the cover, through which the horn cable also runs.
So I removed it and first replaced the pitman shaft seal. I checked the shims; everything was okay. Two of the screw threads also go into the oil chamber, so I wrapped the screws with Teflon tape and tightened everything back up.
I should mention that because of the leak, I had previously used a thicker fluid. Now, however, I filled it with SAE 90 oil.
I let the assembled steering gear sit with the oil in it for 3-4 days – no leaks! So I reinstalled it. Now, after two weeks, there's oil under the car again.
I was able to determine that the oil is leaking again from the bottom through the shims, even though they're tightened completely. Is this a known problem? Does anyone have any advice?
Edited by Todd 2025-12-09 11:39 AM
Todd
Posted 2026-01-16 12:01 PM (#642639 - in reply to #641939)
1002525
Hey folks.
The seal I'm looking for is marked in red in the picture. Is the Timken (National 340797) the right part?
Edited by Todd 2026-01-16 12:06 PM
(Screenshot 2026-01-16 175118.jpg)
Attachments Screenshot 2026-01-16 175118.jpg (143KB - 1 downloads)
