Brake line size
Shep
Posted 2025-11-19 9:55 AM (#642009)
Subject: Brake line size
20001000100100100100252525
On a 59 Dodge Coronet, what size is the brake line from the master cylinder to the Junction on the frame rail? Thanks, Shep
Posted 2025-11-19 10:17 AM (#642010 - in reply to #642009)
Subject: Re: Brake line size
500050001001001001002525
They use a hose to go from the master cylinder to the junction block. At the junction block, the connection is the same as is used on a standard 1/4" tube nut. The actual thread is 7/16"-24 on those. So if you are replacing that with a solid line, I recommend using a 3/16" line, but with a 7/16"-24 tube nut.
Edited by Powerflite 2025-11-19 3:48 PM
Mopar1
Posted 2025-11-20 9:13 AM (#642018 - in reply to #642010)
200010001002525
Hose is used because of possible flex between the body & frame may eventually cause a hard line to break.....
Shep
Posted 2025-11-20 9:30 AM (#642019 - in reply to #642018)
Helping friend over the phone, he's converting to a dual master, with 2 3/16 line ports, will that size fit into the hose junction.
Posted 2025-11-20 10:06 AM (#642020 - in reply to #642009)
Yes, as I stated before. However, the standard 3/16 tube nuts won't work in it. Standard 3/16 tube nuts are 3/8" - 24. But that junction block is 7/16"- 24. So you need to purchase those larger sized nuts to make it work.
Shep
Posted 2025-11-20 10:55 AM (#642021 - in reply to #642020)
Yeh, thought so. Thanks
dels56
Posted 2025-11-20 12:27 PM (#642023 - in reply to #642009)
Take a look at “agscompany.com”. Their website will give you a complete list of brake line fittings and thread sizes. Typically the 3/16 brake line uses an inverted flare fitting. As Powerflite stated there is a 3/8 and a 7/16 thread sizes used.
Del S
Shep
Posted 2025-11-20 3:30 PM (#642033 - in reply to #642023)
Thanks, found it this am, good stuff, Napa doesn't know anything, their answer is go look thru the bins!
