Other fuel pump options for 1957 Dodge 325 Poly
MoparMike
Posted 2026-01-10 12:56 PM (#642564)
Subject: Other fuel pump options for 1957 Dodge 325 Poly
Has anyone figured out another fuel pump option for a '57 Dodge 325 Poly? I'm only asking because I'm planning a long trip in the car for June, and the fuel pump really is my only concern. Not that it's failing, but if it does, I know I won't be buying one off the shelf at the parts store.
I realize I can put in an electric pump in a pinch, but curious if anyone has discovered another mechanical fuel pump that works in that application? Or has uses an adapter plate, or something?
Posted 2026-01-10 11:28 PM (#642571 - in reply to #642564)
Subject: RE: Other fuel pump options for 1957 Dodge 325 Poly
500050001000100252525
Search ebay for 1752463 Plymouth fuel pump
https://www.ebay.com/sch/i.html?_nkw=1752463+Plymouth+fuel+pump&_sac...
Contact hot hemi heads regarding their adapters to use LA block fuel pumps
https://www.hothemiheads.com/cam_shafts_timing/fuel_pump_adapter.htm...
Carry an electric pump and fittings in the trunk?
wayfarer
Posted 2026-01-11 10:28 AM (#642573 - in reply to #642564)
Subject: Re: Other fuel pump options for 1957 Dodge 325 Poly
50010010010010025
The LA pump can be used on the Dodge and Chrysler with a ½" spacer. I have a couple left if you want one. $20 ppd
Mopar1
Posted 2026-01-11 11:16 AM (#642577 - in reply to #642564)
20001000100252525
There's been problems for 20 years with OEM F/Ps. As Gary ( "Wayfarer" i.e. QEC), & 56D500boy said, get the adaptor & be done with it. P.S. Gary is a great guy to work with! :-)
Posted 2026-01-11 11:26 AM (#642578 - in reply to #642577)
Mopar1 - 2026-01-11 8:16 AM
Agree. And for further background, have a read on this thread:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=80239&...
wayfarer
Posted 2026-01-17 3:10 PM (#642650 - in reply to #642564)
50010010010010025
George, thanks for the nod, much appreciated. Mike now has the last two spacers that I had.
MoparMike
Posted 2026-01-25 1:11 PM (#642744 - in reply to #642564)
Thanks for the info, and thanks Gary! I installed one spacer on the 325 in my '57 Dodge Royal. I had to grind the top of the spacer as well as the top of the fuel pump, but it's all plumbed in and pumping fuel. The other spacer is for a 354 Poly I put in my '58 Plymouth 2 door Suburban.
