Adjusting 56 D500 solid lifter valves and discovering a GOTCHAJump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
| Forward Look Technical Discussions -> Engine, Exhaust, Fuel and Ignition | Message format |
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Previously, in an older (2017) thread, while learning how to adjust my solid lifter V8, I said, 56D500boy - 2017-06-09 10:51 PM Today, I went with a TDC method, using a piece of dowel to give me a visual indicator of TDC as I rotated the engine with a 1.25" deep socket and my ratcheting torque wrench. I've done 1, 8 and 4 and had to quit for the day (to cook some ribs au BBQ). I had problems with No. 8 intake. It seems that the more I cranked the adjuster out, the less clearance I had - very strange. I decided to come back to it after I do the other ones. For adjusting I am using a 3/8" stubby rachet, a 3" extension and a 7/16" socket. I suspected that the No. 8 intake lifter was not a solid lifter but a hydraulic lifter that somehow had been installed when the engine was rebuilt (long before my ownership and before the car sat for about 25 years with only periodic starting). I adjusted that valve, based on suggestions, like it was a hydraulic lifter (even though I couldn't confirm that) by adjusting the clearance to zero lash at TDC on 8 plus 1/4 turn for preload. That seemed to work fine (enough) I ignored finding the problem for almost 9 years, until a week ago last Monday, when my otherwise faithful, 56 D500 double-rocker, without warning, started to "pop" (backfire on one cylinder) through the carburetor. Initially I thought that the problem was going to be with the Pertronix ignition that I had installed about 8 years ago. So I changed that but there was NO improvement. Thinking that the problem might be the No. 8 intake pushrod, I removed the valve cover (not easy on a double rocker ("hemi") and removed that push rod for inspection. It was fine (enough). I left the project overnight and when I went to put things back and re-adjust the No. 8 intake, I could not. Even with the adjuster fully out, there was about 1/4" between the push rod and the adjuster. My thoughts were: IT REALLY IS A HYDRAULIC LIFTER AND IT JUST COLLAPSED. No choice but to get in there and confirm the lifter was/is hydraulic and replace it with a NOS solid lifter that I had purchased from Martin K. at Arizona Mopar years ago. So I got into it yesterday AM. Started with removing the 2443S WCFB carburetor before moving on to removing the intake and valley cover. That was in the morning, after attending Planet Fitness with my healthy heart group. After lunch, I spent (wasted) at least 2 hours looking for the 12 point 1/2" socket that I know I had bought and used previously to pre-loosen the 16 intake to head bolts. After the 2 hours, I finally I gave up and went out to Lordco (think O'Reilly) and bought another socket (a 3/8" drive JET, 12 point). As soon as I saw it, I knew that I had been looking for the wrong thing (I remembered it to be a 1/2" 12 point and was looking in that area of my tool box). Found it immediately when I came home with the new one (in the 3/8" drive area of the box).. Got the passenger side intake bolts out no problem but 6 of the driver's side bolts didn't want to move. It was scary even though I knew that I had them out before (and sprayed them with WD-40 before I put them back in) they didn't want to budge. I had to use just about all my strength to slowly put pressure on them until, one by one, they let loose with a bit of a CRACK. But they were fine. Just stubborn. On the way I discovered (DUH) that the intake was NOT as dry as I had imaged. Probably 6 of the intake bolts on each side go through a coolant passage in the head, so as I loosened those bolts, I was getting coolant weepage at the intake-head interface. Solution: Tighten them back up, mop up the coolant ("BOUNTY -the Quicker Picker Upper" to the rescue.), open the pet**** at the bottom of the rad and drain a bunch of coolant into a pan (never to return to the engine). At the end of the day, yesterday, I had the intake off, sitting on top of my other (big tool rolling) tool box which lives on the passenger side of my very cramped 12 x 20 garage. I left the removal of the valley pan and the final discovery until this AM. (Too be truthful, while it was getting late, I was probably too chicken to discover if there was a disaster under the valley pan). SO this AM, after warming up the garage (0 deg C (32 F) out), I cleaned the top of the valley pan and around its edges. Removed the pan and set it aside. Reached it to feel for chunks in the area of the No. 8 intake lifter. IMMEDIATELY felt something and pulled it up. A little button with a concave depression. I knew immediately that it was from the top of a hydraulic lifter. Felt the No. 8 intake lifter and pushed it away from the cam lobe. Grabbed it as it came to the top of the lifter bore and pulled it out. Easy Peasy (Thanks Nathan). YUP nice shiny multi-piece hydraulic lifter. So, at this point, I don't know if the lifter button came out of the lifter by itself or it came out when I removed the push rod. It might have been pushed out by the internal lifter spring. I will never know. And I don't need to know. It might have been the popping problem or it might be a red herring. NOW I need to put it all back together, but this time, with a NOS solid lifter. I am actually NOT 100% CONFIDENT that the No. 8 intake lifter was the problem with the popping through the carb but I have no choice but to try to return things to "NORMAL" and see IF that was the problem. I might get lucky. OR NOT. BUT first, I have bunch of cleaning and painting (intake, valley pan, valve cover, etc) to do. Good thing that it snowed over night and there is no need to get the car running again this week. The NOS 1673 721 lifters that I had to make a choice regarding which one to install: Previous thread on the adjusters and the No. 8 intake "sponginess": http://www.forwardlook.net/forums/forums/thread-view.asp?tid=65759&... Photos of the No.8 push rods taken the other day, the lifter gallery (as found today, not cleaned up), one of the NOS solid lifters and what I pulled out of my engine this AM. Edited by 56D500boy 2026-03-10 7:03 PM (DaveFs56D500No8_IntakeAndExhaustPushRods_ExhaustMeasurement.jpg) (DaveFs56D500No8_IntakeAndExhaustPushRods_IntakeMeasurement.jpg) (DaveFs56D500LifterGallery_asFound.jpg) (56D500SolidLifterWithStrangeHydaulicLifter_ShowingLooseTopButton.jpg) (56D500SolidLifterWithStrangeHydaulicLifter_ShowingLifterCompoents.jpg) Attachments ---------------- DaveFs56D500No8_IntakeAndExhaustPushRods_ExhaustMeasurement.jpg (148KB - 260 downloads) DaveFs56D500No8_IntakeAndExhaustPushRods_IntakeMeasurement.jpg (139KB - 317 downloads) DaveFs56D500LifterGallery_asFound.jpg (209KB - 261 downloads) 56D500SolidLifterWithStrangeHydaulicLifter_ShowingLooseTopButton.jpg (143KB - 201 downloads) 56D500SolidLifterWithStrangeHydaulicLifter_ShowingLifterCompoents.jpg (102KB - 188 downloads) | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Think the Dude, big Lebowski. As usual, not willing to leave anything alone, I went back out to the garage to remove another intake lifter on the 2,4,6, 8 side. Chose no. 2 (somewhat at random). Backed off the adjuster. Pulled the push rod. (Same as the No. 8 intake push rod, except the tip is bigger for some reason) Then I pulled the lifter, fully expecting to see what an OE solid lifter looks like with some wear. NOPE!!! Another hydraulic lifter. What the HEYYY??? Now I think I get it. After looking at my photos of the lifter gallery, from what I can see they are all shiny chrome = hydraulic. So when the engine was rebuilt, I think they tossed all the solid lifters (not just one) and put in a set of hydraulic lifters. Probably to make the car less maintenance needy. My confusion now is how was I able to adjust the valves back in 2017 or 2018? I guess I just adjusted the hydraulic lifters loose. Missed out on some lift and performance - but at least they should have closed tight. Now that I see the No. 2 intake lifter and can see that there is a lifter piston retaining spring that No. 8 intake lifter is missing, I am more hopeful that when I get this sorted, the pop (backfire) might be gone. (Except where DID that retaining spring GO??) I presume that I will be able to use the information from Steve1956's lifter thread to track down a lifter for No. 8. (I am not going to do a full set). This: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=80275&... When I do get the lifter and adjust the valves, (after confirming all of the lifters are hydraulic), I guess I will follow the tight plus 1/4 turn protocol. My head hurts. Edited by 56D500boy 2026-03-10 8:42 PM (56D500SolidLifterWithStrangeHydaulicLifter_AndNo2IntakeLifter.jpg) (56D500SolidLifterWithStrangeHydaulicLifter_AndNo2IntakeLifter_Top.jpg) Attachments ---------------- 56D500SolidLifterWithStrangeHydaulicLifter_AndNo2IntakeLifter.jpg (84KB - 309 downloads) 56D500SolidLifterWithStrangeHydaulicLifter_AndNo2IntakeLifter_Top.jpg (89KB - 246 downloads) | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | 56D500boy - 2026-03-13 6:14 PM. Tomorrow I will figure out why the push rod is still stuck on the No. 6 intake rocker arm with the adjuster 100% out It wasn't stuck after all. I tilted the rocker away from the No.6 intake valve tip (just enough to clear the push rod tip) and "locked" (rested) the rocker beside the valve spring. Pulled the No.6 intake push rod. Pulled the No. 6 Intake lifter. The same as the No. 4 intake lifter, i.e. hydraulic. I have ordered a couple of Melling JB-812s from Rock Auto. Supposed to be here Wednesday. | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | 56D500boy - 2026-03-14 2:31 PM I have ordered a couple of Melling JB-812s from Rock Auto I don't know when Rock Auto stopped using FedEx but I am not liking their use of UPS. Twice now, even though the source is in the Western US, they are shipping to Louisville Kentucky before shipping to the wet (er..West Coast). Ordered Friday, got to Colorado yesterday and then Kentucky today. They are still saying delivery tomorrow. I won't hold my breath. In the meantime, I found some 2808 569 lifters that supposedly are the supersede from the 1555 nnn lifters. They are shorter than what I removed but the depth down to the lifter socket is still less deep than the 56 D500 solid lifter, as shown in the photo. Only 0.037 difference between what I took out and the depth of the 2808 569. I still have some clean up and painting (block and heads) before I need to install a lifter and button things up so I might just wait for the Melling JB-812s to show up. (Maybe) Edited by 56D500boy 2026-03-17 6:23 PM (56DodgeLifterComparison_EffectiveHeight_Annotated.jpg) Attachments ---------------- 56DodgeLifterComparison_EffectiveHeight_Annotated.jpg (147KB - 278 downloads) | ||
| dels56 |
Extreme Veteran Posts: 488 ![]() ![]() ![]() ![]() ![]() ![]() ![]() | My foggy memory of the hydraulic lifters and the oil groove, I would check the position of the oil groove to make sure it is the same as the one currently in service. The groove must line up with the oil gallery in the block. Del | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | dels56 - 2026-03-17 4:12 PM I would check the position of the oil groove to make sure it is the same as the one currently in service. The groove must line up with the oil gallery in the block. Del Thanks for that Del. I just checked the one I removed against the NOS Mopar 2808 569 and the oil groove in the hydraulic lifters are the same at 1.500 from the bottom of the lifter (where the lifter runs on the cam lobe). The two Melling JB-812 lifters are getting closer. They have arrived this AM at the UPS airport warehouse (after first making the trip from Colorado to Louisville Kentucky) *BUT* they didn't make it onto a delivery truck for the previously scheduled (promised??) Weds March 18th delivery. Supposedly out tomorrow. (Maybe) I will obviously check the dimensions and height of the oil groove of the Mellings when they arrive at my door. I am still cleaning and painting in the intake area anyway so no biggy that here is a bit of delay. Edited by 56D500boy 2026-03-18 10:53 PM | ||
| Mopar1 |
Expert Posts: 3190 ![]() ![]() ![]() ![]() ![]() ![]() Location: N.W. Fla. | The 812s are not exactly the same as the OEM ones, but will work. The LA ones will work but are a bit taller & harder to work with. When I had adj. push rods in my 331 I found that setting them where they could still spin w/o any slack worked, where setting them with any extra turns didn't. | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Thanks for the comments George. I received the Melling JB-812s just after lunch. They are very close, if not identical to what I took out of my Dodge 315 double-rocker. Now to soak it over night and start putting things back together. (And adjusting the valves (again)). | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | 56D500boy - 2026-03-18 2:55 PM *BUT* they didn't make it onto a delivery truck for the previously scheduled (promised??) Weds March 18th delivery. Supposedly out tomorrow. (Maybe) I will obviously check the dimensions and height of the oil groove of the Mellings when they arrive at my door. The Melling JB-812s did arrive today, just after lunch. From what I can tell by measuring the height, diameter, etc. they are almost, if not, identical to what I took out of my 315 double-rocker. Still different than the 2808 560 which was supposedly the supersede from the 1555 176 which was the 55-57 Dodge Poly and 57 Double-rocker lifter. I am going to install the Melling JB-812 where I had the broken lifter (No. 8 intake). The height to the oil hole of the Melling is 1.486" (to the centerline of the hole - actually the same as the as found lifter which I thought was 1.500" yesterday) The numbers: (56DodgeLifterComparison_EffectiveHeight_WithMellingJB812AndDiameters.jpg) Attachments ---------------- 56DodgeLifterComparison_EffectiveHeight_WithMellingJB812AndDiameters.jpg (130KB - 227 downloads) | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Well boys, I've got good news and bad news. The good news is the last two weeks or so didn't make the engine's back-firing any worse. The engine started fairly quickly considering that the carb had been off the intake and probably was a bit drained. The bad news is the last two weeks or so didn't make the engine's back-firing any better Engine popped at idle just like it had 2 or 3 weeks ago. But this time I got "smart" (ish). I pulled spark plug wires one at a time to determine which one of the eight was the problem. I did 2-4-6-8 (one at a time) because although I have the plugs back in I didn't have the wire cover attached to the valve cover. Then I did the 1-3-5-7 (one at a time) by pulling the lead out of the distributor cap. No change pulling 1. Pulled 3, no more popping. Okay. Put the lead back in and carried on with 5 and 7. Popping still there. Put them back (one at a time). Pulled No. 3 again. No more popping. So I guess No. 3 is the suspect. Now to find out what it going on and fix the problem. Hopefully, I have the skills to do that. The driver's side bank (odd numbered cylinders) is a major pain on my D500 because the generator and PS pump combo over the driver's side engine bank probably have to come off to allow me to remove the valve cover and inspect the valve train. Not a happy camper at the moment but to be honest I am not surprised. I think the No. 8 intake lifter problem was a red herring/smoke screen (I had to fix the lifter issue but I really didn't think the lifter was the cause of the popping). Your thoughts are welcomed. I suspect a No. 3 intake valve/lifter problem. (Stuck open??) How big a hammer will I need? Edited by 56D500boy 2026-03-31 8:28 PM | ||
| hondaman1974 |
Veteran Posts: 270 ![]() ![]() ![]() ![]() Location: Northern Illinois | Dave, did you happen to do a compression test on all cylinders? i remember years ago having this same problem with an early la273 v-8. the intake lifter "plunger portion" was stuck causing the valve to stick open slightly causing a backfire condition. i found it using a vacuum gauge, i believe the needle was jumping around a bit. just a thought. Tony | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | hondaman1974 - 2026-03-31 6:53 PM Dave, did you happen to do a compression test on all cylinders? i remember years ago having this same problem with an early la273 v-8. the intake lifter "plunger portion" was stuck causing the valve to stick open slightly causing a backfire condition. i found it using a vacuum gauge, I believe the needle was jumping around a bit. just a thought. Tony Tony that is definitely a possibility. Since I posted above, new information has come to light, Dude: Before supper tonight, I went out to the garage and removed the wire cover (1-3-5-7). I was thinking that I might find some kind of wiring issue with No. 3. Nothing immediately jumped out. I pulled no. 3 wire out of the spark plug well (it seemed loose but it might not have been). Then I started the engine. As expected, no popping. When I got out of the driver's seat to observe the engine bay (engine running), there were multiple spark paths from the long tube spark plug wire holder (that reaches down to the No. 3 plug). Lots of different paths. Then I observed the exhaust. Seemed 100% normal. Felt the left side exhaust at the tail pipe. No noticeable puffs that would have indicated a non-firing in one of the cylinders. Sounded great. Checked the spark plug wire and it was arching to the closest metal ground. A bit confusing. Tomorrow I am going to wrap that insulator tube with electrical tape and reinstall it on No. 3 in case that cures the problem (not likely). Generally I am relucatant to remove the left bank valve cover. BUT I will. I AM VERY RELUCTANT to remove the intake and valley cover again (but I will if that is necessary). I am trying to keep the worms confined. BUT I am starting to realize that it is an intake lifter issue. Just not No. 8 like I thought last week More results tomorrow. | ||
| Mopar1 |
Expert Posts: 3190 ![]() ![]() ![]() ![]() ![]() ![]() Location: N.W. Fla. | So...bad plug wire. I'd replace the wires and see if that helps or not. Easy & relatively cheap. I use straight boot 7mm Accel/Mallory type generic cut your own length wires on my 331. Then you can dig deeper if not. | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | Mopar1 - 2026-04-01 7:16 AM So...bad plug wire. I'd replace the wires and see if that helps or not. Easy & relatively cheap. I use straight boot 7mm Accel/Mallory type generic cut your own length wires on my 331. Then you can dig deeper if not. It would be nice (at this point) if the issue is just the No. 3 plug wire. It is still early here and I won't be able to test the "theory" until I am back from my regular Healthy Heart Wednesday "Walkies" (that I organize). Not sure if your 331 is a hemi or a poly George but my D500 315 is a "hemi" and needs these tubes (good ones, not the ones on the right end of the row that I killed by soaking them in Dawn and hot water). (I am not sure if a 7mm wire will go through the tube) Edited by 56D500boy 2026-04-01 10:41 AM | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | 56D500boy - 2026-04-01 7:39 AM. It would be nice (at this point) if the issue is just the No. 3 plug wire. It is still early here and I won't be able to test the "theory" until I am back from my regular Healthy Heart Wednesday "Walkies" (that I organize).. I'm BAAACCKKK. Got some new electrical tape and wrapped the No. 3 spark plug insulator tube (two layers) and re-attached the wire to the No. 3 spark plug. Started the engine (cold start). POP. POP. ( No improvement) Stopped the engine Pulled the No. 3 wire out. Restarted the engine. NO POP. Get out the can opener. Yet another Can O'worms ![]() | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Too bad that I was totally focused on the No. 8 intake lifter as the cause of the POP. I had the opportunity to observe the odd side lifters when I was rolling the engine (1.25" socket on the crank bolt) to adjust the 2-4-6-8 intake valves. I could have (should have) observed, say No. 3, intake lifter because it was there, to be seen. | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Just checked whether the wrapping of the No. 3 spark plug tube with electrical tape got rid of the sparks/shorting to metal. It did BUT with the engine running (on 7 of 8 cylinders as soon as I started to put the spark plug wire down the No. 3 tube, the POP came back. I looked at possible way(s) to remove the odd side valve cover without removing the generator and PS pump combo. I think that it might be possible if I remove the battery so I can slip the cover forward. I want to see what is what with No. 3 intake valve. | ||
| Mopar1 |
Expert Posts: 3190 ![]() ![]() ![]() ![]() ![]() ![]() Location: N.W. Fla. | 56D500boy - 2026-04-01 9:39 AM It's a hemi. I've been running the straight boot wires w/o the ceramic covers since the 90s w/o any problems.Not sure if your 331 is a hemi or a poly George but my D500 315 is a "hemi" and needs these tubes (good ones, not the ones on the right end of the row that I killed by soaking them in Dawn and hot water). (I am not sure if a 7mm wire will go through the tube) | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . New "GOTCHA". After realizing that I had no choice but to investigate the 1-3-5-7 valve train, I had to bite the bullet and remove the left side hemi valve cover. It is NOT EASY. The top three nuts on the valve cover are a piece of cake as are the two outboard bottom bolts. HOWEVER, the middle lower bolt required that I remove the Power Brakes vacuum tank. Then I had to remove the battery to get some room to work (and the valve cover out). I made some progress yesterday but... After much struggling to get the left valve cover off with out removing the generator and PS pump combo yesterday late, I finally capitulated this AM and did just that (PS pump off the back of the generator first and then the generator and bracket off the engine.) Finally I could wrestle the valve cover off (been on 9 years). ( Cork gasket didn't rip so I might reuse it.) I was more than a bit surprised/shocked/disappointed to immediately see that there was an issue with the No. 3 *EXHAUST*push rod. The cup at the top has broken and the push rod has jammed against the rocker arm. I can see where the push rod has been rubbing on the push rod port in the head and that the push rod is slightly bent. I can't quite figure out how that would cause the No.3 backfire but it must. See attached photos below. Now to find a NOS or good used D500 style push rod. I have a couple of ideas. I only found one piece of the broken cup so far. Summit makes an adjustable push rod that might work as Plan Z if I can't find a NOS or good used 1730 567 56 D500 push rod. https://www.summitracing.com/parts/tfs-9510 (LeftBankValveTrainUponValveCoverRemoval_April02_26_NoteNo3Exhaust.jpg) (LeftBankValveTrainUponValveCoverRemoval_April02_26_NoteNo3Exhaust_Detail.jpg) (DamagedNo3ExhaustPushRod_April02_26.jpg) Attachments ---------------- LeftBankValveTrainUponValveCoverRemoval_April02_26_NoteNo3Exhaust.jpg (185KB - 332 downloads) LeftBankValveTrainUponValveCoverRemoval_April02_26_NoteNo3Exhaust_Detail.jpg (187KB - 276 downloads) DamagedNo3ExhaustPushRod_April02_26.jpg (77KB - 239 downloads) | ||
| JedRhule |
Veteran Posts: 143 ![]() ![]() Location: Palm Beach County Florida | If the exhaust valve does not open fully, the charge escapes into the intake manifold when the intake valve opens shortly later. | ||
| Steve1956 |
Veteran Posts: 141 ![]() ![]() | Dave, Are the D500 pushrods different to the 315Poly V8. If not I may have a good spare for you . Would need to find it though ! Steve, Sydney, Australia | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Steve: I appreciate the offer but I believe the poly push rods are different than the D500 because the polys used hydraulic lifters and the D500s used solid lifters with adjustable rocker arms. The rocker arms had friction fit ball adjusters that fit into cups at the upper end of the D500 push rods. These are D500 push rods. The shorter one is for an intake valve, the longer for an exhaust valve. I need one of the longer ones with a good cup. The good news (for you) is you don't have to find one of your spares Edited by 56D500boy 2026-04-03 9:47 AM | ||
| Steve1956 |
Veteran Posts: 141 ![]() ![]() | Yes, You are right of course. I can see the difference. Mine have a ball like end at both ends. Steve | ||
| Powerflite |
Exner Expert 10K+ Posts: 10586 ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | I would just buy them from Hot Heads. | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | Powerflite - 2026-04-04 5:19 AM I would just buy them from Hot Heads. That would be a good idea but for one thing. They are out of stock and are weeks out from getting more. (I just called them) https://www.hothemiheads.com/dodge/cam_shafts_timing/pushrods.html As a result, I am going down a different path (or two) which I will document in a separate thread. | ||
| Mopar1 |
Expert Posts: 3190 ![]() ![]() ![]() ![]() ![]() ![]() Location: N.W. Fla. | Check with QEC, "Wayfarer" here in the Board. | ||
| wayfarer |
Elite Veteran Posts: 942 ![]() ![]() ![]() ![]() ![]() ![]() Location: Peoples Republic of Oregon | Thanks George. Although I have plenty of 'odds n sods' there are none with the cup. I'll need to keep digging to see if something is hiding... The option, of course, is to call Smith Bros. For those who might have a need, Eric is at ext 4710 - 541-388-8188 | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Well I think I finally have the back-fire POP cause figured out: No. 3 was the suspect cylinder. Mangled exhaust push rod was a big clue. Finally realized that I had to bite the bullet and take the intake and valley cover off -AGAIN. Before I did that I tried to get the No. 3 exhaust lifter to move (it seemed to be stuck UP). Nothing (needed a bigger hammer ?) Took a photo of my Bore Hole camera screen. I can see that the wire clip needed to hold the lifter button in/down didn't seem to be there. GONE to meet its maker. Pining for the Fjords. When I finally removed the No. 3 exhaust lifter, I see that the button is stuck UP, not as far as it could go but still UP. Especially compared to the No. 3 intake lifter (which looks fine). I am going to soak both lifters in solvent over night. In the AM I will try to get the No. 3 exhaust lifter button to move (DOWN). I will also look for more lifters that have this Button UP issue. (BoreHoleCameraDownNo3ExhaustPushRodHole_TopOfLifter.jpg) (315HydraulicLifterWithButtonStuckUP_1.jpg) (315HydraulicLifterWithButtonStuckUP_2.jpg) Attachments ---------------- BoreHoleCameraDownNo3ExhaustPushRodHole_TopOfLifter.jpg (99KB - 295 downloads) 315HydraulicLifterWithButtonStuckUP_1.jpg (126KB - 178 downloads) 315HydraulicLifterWithButtonStuckUP_2.jpg (134KB - 268 downloads) | ||
| Mopar1 |
Expert Posts: 3190 ![]() ![]() ![]() ![]() ![]() ![]() Location: N.W. Fla. | I've found retainer clips missing also. I use the early 361/413 lifters, ordered one from the parts house & it came in w/o the insides. just am empty shell. | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | Mopar1 - 2026-04-17 7:44 AM I've found retainer clips missing also. I use the early 361/413 lifters, ordered one from the parts house & it came in w/o the insides. just am empty shell. Hope you got your money back because that ain't right. UPDATE: After soaking my clip-less but stuck lifter in solvent over night, I got it unstuck. Seems to be fine. (The inner piston seems to move up and down without issue.) Not sure if it will ever go back in my engine, even if I steal a clip from another lifter. Edited by 56D500boy 2026-04-17 2:12 PM (StuckLifterNowUnstuckLifter_1.jpg) Attachments ---------------- StuckLifterNowUnstuckLifter_1.jpg (94KB - 212 downloads) | ||
| Mopar1 |
Expert Posts: 3190 ![]() ![]() ![]() ![]() ![]() ![]() Location: N.W. Fla. | yes, they ordered another one. | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . I've been working my way down the odd number bank and hit "7" yesterday. I rotate the engine my hand (1.25" deep socket on a ratcheting 1/2" torque wrench) until I get that cylinder to TDC. Then I check that the lifters are a little loose before I back the adjuster screw off until I can get the rocker out of the way and remove the push rod. When I did this to No. 7 intake I was surprised that the adjustment was way loose (too loose) compared to when I had adjusted the valves as if they were solids. (They're not - but that wasn't known to me in 2017.) No. 7 exhaust was fine. Even when I got the No. 7 intake lifter out, I still didn't notice any isses before I put both No. 7 lifters in a solvent bath over night. When I took the No. 7 intake lifter out of the solvent bath this AM, I still didn't notice the issue. Eventually, after removing the spring clip that holds the inner piston and piston button into the lifter shell, I noticed that the piston was way deep in the shell. No amount of tapping could get the piston to emerge from the shell. Finally the light bulb went on: This lifter had its piston stick down, hence the big gap the adjustment. Solution: Reuse No. 8 intake lifter that was fine except it had lost its spring clip. Put the clip from the No. 7 intake lifter with the shy piston, on the No. 8 intake lifter and rename it No. 7 intake lifter. So far so good. No. 7 exhaust lifter was fine and cleaned up and freed up after the solvent soak. Tomorrow = reinstallation and adjustment of lifters in No. 7, then on to No. 1 before going over to the even side exhaust lifters (I did the even side intake lifters last week (or so). Edited by 56D500boy 2026-04-19 9:39 PM | ||
| Mopar1 |
Expert Posts: 3190 ![]() ![]() ![]() ![]() ![]() ![]() Location: N.W. Fla. | The lifters mate to the cam lobe they've been on. The lobe probably will get wiped using a used lifter, guy a new one. | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | Mopar1 - 2026-04-20 7:27 AM The lifters mate to the cam lobe they've been on. The lobe probably will get wiped using a used lifter, Buy a new one. In a perfect world, I would agree. I have been doing just that (returning the cleaned and oil-filled used lifters to their respective locations) unless I needed to install a new lifter (Melling JB-812 was a good match). But now I am out of new Melling JB-812s (used in a couple of locations) and there are none around to buy locally. The No. 8 intake lifter and the No. 7 intake lifter have the same minimal wear (I don't think you could tell which is which) so I have to rationalize putting a used intake lifter into a intake lifter location (with some assembly lube on the bottom is unlikely to wipe of the cam lobe.) Not saying that there aren't risks, just that the risk is small. I hope Here are photos of the No. 3 exhaust lifter, the No. 7 intake lifter and the No. 1 intake lifter. I don't see much of a difference (No. 8 intake lifter (not shown), now the "new" No. 7 intake lifter looked the same). That said, I do see some more wear on the No.3 exhaust lifter that was stuck UP compared to the other two. Edited by 56D500boy 2026-04-21 1:45 AM (DaveFsLifterWearComparison_Unlabelled_2.jpg) (DaveFsLifterWearComparison_CorrectedLabelling.jpg) Attachments ---------------- DaveFsLifterWearComparison_Unlabelled_2.jpg (82KB - 175 downloads) DaveFsLifterWearComparison_CorrectedLabelling.jpg (133KB - 152 downloads) | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Nothing bad to report. Just plugging away. After I finished with No. 7, I went back to No. 1 to redo/check my work. Then on to No. 8 and the other even side exhaust lifters (I had "done" the even side intake lifters the other week and was too lazy at that time to open up the next can of worms and do the even side exhaust lifters) All the even side exhaust lifters have been fine, just needed some cleaning (internally). Just got the last one (No. 2 soaking in solvent at the moment. Before I go to bed tonight, I will clean and re-assemble it and put it to soak in 10W30 overnight. Tomorrow, I will re-install it and start to move towards re-assembling everything and maybe (MAYBE) starting the engine. IF that back fire is still there, I might have a car for sale, cheap. | ||
| Powerflite |
Exner Expert 10K+ Posts: 10586 ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | You can send all your lifters in to have them resurfaced. At least that used to be a common task. I think Napa can send them out for you if you don't know where to take them. | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | Powerflite - 2026-04-22 11:50 PM You can send all your lifters in to have them resurfaced. At least that used to be a common task. I think Napa can send them out for you if you don't know where to take them. Not happening. They're fine (enough). | ||
| Mopar1 |
Expert Posts: 3190 ![]() ![]() ![]() ![]() ![]() ![]() Location: N.W. Fla. | Supposedly they mate to the lobe within a minute..... | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | Mopar1 - 2026-04-23 2:30 PM Supposedly they mate to the lobe within a minute..... The two new Melling JB-812s that found a home in my engine got Lucas assembly lube on their butts (the contact surface with the cam lobe). The former No. 8 intake lifter is now the No. 7 intake lifter (with some assembly lube) That's all I could do without going nuts and replacing everything. | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11242 ![]() ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Finally got through playing with the mysterious hydraulic lifters and replacing 2 lifters and at least two push rods. Buttoned things up enough to test start the engine yesterday. Well, almost. I inadvertently trapped No. 3 spark plug wire under the newly repainted valve cover and had to correct that issue by loosening the 6 valve cover nuts/bolts *AND* the spark plug tubes (which help to hold the valve cover in). Got the wire out but by then it was supper time so I quit for the evening. Took about 10 - 15 minutes this AM to button up the valve cover and re-tighten (and torque) the spark plugs and then add the *ALL* the spark plug wires. After that, it started right up. It wasn't as quiet as I thought that it might be, considering that I had cleaned all the lifters and pumped them up with fresh oil before I re-installed them and adjusted the rockers to hydraulic standards, i.e. zero lash plus 1/4 turn. Doesn't matter it started and the back-fire is gone. Yay. Minor issue: I think I have too much timing going on because it is a bit hard to start (initial cranking is tough) But that is a problem for tomorrow. Today, I had to finish filing my 2025 Canadian taxes. NOW I have to pay the tax man. | ||
