Just received a NORS 4280X fuel pump and it seems to be siezed??
Posted 2026-06-11 4:51 PM (#643774)
Subject: Just received a NORS 4280X fuel pump and it seems to be siezed??
500050001000100252525
Not the first time. I thought maybe this one, still in its NORS box, would make pumpy sucky noises right of said box.
BUT NO.
Lever arm doesn't what to budge.
Suggestions? Bigger hammer?
This:
(eBay4280XFuelPumpJune2026_1_1024.jpg)
Attachments eBay4280XFuelPumpJune2026_1_1024.jpg (131KB - 68 downloads)
wayfarer
Posted 2026-06-11 6:05 PM (#643775 - in reply to #643774)
Subject: Re: Just received a NORS 4280X fuel pump and it seems to be siezed??
50010010010010025
They can be a bit stiff when fresh. I'd clamp the flange in a vise and put a cheater on the lever arm and gently try to move it.
ronbo97
Posted 2026-06-11 7:39 PM (#643777 - in reply to #643775)
2000200010010025
Find an original Carter fuel pump that was built for your car. Rebuild it with a kit from Then and Now. Never have to deal with aftermarket junk again.
Ron
Posted 2026-06-12 2:01 PM (#643786 - in reply to #643777)
ronbo97 - 2026-06-11 4:39 PM
Ron: That would be ideal. However, in 10 plus years of daily searches on eBay, not once did I see an actual appropriate Carter fuel pump pop-up,
even as a rebuildable core. I would love a stamped steel lever arm but NOPE.
Hence, I end up with NORS pumps or new pumps like an AirTex 4280 (now even that one is no longer available)
I think the closest I could come is an Edelbrock 1720 made for small block "LA" mopar engines (probably would need
the Hot Heads (or the like) spacer.) But the 1720 is "temporarily out of stock" so there you go. (Or NO GO as it were )
https://www.edelbrock.com/performer-rpm-mechanical-fuel-pump-for-big...
Edited by 56D500boy 2026-06-12 6:15 PM
ronbo97
Posted 2026-06-12 6:03 PM (#643789 - in reply to #643786)
2000200010010025
Dave - I'm seeing two different numbers for your fuel pump: 1450709 is what's listed in the 55-6 parts book, while 1692747 is what's in the 55-8 parts book. The good news is that it's the same for all 56 Dodge V8s. So it should be fairly easy to get one from a parts car. John Fowlie, Don Petty (who sold me the original fuel pump for my 55 Desoto), Wildcat, French Lake are places that come to mind. Ebay's search engine is such a pain to work with. It's pretty much broken at this point.
Ron
Mopar1
Posted 2026-06-13 9:56 PM (#643796 - in reply to #643789)
20001000100252525
ronbo97 - 2026-06-12 5:03 PM
Ron
Pretty clogged up with garbage ads.
Posted 2026-06-14 2:37 AM (#643797 - in reply to #643796)
Mopar1 - 2026-06-13 6:56 PM
If you want specific stuff on eBay put parentheses around what you are looking for.
This keeps the garbage ads away.
I always search (56 Dodge) and I only get 56 Dodge stuff. Admittedly, I might get 56 Dodge
Power Wagon stuff as well as 56 Dodge car stuff.
Works.
Try it.
Mopar1
Posted 2026-06-20 10:49 AM (#643845 - in reply to #643797)
20001000100252525
56D500boy - 2026-06-14 1:37 AM
Works.
Try it.
It works! great!
Posted 2026-06-20 4:05 PM (#643846 - in reply to #643845)
Mopar1 - 2026-06-20 7:49 AM
It works! great!
I think Sven (wizard) told me that trick a few years ago and I have been using it
ever since. WORKS.
Cuts out the BS/cr@p
