Revulcanization of motor mounts for a 1956 Windsor
Twotallkris34
Posted 2026-06-24 2:37 PM (#643866)
Subject: Revulcanization of motor mounts for a 1956 Windsor
Looking to see if anyone has a recommendation for a place in America to revcanize a set of motor mounts for my 1956 Windsor.
Thanks.
dels56
Posted 2026-06-24 5:05 PM (#643867 - in reply to #643866)
Subject: Re: Revulcanization of motor mounts for a 1956 Windsor
100100100100252525
good aft, unless you are a purest there are ways to Fix your motor mounts cheap and better than new. My 56 Dodge V8 is a bit different but you will get the idea from the attached page. I used 1955/56 Chry/Desoto motor mounts. I worked my butt of the seperate what was left of the vulcanized rubber away from the metal. Then used acetone and a powered rotoary wire brush to clean it up. Energy Suspension or Anchor will have a motor mount the should, with a little thought, bolt in between the metal parts fr about C$20.00. I paid more as you can see in the photo. Give it a try.
Dels 56
Edited by dels56 2026-06-25 9:45 AM
(Motor Mounts 2.jpg)
Attachments Motor Mounts 2.jpg (167KB - 46 downloads)
