Need Clean Gas Tank without removing suggestions
FdHarper
Posted 2026-09-05 8:37 PM (#644364)
Subject: Need Clean Gas Tank without removing suggestions
New User
I had another mechanical fuel pump die on my s/6 - second one in four years. I think the problem is the gas tank. At 76 years, I seriously hurt my back and I can't drop the tank or currently pay for it. Looking for comments or suggestions. Thanks in advance.
Posted 2026-09-05 11:23 PM (#644365 - in reply to #644364)
Subject: Re: Need Clean Gas Tank without removing suggestions
50005000500252525
It could be the fuel. The ethanol content in today's fuel is really hard on the older rubbers. Even if you buy a new pump, they don't tend to last long because they are still made with the old types of rubber. However, if you do decide to drop the tank, I recommend you run the car out of fuel or else use an electric pump to pump it dry first. That will save you a lot of trouble.
