Adding a Connector / Terminal into 1958 DCR Engine Bay Harness
BUCKET
Posted 2026-10-19 5:51 PM (#644602)
Subject: Adding a Connector / Terminal into 1958 DCR Engine Bay Harness
Would adding a Multi Pin Connector into the Engine Bay Wiring Harness create too much resistance .
The reason I ask is I will be taking the front clip off soon .
With a Multi Pin Connector I could leave all the wiring connected in the Engine Bay and Headlights and turn Signals .
Plus the Terminal block on the Radiator support panel .
I realise I would have to disconnect the Battery cables , Generator and Distributor wires .
I was think of adding a connector just below the Zip Tie in the photo .
Cheers ,
Greg
(Wiring Harness Connector.jpg)
Attachments Wiring Harness Connector.jpg (124KB - 50 downloads)
Posted 2026-10-20 9:01 AM (#644604 - in reply to #644602)
Subject: RE: Adding a Connector / Terminal into 1958 DCR Engine Bay Harness
50005000100010010025
I would say "Go For It". But is would be non-stock and ruin your chances for a concourse restoration trophy
(Kidding )
Just make sure that you label the wiring (in and out) until you know that it is going to work.
Go slowly. Test. Etc.
Back story: Back in about 1983 I bought a 1976 Datsun 200 SX from a wrecker for the 2 L engine to swap into a 1968 Datsun 510
that I was going to ice race. After I removed the engine and transmission, I went about stripping the shell of its wiring harness,
primarily for all the connectors (various pin counts). I have been using those connectors every since including when I added
extra taillights to my 56 Dodge.
Again, I took my time, labeled, tested and slowly completed (= no sparks, smoke or fires). (Important when our cars did not come
with a fuse panel).
Things like this:
REFERENCE: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=64943&...
Posted 2026-10-20 11:31 AM (#644605 - in reply to #644602)
Subject: Re: Adding a Connector / Terminal into 1958 DCR Engine Bay Harness
5000500020001000100100
Mind that the wires are stiff as for the insulation. Very common is verdigre present on the copper leads.
If you would want to solder the leads, you need firts to clean the copper leads. One way is citric acid dissolved in hot water 1:10.
Just acouple of minuts will clean the wires really nice. Submerge the wire ends one by on in the mixture.
BUCKET
Posted 2026-10-20 4:12 PM (#644607 - in reply to #644604)
56D500boy - 2026-10-20 9:01 AM
(Kidding
Now that's funny .
BUCKET
Posted 2026-10-20 4:16 PM (#644608 - in reply to #644604)
with a fuse panel).
Things like this:
Thanks Dave , that is what I was thinking of .
My only concern was the amp gauge wires having a connector .
I guess if done neat and right it shouldn't be a problem .
BUCKET
Posted 2026-10-20 4:17 PM (#644609 - in reply to #644605)
wizard - 2026-10-20 11:31 AM
Thanks wizard .
I have never heard of that but will give it a go .
