| Hello Everybody
I'm new in your forum. I'm live in Bulgaria and I have Dodge 1959. I look for parts for this car, But for the first I don't know the exact model of the car. I'm sure that it is Canadian production. Plymouth dashboard, but the modell may be Regent or Viscount or Mayfair, how to recognize this car.
The VIN is full of rust, but I read these symbols: M166 100632
http://classiccars.zonebg.com/Gifs/AmCars/dodge_59a.jpg
too much parts missing so it's difficult to me to determine model, I'd be happy if somebody help me with information |
Location: bishop, ca | Well, Bogdan, let me be the FIRST one to welcome you, here!
That's an Export model, you have there, all right.
| so in the car there is three pedals, I think it was manual transmission
But I don't know the exact model |
| there is one moulding on the front right fender, so I thin that maybe Viscount, Is Viscount has manual transmission |
| http://classiccars.zonebg.com/Gifs/AmCars/dodge_59b.jpg |
Location: .Norfolk..Mafia.. ,England UK | Welcome to FL.net Bogdan..
The 1959 Dodge Export models were Regent or Viscount or Mayfair as you listed , But also I think there was also a Kingsway.. I blieve the Side Trim was Different to each model Possible , Not sure if some had the Plymouth Dash and others the Dodge Dash,, The Canadian guys will know best probably.. Here is your link Pic and a couple others..
(dodge_59b.jpg)
(dodge-kingsway.jpg)
(dodge-regents.jpg)
Attachments ---------------- dodge_59b.jpg (42KB - 380 downloads) dodge-kingsway.jpg (16KB - 1164 downloads) dodge-regents.jpg (50KB - 3091 downloads)
| I'm sure that the model is not Kingsway, because Kingsway has Dodge Dashboard, but my dashboard is Plymouth dashboard |
Location: Connecticut | Bogdan - Your 59 Dodge is a Viscount. It was one model below the Custom Royal and had a Plymouth dash and body panels. Ron
(59 Dodge Viscount.jpg)
Attachments ---------------- 59 Dodge Viscount.jpg (298KB - 757 downloads)
| Hello Ron
what do you know about engine for Viscount
the VIN: M166 100632
Whay do you think that is Viscount
Moulding on the right fender? |
Location: Vancouver, BC | Rebels-59 Coronet - 2010-01-02 2:34 PM
The export Dodges were NOT Regent, Mayfair or Viscount. Those nameplates were used ONLY in Canada. All export Plymouth-based Dodges from 1946 to 1959, whether built in Canada or Detroit, were sold as Kingsway models.
The instrument panel in LHD cars was from the Plymouth, while RHD 1957-59 Mopars used a panel similar to Dodge.
And this particular car is not Canadian.
M166 100632 :
M - Model year - 1959
1 - Make, engine - Plymouth 6 / Dodge Kingsway 6 (US) / DeSoto Diplomat 6
6 - Series - Fury / Kingsway Custom / Diplomat Custom
6 - Assembly Plant - Lynch Road, Detroit
100632 - the 632nd model M16 off the 6 assembly line.
In North America the "6" series was a V8-only series but Chrysler did built 6-cylinder sedans for export. Being a Detroit-built car, the engine is a 230-cid 23" block engine. If had been built in Windsor it would have a 251-cid 25" block engine.
In Canada this car would have been a Viscount, using make digit "7" for a six or "8" for a V8, same digits as used on the Canadian-built export Kingsway models. The assembly plant code was "9".
Car Line code for the Canadian/export Dodge was "E" in 1959-60 while the DeSoto Diplomat was "F".
The American plant built every body model and body style for export (depending upon country). The base Saboy was labelled as a Kingsway, the Belvedere was Kingsway Deluxe, the Fury was Kingsway Custom and the Sport Fury was labelled Kingsway Lancer. The 1956-58 Fury models were not exported under either Kingsway or Diplomat name.
In 1959, the Canadian plant built only the following models for export -
Plymouth 6 - Belvedere 4-door sedan
Dodge 6 - Kingsway 4-door sedan, Kingsway Deluxe 4-door sedan, Kingsway Custom 4-door sedan
Dodge V8 - Kingsway Custom 4-door sedan and 4-door hardtop
DeSoto 6 - Diplomat 4-door sedan, Diplomat Deluxe 4-door sedan and 4-door Suburban, Kingsway Diplomat 4-door sedan
DeSoto V8 - Diplomat Custom 4-door sedan and 4-door hardtop
Is there a body tag somewhere on the firewall of the car? It would have some build details as well as model, paint, trim and possibly options. Of course, if this car was shipped CKD the tag will be nothing like the tag as used in the U.S.
Your car is a six cylinder Kingsway Custom sedan, basically a Fury/Viscount. In North America the Fury and Viscount models were V8 only, but Chrysler did built 6-cylinder Fury, Kingsway Custom and Diplomat Custom sedans for export.
American-built export models all used Plymouth's "1" or "2" for the Car Line / Engine in the 1959 VIN. The first "6" is for Fury / Kingsway Custom / Diplomat Custom and the second "6" is for the assembly plant, Lynch Road, Detroit. Being an American car, the engine is a 230-cid engine and, yes, the base transmission was the 3-speed manual. The 2-speed Powerflite was the only automatic available on a six before 1960.
If there is a body tag on the firewall, the model code should be ME1-H 41. A DeSoto 6 Diplomat Custom would be
MF1-H, while the V8 version would be "-2" instead of "-1".
| Hello Chrycoman
well. the car is Kingsway for export and Viscount for Canada.
there is no tag on the firewall - too much rust
| O.k now I'm sure. Thank you very much
Kingsway 6 cylinder engine, 3 speed manual transmission
in America this is Viscount, what is the diference between Mayfayr, viscount and regent in America |
Location: Connecticut | Sounds like Bill's got it nailed down. I based my assumption on the fender moulding. Ron
| Well you're right
It is export model, not american model. The model is produced for Export. the right moulding show that it is Kingsway. the export models is 6 cylynder 3 speed manual, so it easy for me now, that I have Dodge Kingsway 1959 for export or Dodge Viscount 1959 for America |
| Can you explain me what is the diference between Mayfair and Regent outside |
I own a 1959 Dodge Mayfair 4dr sedan. There are many differences between the Mayfair and Regent, but the most easily recognizable outside difference is the shorter lower moulding on the Regent and the absence of chrome rain gutter moulding along the roof on the Regent.
Here's a couple of pics of my Dodge Mayfair:
| so it means that Regent is the cheapest model, the next place is for Mayfair and the luxury Canadian model is Viscount. Do you know how many KIngsway produced in 1959 |
Location: Nasco , SWEDEN | ronbo97 - 2010-01-03 12:19 AM
Here's a pic: Wow, this is a beautyful car. i´ve never seen one before! Ron wouldn´t it be great to start a thread only for original pic´s frome sales brouschures etc, etc?
Attachments ---------------- 59 Dodge Viscount.jpg (298KB - 519 downloads)
Here are two shots of a 1959 Dodge Kingsway Custom sedan from the web.
(1959 dodge king cus Q86.jpg)
(1959 dodge king cus Q85.jpg)
(1959 desoto dip inst 03.jpg)
Attachments ---------------- 1959 dodge king cus Q86.jpg (72KB - 2262 downloads) 1959 dodge king cus Q85.jpg (75KB - 1329 downloads) 1959 desoto dip inst 03.jpg (97KB - 718 downloads)
Location: Vancouver, BC | The base Dodge Regent. Also known in export markets as "Kingsway". The 4-door model has the optional sport tone side trim. The 2-door has the standard side trim.
(1959 dodge reg 0A.jpg)
Attachments ---------------- 1959 dodge reg 0A.jpg (239KB - 1953 downloads)
| thank you everybody
you're very helpfull to me. I know too much for my car and for my favourite models of Dodge and Plymouth
Does anybody where can I find parts for my car. Does anybody know how many Kingsway produce in 1959.
So Regent is base,Mayfair is luxury and Viscount is on the top of the Canadian. For first look difference between Mayfair and Regent is side mouldings - am I right?
Thank you |
Location: Montreal, Canada | bshopov - 2010-01-03 12:13 PM
thank you everybody
Thank you
Yes, in Canada, the 1959 line-up went like this, from base model to top:
Regent, Mayfair, Viscount, Custom Royal
I have the Canadian brochure, the accessories catalog and the owner's manual for the 1959 Dodge, but it's now in the glove box of the Mayfair in winter storage.. I'll post scans when I can.
Here's a picture of a 4dr Regent I spotted in a backyard on the Gaspe Coast, in far eastern Quebec, two days ago. I'll get better pictures of it when I'm back in that area in the spring. It's a sad rusty hulk... Too bad, really, as it was still running a plated about 6-7 years ago.
Compare the picture of this Regent with the one of our Mayfair, and you'll easily spot the difference in side trim.
Edited by soiouz 2010-01-03 12:48 PM
| Hello Soiouz
Thank you
with advices you give to me, now it's very easy to determine Canadian Dodge 1959, when I saw the picture of the blue car - I said wow it is Regent, and then when I read your description I saw that is Regent. Thank you for the photos, Now I think thanks to You I'm specialist about Canadian Dodge 1959 and for me it is easy when I look side mouldings of the car to determine the model. Thank you very much, for two days here I learn much for my car and the others Dodge models, Now I'm the biggest specialist in my country of Canadian Dodge 59 - my favourite Dodge
Thank you again |
| Is there in Canada many Canadian Dodge 59?
How do you think where I can find parts for my car |
Location: Montreal, Canada | Well, they are pretty rare, but I guess they are quite common compared to the situation in Bulgaria!
Of course, these cars were prone to rust and our climate being so harsh (especially in Eastern Canada), not that many examples survived.
But that said, only here in Quebec, I know of more than a dozen 1959 Canadian Dodges (not counting Custom Royals). That includes about 4 or 5 of them in a junk yard I know (including two Regents and two Mayfairs). The Viscount are the rarest.
Parts can be found in many junk yards around here. |
Location: .Norfolk..Mafia.. ,England UK | Check this Thread..
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=24456&...
Jeff may have some Spare Parts.. He lists a few regents on his farm..
| hey very good news to me and to my car, do you have any website of these junkyards or e-mail to contact
In my country my car is the only one except one Dodge 1959 Coronet - american version
http://classiccars.zonebg.com/Gifs/AmCars/dodge_59_4.jpg
http://classiccars.zonebg.com/Gifs/AmCars/dodge_59_3.jpg |
Location: .Norfolk..Mafia.. ,England UK | IF you are referriing to the Link i Posted.. It is Jeff's personal collection i believe.. But you can click on his Name and send him a PM , Or ask on that Thread and he may reply, I thought he wrote sometime back that he was Breaking 1 of the 59,s up for Parts.. But maybe wrong..
Here are the 2 PIC,s you linked above
(237.jpg)
(238.jpg)
Attachments ---------------- 237.jpg (46KB - 572 downloads) 238.jpg (44KB - 336 downloads)
| O.k I send mail to Jeff and will expect his answer |
| Tomorrow I post photos on my car. |
| so I post the photos how can I move the car from the ex-owner to my place when I keep it now. |
Location: Vancouver, BC | To help you with your search for parts -
1) Your car is an American-built Dodge Kingsway Custom 4-door sedan, with a 230-cid flathead six. The 230-cid six was built in the U.S. and is the same for all 1957-59 American-built six-cylinder Plymouth, Dodge and DeSoto models. Same for the transmission.
2) The interior on your car is bascially that of a 1959 Plymouth Fury - which was used on the export Dodge Kingsway Custom, DeSoto Diplomat Custom and Canadian Dodge Viscount. Only the parts with a "Dodge" name differ from the Plymouth and DeSoto models. Also cars with RHD drive use a different instrument panel.
3) The front clip (fenders, hood, bumper and grille) is the same as used on all export Dodge Kingsway models, Canadian Dodge Regent/Mayfair/Viscount models and American Dodge Coronet and Royal. All but the parking light housing parts will interchange with the Custom Royal. The CR has a different housing with an addtional collar with "gear teeth". (See Side Trim below)
3) The body, rear fenders, tailights, etc. are the same as all 1959 Plymouth sedans, 1959 Dodge Kingsway sedans, all 1959 Diplomat sedans and Canadian 1959 Dodge Regent/Mayfair/Viscount models. Only the nameplate on trunk lid differs make to make. The "Dodge" nameplate is unique to all non-wagon 1959 Dodge Kingsway models and Canadian 1959 Dodge Crusader/Regent/Mayfair/Viscount models and is not used on the larger Coronet, Royal & Custom Royal models.
4) The windshield, door glass, rear window will interchange with all 1957-59 Plymouth sedans, 1957-59 Dodge Kingsway sedans, all 1957-59 Diplomat sedans and Canadian 1957-59 Dodge Crusader/Regent/Mayfair/Viscount models. I know that holds true for the front doors as well.
5) Side trim - The trim used on the doors and rear fenders is shared with all 1959 Plymouth 4-door sedans & hardtops, 1959 Dodge Kingsway 4-door sedans & hardtops, all 1959 Diplomat 4-door sedans & hardtops and Canadian 1959 Dodge Regent/Mayfair/Viscount 4-door sedans & hardtops. Front fender side trim, though, is not shared with Plymouth due to the Plymouth's lower wheel opening, but it is shared with all 1959 Dodge Kingsway 4-door models, all 1959 Diplomat models and Canadian 1959 Dodge Regent/Mayfair/Viscount models.
6) The "Kingsway" nameplate was used on all 1959 Dodge Kingsway models, with a "Deluxe" or "Custom" nameplate added below where needed.
Any questions as what fits what during your search, don't hesitate to ask here. Someone will be able to help.
| http://www.2shared.com/file/10442655/50d8d2ce/IMG_0413.html
http://www.2shared.com/file/10442670/128444c3/IMG_0414.html
http://www.2shared.com/file/10442679/6b58fc67/IMG_0415.html
http://www.2shared.com/file/10442698/82dce17f/IMG_0416.html
http://www.2shared.com/file/10442711/321bb9e4/IMG_0417.html - this is plate on firewall with VIN
http://www.2shared.com/file/10442721/1936ea27/IMG_0418.html
http://www.2shared.com/file/10442734/70472fe9/IMG_0419.html - on this photo you can see that front panel around headlights is missing
http://www.2shared.com/file/10442785/e4b4c6b4/IMG_0421.html
http://www.2shared.com/file/10442834/7b1b68d4/IMG_0422.html
http://www.2shared.com/file/10442848/3decb238/IMG_0425.html
http://www.2shared.com/file/10442853/b3255af1/IMG_0426.html
http://www.2shared.com/file/10442865/716bac07/IMG_0427.html
http://www.2shared.com/file/10442875/68709d46/IMG_0428.html
http://www.2shared.com/file/10442884/98efb11f/IMG_0429.html
http://www.2shared.com/file/10442912/a18cc554/IMG_0430.html - on this photo you can see that the front panel is missing, so the headlights is missing and the left front turn signal is missing, so I must look for these parts
http://www.2shared.com/file/10442933/e4bd9740/IMG_0431.html - front shot again, you can see the missing parts
http://www.2shared.com/file/10442957/b58af4df/IMG_0432.html
http://www.2shared.com/file/10442966/e9a0978a/IMG_0433.html
http://www.2shared.com/file/10442969/791f8a1b/IMG_0434.html
http://www.2shared.com/file/10442994/8036ea69/IMG_0435.html
http://www.2shared.com/file/10443008/ef2f41e1/IMG_0436.html
http://www.2shared.com/file/10443030/cad99a10/IMG_0437.html
http://www.2shared.com/file/10443053/58a6c2c/IMG_0438.html - the new home of the princess
http://www.2shared.com/file/10443067/29cafbf6/IMG_0439.html
http://www.2shared.com/file/10443082/c72322f7/IMG_0440.html
so enjoy and I wait for your answer, you can see the missing parts which I must purchase
| also, before a couple of minutes I saw the speedometer it is in KM/H the last symbols are 200
You were right that my car is Export model and the model is Kingsway
Now I'm very sure. |
| Hi Bshopov, I sent you a pm. I should add a minor note to Chrycoman's interchangability list, the stainless 'eyebrows' above the headlights are different from the Plodges to the Custom Royals...the CR's are wider. Also I have seen proof that as beforementioned, It's not uncommon to see a '59 Regent with one-up Viscount-style side trim.
I'll be going to an auto wreckers this friday where there is a '59 Plodge. I'll take pics. |
| O'k I wait for photos, Jeff |
| I was too late on getting pics or more parts off the 59 in the junkyard...sadly, it was crushed. I wanted to know what model it actually was; it had Regent emblems on it yet the car had lots of options and a very nice interior, V8 auto, fancier stainless, et cetera. I suspect it started life as a higher model. Wish I'd have taken pics of it the first time I was there! |
| Wow, what happened with car - accident or something else. |
| Hey I think maybe some parts that could be used, can you take photo of the car from me. No matter that it was crushed. |
| http://www.2shared.com/file/10789271/f6efc427/IMG_9544.html
http://www.2shared.com/file/10789287/98147ddd/IMG_9545.html
http://www.2shared.com/file/10789300/cf6b0841/IMG_9546.html
http://www.2shared.com/file/10789306/2608ad74/IMG_9547.html
http://www.2shared.com/file/10789323/64543b79/IMG_9550.html
http://www.2shared.com/file/10789331/93416b14/IMG_9551.html
http://www.2shared.com/file/10789357/2c7869a7/IMG_9552.html
http://www.2shared.com/file/10789364/9e5c6bde/IMG_9553.html
http://www.2shared.com/file/10789375/f0406a09/IMG_9554.html
http://www.2shared.com/file/10789383/9ebbd3f3/IMG_9555.html
http://www.2shared.com/file/10789392/f0a7d224/IMG_9556.html
Location: bishop, ca | Bogdan, it is a bummer that your Paint/Trim plate, on the firewall is corroded.
The factory probably has no build records still existing on your car.
What you might/should try to do is check up-behind your car's glovebox to see if the factory's Broadcast Sheet might
still be masking-taped there.
Also, depending upon your car's floor covering's present condition, you might try removing the car's front seat and carefully
check under the floor covering, and/or on top of the floor pan, itself, to see if another Broadcast Sheet might have been folded-up
and thrown down onto the floor pan, right before the floor covering was installed, on the assembly line.
You might even check under the front & rear seats to see if there is any factory 'literature' folded up, under there, too.
Doesn't hurt to look there, and you might be pleasantly surprised with what you may find hidden in those areas!
Edited by d500neil 2010-01-20 4:50 PM
| so, it is very bad that I can't see the plate with VIN
But soon after the hard winter I start the restoration, I will see under the seats and I show you photos of restoration |
Location: Pau, S-W France | Pics of a '59 Kingsway Deluxe (V8), owned by the same guy who has the '58 CRL convertible (and a 2dr HT '59 Coronet ...)
(b-b-l_02 [%P].JPG)
(b-b-l_03 [%P].JPG)
(59kingsway2.JPG)
Attachments ---------------- b-b-l_02 [%P].JPG (123KB - 1181 downloads) b-b-l_03 [%P].JPG (101KB - 252 downloads) 59kingsway2.JPG (140KB - 1349 downloads)
| Do you have photo of the dashboard of your Kingsway, why your Kingsway is with short trim on the front fender
So, I find difference in the back side on the car in my car was a trim on trunk
I see that your car is without this trim
Can you explain for me this difference |
Please not that itsn't my car but the car of a friend ...
The car is a Deluxe not a Custom
(kings2006_0420_184800AA (Medium).JPG)
(kings-medal.jpg)
(b-b-l_08 (Large).JPG)
(b-b-l_09 (Large).JPG)
(DSCF0004 [800x600].JPG)
(kings2006_0420_184313AA [800x600].JPG)
Attachments ---------------- kings2006_0420_184800AA (Medium).JPG (96KB - 301 downloads) kings-medal.jpg (48KB - 292 downloads) b-b-l_08 (Large).JPG (130KB - 637 downloads) b-b-l_09 (Large).JPG (158KB - 299 downloads) DSCF0004 [800x600].JPG (87KB - 264 downloads) kings2006_0420_184313AA [800x600].JPG (100KB - 313 downloads)
| Hello
Wow your car is very nice and very original
Is there electric windows?
you see my car, aren't you?
Tell me what is your advice about restoration of the car
From where I must start the restoration.
Congratulations for you friend's Kingsway Deluxe - it is very good!!!!!
Location: bishop, ca | That 59 Kingsway looks like it's got 1958 Custom Royal upholstery in it; that's good durable material. |
Location: Pau, S-W France | bshopov - 2010-03-12 9:23 PM
Yes, at front, but not original ! My friend put the 2 switches under the radio.
bshopov - 2010-03-12 9:23 PMTell me what is your advice about restoration of the car
My friend bought the car (running !) in 1996 because he wanted "parts" for his '59 Coronet... But after a while he decided to not part the car and put it in storage (he hadn't the time to restore). He started the restoration 10 years later and made a "frame off" restoration, not because the car needs it but because he wanted to do a complete resto..
A complete restoration needs a lot of time and .. money !!
d500neil - 2010-03-13 12:01 AM
Remember that my friend owns also the '58 blue Custom Royal convertible and he loves the upholstery !!! So he bought the same material from SMS, problem he had to wait 1 1/2 year to get it !!!!
| Can anyone show me the original upholstery for Dodge KIngsway 59 for front doors and rear doors |
Location: Montreal, Canada | bshopov - 2010-03-13 11:37 AM
Your car had the same interior as a 1959 Plymouth Fury sedan. So you could use that as a model.
For example:
http://59sportfury.net/showcase/walker.html |
| Thank you,
Can you tell me is Plymouth Savoy luxury model for 59 or Fury is more luxury model |
Location: Vancouver, BC | bshopov - 2010-03-13 10:21 AM
Thank you,
From bottom (cheap) to top (luxury) -
Savoy (Kingsway)
Belvedere (Kingsway Deluxe)
Fury (Kingsway Custom)
Location: Vancouver, BC | d500neil - 2010-01-20 1:49 PM
No harm in writing Chrysler Historical and asking. As the build records were microfilmed in VIN order by assembly plant they rarely 'lost' anything. Judging by the experiences of non-North American owners, it seems Chrysler did not bother to keep the records of the Wyoming Avenue export plant, or for cars shipped CKD prior to Wyoming Avenue turning out export product.
This particular Kingsway appears to have been assembled in North America (Lynch Road) and shipped complete. So, CH might have the record.
| I'm a big fan of classic american cars. Speccialy the fly fenders. My favourite model year is 1959. so for the first time I see Buick 59 in my town I was around 11 years old. So I fall in love in these cars. I spend money and purchased this Dodge 59, but I realized that the car which made I falling in love in fly fenders is live. I'm very happy that my kid dream is live. My hapiness was full when I meet the owner and he told me that want to sell this Buick 59. now I spend money and I hope my dream will come true.
But I love the Dodge and I have a big interest of General Motors history and Chrysler history around 1955-1965.
So you're very helpfull to me with information in this forum |
| So can anyone tell me what was difference between Fury, Belvedere and Savoy in 1959 model year
Outside I see that Fury has more trims than Belvedere - the trim of front fenders are longer and there will be trim on the trunk - strange that the cheaper model has more trims than the more luxury Belvedere. And Savoy has only one chrom side trim on the left and right |
| What is the difference between Dodge Kingsway and Dodge Kingsway Custom |
Location: Pau, S-W France | The 2dr H/T Kingsway Custom (the only one i know in France) is for sale ... http://www.anciennes.net/annonce/201126798-Ventes-Auto-DODGE-kingsw...
About differences there is a lot of them, the K. Custom is the top (only V8), in the midle you've the K. Deluxe and the entry level is the Kingsway . I have a copy (in B&W) of the '59 Kingsway french catalog, i'll post them later. |
Location: Pau, S-W France | Here is the 8 pages catalog (i put thumbnails so enlarge them ...)
Cover :
Page 2 / 3 : Kingsway Custom 5 models : 4dr sedan , 2 and 4 dr "faux cabriolet" = H/T model . 2 wagons Sport Suburban (6 & 9 pass)
Page 4/5 : Kingsway Deluxe : 8 models : 2 sedans, 1 2dr H/T, 3 wagons "Custom Suburban" (6 & 9 pass 4dr , 6 pass 2dr)
Page 6 : only one page for the Kingsway (base model) !! No H/T but 2 wagons (Suburban)
Page 7 : Kingsway Lancer : the top trim level only in convertible and 2dr H/T .. This is the export version of the Sport Fury. DeSoto export named this model Diplomat Adventurer.
Page 8 : specifications.
Location: Vancouver, BC | The complete line-up, bottom to top - Plymouth-Dodge Canada-Dodge export-DeSoto export
L (Low) :
Savoy - Regent - Kingsway - Diplomat
M (Medium) :
Belvedere - Mayfair - Kingsway Deluxe - Diplomat Deluxe
H (High) :
Fury - Viscount - Kingsway Custom - Diplomat Custom
P (Premium) :
Sport Fury - (none) - Kingsway Lancer - Diplomat Adventurer
Interiors were just like the exterior trim - plainest on Savoy, et al. and fanciest on the Sport Fury, et al. Will get the interior photos scanned sometime today and post them.
The Low series interior was the plainest with no cigar lighter, no glove box lock, one sun visor, no arm rests in the rear and rubber carpet for the floor. Many years the steering wheel had no horn ring - just a button in the centre of the wheel. The lack of rear arm rests was common on Plymouth and Dodge models until the adoption of the new safety interior door releases in 1966-67, the ones that look like seat belt releases.
Location: Plymouth Spaceport | ronbo97 - 2010-01-02 6:19 PM
Here's a pic:
The export models are very interesting...its half plymouth,half dodge! |
| The export Dodge i very interesting, I find De soto Diplomat - Export, If you like I can post photos. De Soto is 1958 model year
Thank you for french catalog of Kingsway but the catalog confuse me, Because my VIN show that the car was 6 cylinder, but when i see exterior trim I think that my car is Kingsway Custom, but Custom V8 only
So now I thinking what exactly model is my car |
Location: Pau, S-W France | bshopov - 2010-03-15 11:52 PM
The Kingsway Custom is also available in 6 , see the small drawings of each body, the text says "6 or V8" (except the 2 dr HT, V8 only) |
| Thank you for information Phil
Now I can tell that I have Dodge Kingsway Custom 59
Do you have photos of Kingsway Custom - I want to see how must look like my car in perfect condition. also i want to see interior of Dodge Kingswat Custom, I'd be very happy if I see the dashboard of Dodge Kingsway Custom.
So I want to talk about the length of the car, when I se in the Internet i find information that the length of the car is 5.51 m but in french catalog I see that length is 5.51. Which dimenssion is right? |
Location: Montreal, Canada | bshopov - 2010-03-16 4:04 PM
Did you go see the photos I linked you to of the interior of a Plymouth Fury sedan? It's the same interior, same dashboard, same everything inside.
I suggest you do a little research for pics of a 1959 Plymouth Fury sedan, as you will have a much greater chance of finding what you are looking for than looking specifically for stuff about the much rarer Kingsway Customs. Except for the front clip and the emblems on the fins, your car was 100% identical to a USA-made Plymouth Fury 4dr sedan. |
Location: Pau, S-W France | The correct lenght, as stated in the last page of the catalog, is 5,33m (210 "). 5,51 m is for US Dodge. |
Location: bishop, ca | Bogdan, if your car is an Export model, its rear leaf springs and its Torsion bars may well be Heavy-Duty items.
You can count the number of its leaf springs (it may have 6 1/2 leafs) and if you can get it elevated, you could look
at the tail ends of the Torsion bars to read what its raised-numbers Parts Numbers may be, too.
| O'k I look in Internet about photos for Plymouth Fury and I will see again interior and dashboard. Can you tell me how many Dodge Kingsway Custom produced in 1959. So it means that I'll have problems with front torsions. In Condition that car is Dodge KIngsway Custom can you tell me what kind of torsions bars I must look for. Can I use the standart torsions bars from Dodge 59 or I must look for torsions for another model. Can you advice me? Can I use torsions from Dodge Regent, Mayfair, or I must look for torsions for Dodge Kingsway only. So the problem with torsions is big. Can you show me photo of Dodge kingsway Custom - Ouside I want to see where is located badge Custom and what is the difference between Kingsway Custom and Kingsway Deluxe
Thank you. |
| The problem is that I don't know the number of torsion bars because they missing, so even i climb the car when torsions missing - I can't see the item number and I can't be sure what kind of torsions must put in the car |
1959 6-cylinder Plymouth, Dodge, Kingsway and Diplomat used bars 604 and 605. (All bars that fit 118" and 122" wheelbase 1959-64 cars have the part numbers starting with 1825. Thus the full part numbers are 1825 604 and 1825 605.)
Other bars that would fit your Dodge at 1825 606/607; 1825 608/609; and 1825 610/611.
So, what cars could you use for a source?
Plymouth - all 1959, 1960 and 1961
Dodge Kingsway - all 1959
Dodge Dart - all 1960 and 1961
Dodge Coronet, Royal and Custom Royal - all 1959
Dodge Matador/Polara - all 1960 and 1961
Dodge 880/Custom 880 - all 1962, 1963 and 1964
DeSoto Diplomat - all 1959, 1960 and 1961
DeSoto Firesweep - all 1959
DeSoto Firedome and Adventurer - all 1960
DeSoto - all 1961
Chrysler Windsor - all 1959, 1960, 1961, 1962, 1963 and 1964
Chrysler Newport - all 1961, 1962, 1963 and 1964
Chrysler Saratoga - all 1961, 1962, 1963 and 1964
Chrysler 300 - all 1962, 1963 and 1964
Chrysler 300 H, J & K - all 1962, 1963 and 1964
Chrysler New Yorker - all 1963 and 1964
So there is a good selection vehicles to choose from over a six year period.
Just remember that the bars come in pairs, with the even number one digit less than the odd number. Thus a pair of bars would 604 and 605. Bar 606 would not go with 605, but it would with 607. Also, the even number (604) goes on the right or passenger side while the odd (605) goes on the left or driver side.
And when you install the bar, you place the bar non-numbered end in first. Thus the numbers will be showing when they are installed.
| O.k I talk with Bigmauto and he prepare for me two torsions from Plymouth Belvedere 59. So I decided this problem.
Can anyone tell me how many Dodge Kingsway 1959 were produced? |
Location: bishop, ca | Bill, do you have applications for the 608/609 and the 610/611 bars?
Is there an Export torsion bar listed in your records?
Location: Vancouver, BC | d500neil - 2010-03-25 2:10 PM
The 608/609 is listed in 1959 -
Heavy-Duty for suburbans (wagons) : Plymouth (P), Dodge (E), DeSoto (F), Coronet (D) - 6&V8
Heavy-Duty for all models except convertible & wagons : Dodge Custom Royal (D) and DeSoto Firesweep (S), also Chrysler Windsor (C) after M519101254, M511109320, M514100956
For 610/611 :
Standard duty for all models except convertibles : Chrysler Windsor (C) before M519101517, M511109320, M514100956
No mention at all of export use, although the H-D springs were used for export models as a rule.
By the way -
P - Plymouth (118" wheelbase)
C - Chrysler (122" & 126" wheelbase)
D - Dodge (122" wheelbase)
E - Dodge (118" wheelbase) and Dodge Kingsway
F - DeSoto Diplomat (118" wheelbase)
S - DeSoto (122" & 126" wheelbase)
Wagons for 118" wheelbase models were on a 122" wheelbase.
Location: bishop, ca | That's weird; the 610/611 are lower/STANDARD-duty, than the 608/609, huh?
John Schutte just scored a set of 608/609 bars off of a 61 D500.
B/G 61 might just be interested in those bars, because his D500 came with the 610/611
bars, reportedly...
Edited by d500neil 2010-03-26 3:52 PM
| Hello can anyone tell me what were the original colours of Dodge 1959?
| Hello Everybody
can anyone tell me how can I find the original colour of my Dodge 59. Is there any label on the car, or a sign that I find the real colour? |
| http://www.2shared.com/photo/5_U9n4qd/IMG_0417.html
http://www.2shared.com/photo/XBsVdv9q/IMG_0438.html |
| http://bshopov.snimka.bg/automobiles/taunus-15m.281636.19756428.big
http://bshopov.snimka.bg/automobiles/taunus-15m.281636.19756431.big |
