57 Custom Royal - Some Vintage Views Jump to page : 1 2 3 Now viewing page 2 [50 messages per page] | View previous thread :: View next thread |
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Hey, Rob; at your earliest convenience, you could have a good auto-mechanical shop lower the torsion bar's ride height, a tad. The car looks to be sitting very nicely, on its rear leaf springs. Hi, Ian; the 58 CRL's should have had a 4-bbl carb, with the new-4-58 350c.i. wedge-engine (along with dual exhausts). In Re: Spring Specials, the introductory literature specify that S.-S.'s were being built, OEM, that a car could be factory-ORDERED, with varying extents of the S.-S. trim-items, and/or , that any OF the S.-S. trim items could be DEALER installed!! The specific S.-S. trim were the grille-emblem, PAINTED headlightbezels (two-three existing S.-S. cars are known to have this very-rare item, on them; dunno why most S.-S.'s had regular headlight bezels, except, that the special-painted ones MUST have been expensive, to produce)...., then there's the distinctive WIDE side-trim, the end-of-fin 'triangle', and, then, there is the rear license plate "Escutcheon". In addition to the distinctive chrome/potmetal pieces, there were three unique S.-S. body colors: Poppy Red (R") , Frosted Turquoise ("J") and Paris Rose ("T"). SO, a (factory) Spring Special could have ANY combination of the above color(s) and trim, depending upon how the fatory jobber felt about a particular car, or depending upon how a special-ordering customer wanted his car to appear. SO (ii) all Spring Special COLORED cars are 'real' S.S.'s , but, for any car NOT painted in the three official colors, they can STILL be legitimate "factory" S.-S. cars, if they were special-ordered in a common-color, but having some/all of the S.-S. trim! Then: there are the DEALER-installed S.-S. trim cars (WHAT are they, officially? I dunno) Then: there are the cars where an owner bought some/all of the trim, & stuck it on HIS car, hisself! Ah, ya gota LOVE the Spring-Special cars! (that, & go FIND the car's Broadcast Sheet, or, go BUY a copy of its factory IBM Build card!) items | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | A sad end to a classic.......About five years ago, I realized I knew the landowner. He said he had forgotten the wreck was there, and to go ahead and take whatever I wanted. I clipped down a bunch of saplings, put the transmission in a wheelbarrow, and pushed it out to a road at the bottom about 150 yards from the car. It still had a piece of rotten rope tied to it from where a friend and I tried to drag it up the slope 20 years ago without any luck!.....The bumper chrome on it is in better condition than my car! Unfortunately, they dinged it up good pushing it with another vehicle. - Rob (57 parts car005 edit2.jpg) Attachments ---------------- 57 parts car005 edit2.jpg (98KB - 157 downloads) | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Hey, Rob! that bumper's worth some BUX!!!! That fin-trim would be hard to reach (why it's still THERE!, huh) unless you can get inside the trunk, but, that fin-plate is anodized aluminum! , and, the end-of-fin can be sucessfully re-chromed (no fine-detail to lose). You might also check to see if this is a CRL; if so, it will have a VALUABLE front end SWAY BAR---be sure to try to cut-out the frame's sway-bar brackets, if at all possible; if not, well, that's OK.... | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | Thanks for the advice Neil!........The rear end has sat a little low since we put a dual exhaust on it 5 years ago. The guy who's going over it for us at the moment has suggested some coil-over shocks. Another person, air shocks. I've contacted a spring outfit in the city, and they say they could re-arc and refurbish the leaf springs. I'm not sure what we can do before leaving for Tulsa in less than 3 weeks now................I intend to go out to the wrecked car this summer with a nut splitter and take the bumper. I will look at the other parts you've mentioned. I'm pretty sure we took the name plates off, and they were Custom Royal. - Rob | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Rob, if you are driving that CRL to Tulsa, you should get its T/bars lowered (for better handling, but, you will need to have the front end be realigned, too. The rear springs look to be OK; I've written to say that guys should, just-simply, score a set of (late 50's-mid 60's) stationwagon springs, and RE-use your car's long-leafs, while "stacking" a mixture of the S/W leafs, along with your car's leafs, to obtain a custom fit/ride. I did that, with a set of 1962 CHRY S/W leaf springs; got 5-full leafs on my car (yours has 4 1/2 leafs, OEM) now, and it sits "up" and rides nicely. | ||
exnerman |
Member Posts: 46 Location: NORWAY | Has anyone got a picture showing the Spring Special ? | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | Here's the first time the CR hit the road again after the rebuild, the 1988 wedding of some friends from school, back in Brandon, MB. I've just found out that the groomsman second from right here has since died in a SCUBA accident in Clear Lake; coincidentally where the old camping pix above were taken. (Wedding 1988 edit3.jpg) Attachments ---------------- Wedding 1988 edit3.jpg (82KB - 159 downloads) | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | Another in 2003. The mayor's daughter. (Wedding 2003 edit.jpg) Attachments ---------------- Wedding 2003 edit.jpg (40KB - 150 downloads) | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | The groom is a Mopar fan, his Monaco is at right. About an hour before the wedding, we got hit with a blinding downpour and I watched in horror as it turned to hail! Not a mark on the car, though. (Wedding 2003 edit2.jpg) Attachments ---------------- Wedding 2003 edit2.jpg (80KB - 146 downloads) | ||
Lancer Mike |
Location: The Mile High City | Wow, Rob! Those photos (past and present) are wonderful. The Dodge looks like it hasn't aged a day! It's just too bad that the people can't survive the ravages of time in the same way (ha, ha - I don't know whether that would be a blessing or a curse). Thanks for sharing those. Mike | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | Thank you Mike........Would you believe I spoke on the phone yesterday with the salesman they bought the Custom Royal from? It took all of 2 phone calls! He is 87, and in the same city as 50 years ago! He sold nothing but Chrysler until he was 75, including a couple of years in the town where I live now. Pretty amazing! | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | 5859 - 2007-05-21 8:04 PM Yeah, a real bad day, and the problems went on and on. We lost 2 engines and a transmission out of a locked shed there, as well.That's a pretty hard blow to have had that car burned up like that, and like you said, it just had to be the driver, and not the parts car. | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Hmmp, 'you' just don't go-out, and pick up a couple engines, and cast-iron transmission!! Somebody put a "hit" out, on your stash! I wonder what their intended purpose was, in stealing them? Any knowledgeable rodder (robber) would know that the things would require rebuilding, to be made serviceable, and, where do they STORE them, after they've got them, and how do they keep the news, of their new acquisions, secret?? One would think that, anyone adept in engine rebuilding would not be the sort of person who would go out & steal his own "inventory", and, that that person would look askance at someone else, just showing-up with an "engine-and-a-story", and not wonder about how the guy reallly got that engine/trans. What kind/size of motors were they? And, who knew about their presence, in that shed (and, who also, apparently knew that no one would bother/observe them, as they hoisted the pieces, into their nearby truck???) | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | In case anyone noticed, I think I've solved the mystery of the disappearing radio antenna. Although my Mom doesn't recall the car not having a radio, I'm pretty sure they bought it without and installed one later. So, the photos without an antenna are the earliest of the car, and predate the 1958 camping trip where the antenna is in place just in front of the driver's rear view mirror. When they changed the fenders, the new ones had the antenna hole on the passenger side, where it is now........The salesman remembers the dealership often installing antennas on the driver's side, and thinks he sold it without a radio. Also, that he sold more Tri-Tone cars than this one in '57. - Rob (Old slides FL05.jpg) Attachments ---------------- Old slides FL05.jpg (70KB - 152 downloads) | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | d500neil - 2007-05-25 3:39 PM The 383 from the 59 parts car, and another 325 Poly & trans for the 57. ......Thief had all the time in the world. *Cough*tenant*Cough*......Instead of prying the hasp off the front door, they dismantled the back wall, took the stuff, and nailed the boards back on with new, galvanized nails! I believe in an attempt to make it look done by someone with a key to the shed.What kind/size of motors were they? And, who knew about their presence, in that shed (and, who also, apparently knew that no one would bother/observe them, as they hoisted the pieces, into their nearby truck???) | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | Here's one of my aunt's snapshots from that 1958 campout. (Clear Lake 1958b.jpg) Attachments ---------------- Clear Lake 1958b.jpg (16KB - 158 downloads) | ||
ronbo97 |
Expert Posts: 4044 Location: Connecticut | The vintage photos are very cool! Looks like you had someone in the family that knew a little about photography and was able to get close to the subject. I'll bet that the slides were Kodachrome, which had very stable color dyes. If they were any other brand, including Kodak Ektachrome, those images would be all but gone. | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | Good call ronbo. They're Kodachrome, and were stored in magazines for an automatic slide projector. (Kodak2.jpg) Attachments ---------------- Kodak2.jpg (46KB - 159 downloads) | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | And, to further prove I don't get rid of much,.....here's the camera that took the photos. You can see Mom holding the case for it in the photo with the little girl. I think they got it from my uncle with the Cadillac after he upgraded it! (Camera2.jpg) Attachments ---------------- Camera2.jpg (53KB - 159 downloads) | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Bummer, to hear about Eckta-plasm film; Ron! I took predominently Eckta-photos, in the 60's. That's a major-Kool camara; kinda like a Leica, on Steroids!!!! | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | Their 40th anniversary. Hard to believe this was 17 years ago. (40th anniversary 1990 edit.jpg) Attachments ---------------- 40th anniversary 1990 edit.jpg (92KB - 154 downloads) | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Rob, SMS makes/sells upholstery cloth for your car; it looks to have gray-colored "Linear Lucidity" 1957 Royal upholstery. | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | Thank you Neil, I will certainly look into it. Dad recovered the front seat, but not the back one. It's had the same Leopard (or Cheetah?) skin blanket on it since I was a child! | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | SMS sells the correct colored/patterned vinyl, correct black seat-beading, upholstery cloth, and should be able to reproduce the heat-embossed center-sections, too. You can take your car to your area's best upholstery shop, & they can tell you if they can re-use the embossed center sections, or not. Here's a MAJOR clue: SMS's vinyl is NOT as thick/reinforced/durable as the OEM vinyl (check out the OEM "Pellon"-reinforced vinyl, versus the un-lined materail, from SMS. Because the MOST wear, to the vinyl bolsters occurs at the LOWER/OUTER areas (because of seat compression, every time someone sits in the car) and, also, on the outer-horizontal sections, THOSE area-sections should have RESIDUAL OEM vinyl be installed (typically, from perfect-condition vinyl, found on the lower seat backs). The upper seat-backs get the most wear, to the upholstery, where it adjoins to the vinyl, so, SMS vinyl can be used on the upper seat backs. In my 27 year custodianship, I have had to replace the outer/lower seat vinyl twice, due to compression-failure/cracking, from getting into the driver's seat. I also have had my upholstery shop install clear plastic vinyl seat-covers, over the redone upholstery. I recommend that procedure, for anyone who uses his car regularly. Think of it as being a condom, for your car: you DO get used to it (eventually), but ALWAYS appreciate the protection it affords, from you, and from any other careless person who "falls" into it!!! | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | Went out to the wrecked 57 yesterday for the first time in 5 years or so. Had fun finding and getting to it! Been enough Black Bear incidents here lately to get you thinking, too.....The front end has sunk further toward the stream, which is right beside it. A friend has offered to help take some more off it when the leaves drop. He says we should just take a torch and cut the bumper, etc., off...If anyone wants some more sad photos, PM or email me, and I'll send you a 7.6 Mb zip file with about two dozen pix. - Rob (June 1 07.jpg) Attachments ---------------- June 1 07.jpg (98KB - 158 downloads) | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Hey, believe it or not: those gas tank straps are valuable, as are the spring assemblies. You could torch off the license plate trim; looks like the lock is gone. Heck, even the gas tank is nicer than the one that Johnny Rosen has been trying to sell on Epay! | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | A few more of the old slides..................A fishing trip with the last camper Dad made. (Old slides FL25.jpg) Attachments ---------------- Old slides FL25.jpg (80KB - 156 downloads) | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | North end P la P. (Old slides FL12.jpg) Attachments ---------------- Old slides FL12.jpg (62KB - 151 downloads) | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | Cheers!........See you in Tulsa. - Rob (Old slides FL15 edit.jpg) Attachments ---------------- Old slides FL15 edit.jpg (82KB - 144 downloads) | ||
Diesel45 |
Expert Posts: 1539 Location: Farnborough. Hampshire. England. | For me personally, this post has been one of the best trips down memory lane that I have seen on this board in a long time..Thankyou Rob.. | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | Hi All - Been a long time!......I have a new computer and it`s taken me this long to find this thread again. I thought I`d add some more of the old slides.......Here`s the 55 Regent again, along with the big catch of the day. :P - Rob (Old slides FL19.jpg) Attachments ---------------- Old slides FL19.jpg (57KB - 144 downloads) | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | A picnic, but notice the tackle box.....Always ready to fish! (Old slides FL26.jpg) Attachments ---------------- Old slides FL26.jpg (99KB - 142 downloads) | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | "Mr. Rich B!tch" (Old slides FL04.jpg) Attachments ---------------- Old slides FL04.jpg (48KB - 138 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13055 Location: Southern Sweden - Sturkö island | This is supercool photos! Really enjoyable Thanks for posting them | ||
agirlandher58 |
Extreme Veteran Posts: 369 Location: buchanan,Ga. | I 'm digging it daddy-o !!! Looks like it just blasted its way rt. out of 57!!!!Very Nice Car!! | ||
Gidman |
Extreme Veteran Posts: 452 Location: Southern California | What a great tribute to your Dad and family! Having the car is just the icing on the cake. Great photo album!! | ||
moparsteve |
Elite Veteran Posts: 1155 Location: somerville mass | thank you for preserving such a beautiful fl car! 51 years! think of all that happens in that time! and you had your own 1959... wow and one kids threw off a embankment in the 60's - its still there!!!! you even have your dads 1963 dodge panel truck! "town panel" it said. strictly a dodge family at heart!!! a electrician by trade.. did you follow in his footsteps.....? thanks for rekindling memories to us all!!! restore the truck , too - it doesnt look too bad..., paint is a little dull... thanks! you took us all back in time.. | ||
firedome |
Expert Posts: 3155 Location: NY & VT | The Caddy is a 1960, Model 62 Convertible in Cad-speak...I love that car in the light metallic purple they had that year with white interior..yowza!! | ||
Board Moderator & Exner Expert 10K+ Posts: 13055 Location: Southern Sweden - Sturkö island | Got to admit that the 60 Schabbillacs was kind of OK even if it hurts a little. | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | So, Rob, you said, somewhere, that you're thinking about selling the car? | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | d500neil - 2008-01-30 8:44 PM Why yes, I am........(Not!) :PSo, Rob, you said, somewhere, that you're thinking about selling the car? (drevil2.jpg) Attachments ---------------- drevil2.jpg (10KB - 150 downloads) | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | Mom with a neighbour in Selkirk, MB. A single mother who asked her to be in the delivery room, then LOST HER MARBLES delivering and ripped Mom's blouse! (Old slides 23.jpg) Attachments ---------------- Old slides 23.jpg (119KB - 152 downloads) | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | Thanks to all who've enjoyed these and responded...............This is Uncle Steve, who was a gun & antique collector/dealer extraordinaire. (Old slides 12.jpg) Attachments ---------------- Old slides 12.jpg (126KB - 134 downloads) | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | 1958 again. (Old slides 21.jpg) Attachments ---------------- Old slides 21.jpg (104KB - 137 downloads) | ||
Doctor DeSoto |
Location: Parts Unknown | Outside of some rather unflattering bathing suit designs, those folks of old sure did know how to dress ! Mom, with the big, furry black hat looks like she dressed to match the car ! Good stuff, Amigo. Thanks for posting. | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | Funny you should mention that! Here are pix from Nov. 07 I was planning on posting next. The "original owner"......... (IMG_0973 FL edit.JPG) Attachments ---------------- IMG_0973 FL edit.JPG (87KB - 139 downloads) | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | ........along with the salesman that sold her the car in '57! He lives in the same town, where he sold Chryslers until he was 75. Great guy and a WW2 RCAF veteran. (IMG_0988 FL edit.JPG) Attachments ---------------- IMG_0988 FL edit.JPG (89KB - 140 downloads) | ||
Sisu |
Inactive by Request Posts: 1292 Location: Lovely place | Wow, great pics! Especially nice to see the new ones and compare to the old ones. Thats real history and makes one understand how the car has been part of the everyday life of the family. Would be great once when I'm old, to post some pics on the forum and show everyone how it was when I was young, succesfull with ladies, hansom, intelligent... Sorry I'm dreaming again, but really would be great to own something for such a long time. The Dodge looks absolutely great! Cedric | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | Thanks again!.......I've had another group of the old slides converted, and there's a few more Mopar pix among them.......I believe this is Dad's 48 Chrysler that preceded the 55 Regent. Possibly taken in Dryden, Ontario. (48 Chrysler.jpg) Attachments ---------------- 48 Chrysler.jpg (105KB - 143 downloads) | ||
Red Ram |
Extreme Veteran Posts: 303 Location: P la P, Man | I'm told this is a different one my Grandfather owned. Nicknamed "The Bull Moose". *Note the old-time glass frost shields on the windshield! (North Farm (3).jpg) Attachments ---------------- North Farm (3).jpg (97KB - 148 downloads) | ||
