'59 Dodge police car Jump to page : 1 2 Now viewing page 2 [50 messages per page] | View previous thread :: View next thread |
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | BTW, the car should have 12"x 2/12" brakes, and extra-reinforced seat springing. About its Dana-type rear end, John, can you see its rear end ratio, or rotate the tire, to see if it's a Sure Grip, or what its ratio appears to be? | ||
hecksheads |
Regular Posts: 59 Location: N.W. FL | To me, that rear end looks like an 8 1/4" out of a '70s or '80s Mopar. | ||
Doctor DeSoto |
Location: Parts Unknown | Negative on the 8.75 The Danas have the removable rear cover and have a much less rounded look overall. 8.75's drop out the front with a solid back to the housing. | ||
lawrence |
Expert Posts: 3951 Location: Bama | How many bolts are in the inspection cover? Yeah, spin it, spin it. Also where was the car made? Come on John. | ||
Benji |
Veteran Posts: 101 Location: Walhalla, ND | Check the serial (VIN) plate. The 3rd digit should be a "9" indicating a "pursuit sedan". Serial number should look something like this M392-100001 or higher. The M indicates 59 model year, 3 is Dodge, 9 pursuit sedan, 2 Dodge assembly-Hamtramck (this could be different depending on final assembly location) and the sequential serial number started at 100,001 upwards. | ||
Fins/413 |
Extreme Veteran Posts: 530 Location: Wake Forest, NC | Here is a scan of the 1959 Ross Roy maual for pursuit vehicle and taxis. Looks like some neat options are added. (F-11a.jpg) Attachments ---------------- F-11a.jpg (94KB - 137 downloads) | ||
57plymouth |
Expert Posts: 3577 Location: Blythewood, SC | The taxi package looks interesting as well. I remember there was a 57 Plymouth taxi in a guy's yard near Greenwood, SC. He would NOT sell any cars or parts, but he inexplicably gave me a dash clock. Go figure. Maybe I should go harass him again. It's been 10 years since I was there... | ||
big m |
Expert 5K+ Posts: 7809 Location: Williams California | Benji - 2007-09-04 8:36 PM Check the serial (VIN) plate. The 3rd digit should be a "9" indicating a "pursuit sedan". Serial number should look something like this M392-100001 or higher. The M indicates 59 model year, 3 is Dodge, 9 pursuit sedan, 2 Dodge assembly-Hamtramck (this could be different depending on final assembly location) and the sequential serial number started at 100,001 upwards. The 3rd digit of the VIN# is, indeed, a 9. Thanks for the info. ---John | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | I'll keep the VIN-info stuff, (got new info) over on the Fender Tag Decoding board, but the differential would appear to be a 8 1/4" unit, due to the rear-access plate on it, but, does anyone recognize the brake drums (without chatter-springs on them, and with non-protruding axle-ends?) Also, the car has at least 6-full leaf springs, visible, and possibly seven. OEM would have been 5 1/2, or maybe 6 leaves. If the axle was changed-out (why?) wouldn't the leaf springs have gone 'with' it? Did 8 1/4" rear ends ever have 6 or 7 leaf springs installed with it? | ||
dartguy699 |
Regular Posts: 63 | the rear axle assy intriques me in that it does not appear to have the axle nuts that hold the drums on. i wish i could have retro fitting one to my 60 if that is the case! jim | ||
narleycharlie |
Expert Posts: 1812 Location: Slidell La. | d500neil - 2007-09-06 4:17 PM I'll keep the VIN-info stuff, (got new info) over on the Fender Tag Decoding board, but the differential would appear to be a 8 1/4" unit, due to the rear-access plate on it, but, does anyone recognize the brake drums (without chatter-springs on them, and with non-protruding axle-ends?) Also, the car has at least 6-full leaf springs, visible, and possibly seven. OEM would have been 5 1/2, or maybe 6 leaves. If the axle was changed-out (why?) wouldn't the leaf springs have gone 'with' it? Did 8 1/4" rear ends ever have 6 or 7 leaf springs installed with it? Why would the springs have to go with the axel ? The spring bolts on these old cars are rusted/frozen and will generally be a bitch to remove . Axel is a breeze to swap out , swapping the springs adds a lot of time . Thats definately a later axel , late 70s or 80s . Edited by narleycharlie 2007-09-06 8:02 PM | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | The spring assemblies look to have too many leaves/leafs(?) in them; swapping-out leaf springs is rather unusual (but, so is swapping out a diffie, too). It certainly would ride well, with adequate rear springing; wonder what ratio the car is running??? | ||
FinFury57 |
Elite Veteran Posts: 693 Location: Kangasala, Finland | d500neil - 2007-09-07 4:14 AM The spring assemblies look to have too many leaves/leafs(?) in them; swapping-out leaf springs is rather unusual (but, so is swapping out a diffie, too). It certainly would ride well, with adequate rear springing; wonder what ratio the car is running??? Too many? I counted 6 leaves. They came standard in '57-'58 Fury - probably in HD police model too... | ||
Doctor DeSoto |
Location: Parts Unknown | On that Ross Roy manual page, note the listed option of BOTH a Hi-Output generator, ..... OR an ALTERNATOR. I cannot recall ever seeing an ALTERNATOR on a 59, or even a 60 ! I recall the 60 exhaust manifold is part of the bracketing for a generator that was very different with the new alternator set up that I always thought was introduced in 1961. Anyone ever seen a pre-61 car with an original alternator set up ? Photos ? Velly intellesting ! | ||
1959Dodge |
Expert Posts: 2244 Location: Yorba Linda, Ca | Alternator History Chrysler first introduced the alternator in the 1960 model year. Due to the increased electrical loads on the charging system the old generator could no longer provide enough amperage (electrical volume) to operate all of the electrical components on the car. http://www.mymopar.com/alternator.htm | ||
58 DESOTOS RULE |
Expert Posts: 2308 Location: The Bat Cave, Fairborn, OH | The 1960 Dodge Dart I once owned had a generator not an alternator, but Chrysler may have installed alternators in other 1960 models. I think the 1960 Valiant had an alternator for example. | ||
dartguy699 |
Regular Posts: 63 | 1960 valiant was the only 60 to have the alternator on the regular cars (police/taxi used a different type) and the 61 line had them across the board. i dont know how much of the police/taxi cars were alternator equipped in 1960 jim | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Going back to the leaf springs, in 1957 -1958 (not sure, about 1959; too lazy to look it up, now), Dodge had 5 leaf springs on its non-stationwagon models , which were actually 4 1/2 leafs, as the shortest one only extended to the axle housing, so that it was not visible, when the leaf springs were viewed from the rear-end of the car. The stationwagon models probably had 5 1/2 leafs, but might have had 6-full leafs under them. John's car is showing 6 leafs, when viewed from the rear, so that there might be another 1/2-leaf which is not visible (when viewed from the rear-end). The Furys had 5 1/2 leaf springs, too ---Ok: 6-technically, but 5 1/2 functionally. I know that 300's had "seven" leafs, and I think that those seven leafs may have been full-ones, and not 6 1/2 leafs. | ||
vedette |
Expert Posts: 3069 Location: Scotland | here's a '58 CHP Dodge http://adcache.collectorcartraderonline.com/10/3/1/89552131.htm | ||
big m |
Expert 5K+ Posts: 7809 Location: Williams California | The rear end is not an original as suspected. It appears to have been installed just to make the car a 'roller' after the original unit was removed. The spring perches are about an inch and a half wider than the originals.---John | ||
