Ball and Trunnion Drama Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
GrumpsMcGee |
New User Posts: 4 Location: Huntington Beach,CA. | Hiya fellas, I know this subject has been gone over a few times,but i need a little help. I got a 57' Coronet which has the ball and trunnion front u joint.I'm trying to rebuild it,but i havent a clue how to get that darn joint pin out! I read past posts about doing away with it completely,and replacing the boot but no advice on how to repair the u joint itself. Can i remove the pin with some average tools or would i have to take it in to a shop? Thanks~ | ||
DeSotohead |
Board Moderator Posts: 3186 Location: The not-so-great, dirty-white North ( Michigan) | A lite-duty arbor press will remove it. I have also gotten them out with a large C-Clamp and a deep socket. Make sure you have sufficient depth in your tube you use for the receiver of the pin. | ||
57plymouth |
Expert Posts: 3577 Location: Blythewood, SC | You need a press to remove the pin. It's the only way to get it out. It is in WAY too tight. | ||
Shep |
Expert Posts: 3402 Location: Chestertown, NY ( near Lake George) | I wouldn't get it out unless it is worn or damaged, it is usually in very tight and recentering it back in is very tough also. Edited by Shep 2008-04-11 8:10 PM | ||
Expert Posts: 3780 Location: NorCal | Every one I've dealt with would laugh at a heavy duty arbor press, even my 20-ton hydraulic press groans to press out the pin. The trick to centering the pin is good lube and an accurate stop. | ||
DeSotohead |
Board Moderator Posts: 3186 Location: The not-so-great, dirty-white North ( Michigan) | 57plymouth - 2008-04-11 7:51 AM You need a press to remove the pin. It's the only way to get it out. It is in WAY too tight. Hmmmm... I removed the one from my Adventurer B&T in my garage (NO arbor press there) with a big U-Joint press and anvil set! Maybe mine was at the loose end of the clearance table. Mind you, a U-Joint Anvil/Vise set (Snap-On) is a pretty robust tool, with a HUGE fine thread srew and requires like a 1" socket to fit the head, so it is more than the average bear of a C-Clamp...... BTW...I do agree about reinstalling, in that centering the pin is a B*TCH! So I had a tool machined that only allows me to press it to the correct depth.... | ||
345 DeSoto |
Expert Posts: 1302 Location: Skaneateles,NY(summer)/Port St.Lucie,FL(winter) | ...OR before you press the pin out, LIGHTLY file a SLIGHT reference mark with a tri corner file, on it. File one on both sides of the hole... | ||
57plymouth |
Expert Posts: 3577 Location: Blythewood, SC | I guess I'm lucky. I got mine centered on the first shot with a 12 ton press. | ||
DeSotohead |
Board Moderator Posts: 3186 Location: The not-so-great, dirty-white North ( Michigan) | 345 DeSoto - 2008-04-11 6:29 PM ...OR before you press the pin out, LIGHTLY file a SLIGHT reference mark with a tri corner file, on it. File one on both sides of the hole... Works unless you are using a *NEW* pin, like I generally do...... | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | So... line up the old and new, and transfer the mark! | ||
narleycharlie |
Expert Posts: 1812 Location: Slidell La. | Why not just update the ball and trunion and replace with the flange style ujoint and slip yoke . | ||
Expert 5K+ Posts: 7432 Location: northern germany | because the ball and trunions, properly serviced, last forever. | ||
narleycharlie |
Expert Posts: 1812 Location: Slidell La. | Forever is a good thing , forever and a DAY is what worries me . | ||
GrumpsMcGee |
New User Posts: 4 Location: Huntington Beach,CA. | That sounds like a good idea,my original seems fine. Heres the kicker though, the kit i bought from Bernbaum looked fine until i tried to put the bearings on the pin....they don't fit! Both the new and the old pins seem the same, but i think the needle bearings are different sizes! Did they use two different sizes , or is this Bernbaum dude not only selling crappy u-joint boots,but also junk kits?? Thanks for the reply | ||
GrumpsMcGee |
New User Posts: 4 Location: Huntington Beach,CA. | Bummer is i dont have a garage ,but merely a carport in which i keep all my tools in my trunk..haha I think i'll leave the pin in,and just stick the new bearings on ...if only they would fit! Bernbaum strikes again!ARG! Thanks for da help~ | ||
57plymouth |
Expert Posts: 3577 Location: Blythewood, SC | I would guess you are another Bernbaum victim. Just for reference, I bought a complete kit with a new housing off E-Gag for $50. Of course, I ruined the boot and modified a CV joint boot to seal it, but it's working just peachy. | ||
DeSotohead |
Board Moderator Posts: 3186 Location: The not-so-great, dirty-white North ( Michigan) | GrumpsMcGee - 2008-04-13 7:38 AM Bummer is i dont have a garage ,but merely a carport in which i keep all my tools in my trunk..haha I think i'll leave the pin in,and just stick the new bearings on ...if only they would fit! Bernbaum strikes again!ARG! Thanks for da help~ There is more than one kit for the Detroit B&Ts...Mine is the larger "57" series, not the smaller. So you need to do the following with Bernbaum.... Measure the bolt spacing on the housing, call Bernbaum, and give that to ANDY.... He will then get you the correct kit (large or small) | ||
