56 Dodge decode
   Forward Look Technical Discussions -> Fender/VIN Tag and Broadcast Sheet DecodingMessage format
coronetx2
Posted 2008-10-17 6:32 PM (#148621)
Subject: 56 Dodge decode
100252525
looking for info on 56 Dodge
SCHEDULE
02 10 11 027
BODY 816
PAINT 369
TRIM 531
SP2
Edited by coronetx2 2008-10-17 6:45 PM
d500neil
Posted 2008-10-17 7:44 PM (#148627 - in reply to #148621)
Subject: Re: 56 Dodge decode
5000500050002000200010025
Philip: 8=v/8
1=Coronet
6=2 dr HT
That paint code I don't have in my files.
TRM= black& white cloth/vinyl
build date: o.o.a. 2/10/56
SP-2: I don't know.
Have you looked up/behind the glove box, to seeif your car's Broadcast Sheet might be masking-taped there?
I really need to to see/find a 1956 B.sheet.
coronetx2
Posted 2008-10-17 8:16 PM (#148629 - in reply to #148627)
100252525
No build sheet to be found.
car is strip down to bare metal.
I think the colors were black top maroon saddle and Chinese rose lower.
car also has lancer scripts.
d500neil
Posted 2008-10-17 9:21 PM (#148647 - in reply to #148629)
Philip, the hardtop models were known as "Lancers"
If you've got the VIN plate, you should buy a copy of the factory's IBM build card copy, as you'll see at the top Sticky-message
on this board.
This IS an unusual color combination; very attractive!
55CRL
Posted 2008-10-18 5:08 AM (#148662 - in reply to #148647)
500100100100100
Philip, do you have any picture before it was stripped down to bare metal? Would love to see the color combo.
I've got a couple of b/w pics of a 4-door Lancer seen in Sweden back in the early 80s but no longer in the Swedish registry.
(Dodge 56crl.jpg)
(Dodge 56crl_rear.jpg)
Attachments Dodge 56crl.jpg (69KB - 229 downloads)
Attachments Dodge 56crl_rear.jpg (66KB - 236 downloads)
coronetx2
Posted 2008-10-18 12:40 PM (#148683 - in reply to #148621)
100252525
I do not have any pics of the car in original colors as it has been painted many times over.
I did find hand written color combination of black,garnet and rose on cowl behind inner fender.
thanks for any and all help.
(56 colors.JPG)
(55 coro.JPG)
(56 data tag.JPG)
Attachments 56 colors.JPG (50KB - 230 downloads)
Attachments 55 coro.JPG (39KB - 235 downloads)
Attachments 56 data tag.JPG (38KB - 220 downloads)
Chrycoman
Posted 2008-10-22 4:08 PM (#149224 - in reply to #148627)
1000500100100100
d500neil - 2008-10-17 4:44 PM
Philip: 8=v/8
1=Coronet
6=2 dr HT
SP-2: I don't know.
Although there is no "369", there is a "569-3" :
Roof - Jewell Black
Sweep - Garnet Metallic
Lower - Chinese Rose
"569" itself is :
Upper - Garnet Metallic
Adding "-2" means it would have a Jewell Black roof. Perhaps that is what "SP 2" refers to?
coronetx2
Posted 2008-10-22 7:41 PM (#149252 - in reply to #148621)
Subject: RE: 56 Dodge decode
100252525
In the next week or three i 'm going to put out the $45 bones.
And find out just what this car really is or isn't.
Again thanks to all I"ll keep ya posted.
d500neil
Posted 2008-10-23 6:17 PM (#149377 - in reply to #149252)
Bill, and Philip, that "3" on Phil's inner fender almost certainly applies to that "-3" that you show, for a 569-3 paint scheme.
Are there any OTHER "69" paint schemes listed on the 1956 paint codes????
If not, and if there were only 3-digits provided for, for ALL the color schemes on the P/T plate, under the "PAINT" column,
it would make (some-) sense that a "569" scheme might morph into a 3-69, or, "369" meaning a 3-tone paint scheme, and,
that the "SP" code with a "2" might designate the black painted roof.
If so, it's a little unfortunate that the factory might have chosen a "2" to designate a black color, because in almost all other
color-code instances, the factories have used a "1" (or, an "A") to confirm a black finish. Otherwise, I would have guessed
that that "2" would have designated a white-finish.
d500neil
Posted 2008-10-23 6:22 PM (#149379 - in reply to #148621)
And, the 1956 paint coding might have been so confusing, that a line supervisor was compelled to spell-out
precisely how that car was to be painted, on its inner fender/firewall area (at least, AFTER the
first finish coat was applied!!)
Edited by d500neil 2008-10-23 6:24 PM
