Electroluminescent lighting / Panelescent lighting dashboard Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Board Moderator & Exner Expert 10K+ Posts: 13051 Location: Southern Sweden - Sturkö island | What is electroluminescent lighting? How can speedometer and gauges shine without lights, tubes or gas? The answer lies in ceramic technology. The board of a gauge is constructed of laminated layers of material that starts glowing when they are fed with a high volt alternating current. As a result, the needles and board of a gauge are a light source in itself. A typical gauge or indicator consisting of several layers; One layer of vitreous enamel coated steel is the gauge base. One layer of solid ceramics is applied over that. One layer containing electroluminescent phosphorus in ceramic base. One transparent electrically conductive layer applied over that. Last a layer of glassy coating is added for the final touch. This is called an electroluminescent light (EL) Power; The speedometer, gauges and needles are driven by a power source, known as oscillator or power pack, which converts 12 volts DC to 200-300 volts alternating current of 250 cycles per second. This amazing system used in 1960, 1961 and 1962 Chrysler, in the 1960s, 1961, 1962 and 1963 Imperial, as well as in 1966 and 1967 Dodge Charger. At Chrysler, and Imperial is the power source mounted in the dashboard on the driver's side against the inner cowl. On the Dodge Charger it’s mounted on the dashboard behind the glovebox. In Chrysler ’60-’62, the AstraDome contains many EL- lamps; 1 The EL on the speedometer board 2 The upper EL for the odometer 3 The lower El for the odometer 4 The speedometer EL needle 5 The EL on the ammeter board 6 The ammeter EL needle 7 The EL on the oil-gauge board 8 The oil-gauge EL needle 9 The EL on the tank-meter board 10 The tank-meter EL needle 11 The EL on the temp-meter board 12 The temp-meter EL needle Then there’s EL lamps in the radio and it’s dial needle and in the clock and its 3 hands. The use of EL lamps had many benefits, the cool glowing and glarefree light was much appreciated then and even today many people look at the floating dash in almost disbelieving their eyes. The EL-lamps are almost indestructible and will keep on shining more than the estimated 10.000 hours when they where constructed. General trouble shooting; Problem: Dash is totally black – nothing lights up at all Cause: The rheostat on the light switch is corroded – bad contact Solution: Demount and clean the light switch rheostat Cause: There’s one EL-lamp shorted out (if one shorts, all go black) Solution: Disconnect one EL-lamp at the time until some of them lights up (disconnect the white cables) Problem: The dash lights up, but fades to black or almost black Cause: The Power Pack (oscillator) is faulty Solution: Change and/or renovate the oscillator Problem: The needle of a gauge does not light up Cause: The linz wire that connects the needle to the feed cable is broken or oxidised (the current flows on the outside of the linz wire and can be obstructed by too much oxide) Solution: Clean the connection point and solder the linz wire back in place. If you need further help, PM me. (Resize of Amp_gauge_back.jpg) (Resize of IMG_3610.jpg) (Resize of IMG_3611.jpg) (Resize of Speedoboard.jpg) (Resize of Size of EL-lamp.jpg) (Resize of Label on EL-lamp.jpg) (Resize of Spare_AstraDome.jpg) Attachments ---------------- Resize of Amp_gauge_back.jpg (48KB - 671 downloads) Resize of IMG_3610.jpg (32KB - 464 downloads) Resize of IMG_3611.jpg (34KB - 438 downloads) Resize of Speedoboard.jpg (22KB - 813 downloads) Resize of Size of EL-lamp.jpg (18KB - 910 downloads) Resize of Label on EL-lamp.jpg (41KB - 724 downloads) Resize of Spare_AstraDome.jpg (25KB - 1205 downloads) | ||
NewportBob |
Regular Posts: 97 Location: Sioux Center, IA | Wow! I wish all this info had been gathered when I was working over mine! If you want to dig further, I found this discussion helpful: http://www.imperialclub.com/Repair/Electrical/EL.htm Bob | ||
JimK |
Veteran Posts: 259 Location: Detroit MI area | A write up/photos on the differences between the '60, 61 and 62 dashboards, astradomes and gauges. http://www.chrysler300club.com/rcmstuff/dash/dash.html Jim Krausmann Detroit | ||
Board Moderator & Exner Expert 10K+ Posts: 13051 Location: Southern Sweden - Sturkö island | Bump (Resize of IMG_4687.jpg) (Resize of IMG_4693.jpg) (Resize of IMG_4694.jpg) (Resize of IMG_4695.jpg) (Resize of IMG_4696.jpg) Attachments ---------------- Resize of IMG_4687.jpg (57KB - 472 downloads) Resize of IMG_4693.jpg (22KB - 446 downloads) Resize of IMG_4694.jpg (24KB - 449 downloads) Resize of IMG_4695.jpg (19KB - 441 downloads) Resize of IMG_4696.jpg (22KB - 405 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13051 Location: Southern Sweden - Sturkö island | Kilometer trick on a miles speedometer While repairing and testing my spare AstraDome which I will mount in the car this winter, I came to think about one speedo EL-lamp with cracked paint, so I made some tests with that one first. Then I masked carefully and cut away the paint for to make some graduations longer for the most common speed limits here in Sweden. This way I have a clear indication even under night driving. (Resize of IMG_4688.jpg) (Resize of IMG_4690.jpg) Attachments ---------------- Resize of IMG_4688.jpg (48KB - 1928 downloads) Resize of IMG_4690.jpg (21KB - 452 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13051 Location: Southern Sweden - Sturkö island | AstraDome removal The shop manual procedure is to actually demount the glass together with the gauge clusters, while the speedometer remains mounted. This actually works, but there's a lot of tension from the surrounding bezel - it's best to loosen the screws that holds the bezel (bummer screws - they are not studs, so they turn around - but doable) (Resize of IMG_4701.jpg) (Resize of IMG_4704.jpg) Attachments ---------------- Resize of IMG_4701.jpg (65KB - 572 downloads) Resize of IMG_4704.jpg (51KB - 512 downloads) | ||
skylineeeeee |
Member Posts: 24 | I've just bought an Astradome on ebay because even if I have no cars for now I like it so much that wanted to have one at home. I would like it to turn on, but for now I have no power pack with me but considering how simple is the circuit I would like to build one by myself. the only trouble is that I have no data about the transformer. this is the electric diagram i've found http://www.imperialclub.com/Repair/Electrical/powersupply.jpg but have no idea how to associate the "readings from T-1" to a set of valid datas for a transformer. if you have any good ideas, you are welcome! Edited by skylineeeeee 2015-12-07 2:31 PM | ||
hemidenis |
Expert Posts: 3888 Location: Northen Virginia | Those T1 values are the the impedance of the transformer, just to test if yours is working properly. Are you trying to build your own power pack? | ||
Mr Bob |
Member Posts: 9 Location: Bellingham, WA | There is a guy selling newly made EL powerpacks on eBay for about $79. | ||
Board Moderator & Exner Expert 10K+ Posts: 13051 Location: Southern Sweden - Sturkö island | Yes, but those ones have too high output and they sound like a pig in bondage. I don't know for sure, but I Think the EL-lamps will be damaged by too high voltage over time. As I remember, one of those put out Close to 500VAC and that's roundabout the double needed. | ||
NicksGarage |
Expert Posts: 1223 Location: Ramona, CA | Got my dash lighting working today. Turns out the oscillator wasn't plugged in. The reostat only works in one place so I'll try changing the headlight switch tomorrow. I've got some sort of short somewhere. If the fuse for the cigarette lighter (in the console) is connected, the ignition stays on all the time. Even with that unplugged, the left park light doesn't work and if the headlight switch is in the park mode, the left turn indicator in the dash stays on and the turn signal goes really slow on that side. In off or headlight mode it blinks the normal speed. And now the dome lights and map light don't work. The turn signals and gauges intermittently don't work as well. Fuel gauge definitely has a problem. The battle continues. (el_lighting.jpg) Attachments ---------------- el_lighting.jpg (33KB - 864 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13051 Location: Southern Sweden - Sturkö island | Nick, don't waste too much time on the light switch - the rheostat controls the 12VDC feed to the oscillator, but the range is very narrow even if the rheostat works as it should. Pratically, you can chose between full light and almost full light and black. Check that the correct bulbs are mounted in the flashers - many times we ceard of single filament bulbs instead of the dual filaments that should be mounted. The single filament bulb will backfeed the parking lights or vice versa with the flashers Edited by wizard 2016-03-27 3:25 AM | ||
NicksGarage |
Expert Posts: 1223 Location: Ramona, CA | I did have the wrong dual filament bulbs in the front so I changed them but that didn't make a difference. The sockets were crusty so it took a bit of work to clean them up and get the new bulbs in. Used dielectric grease on the new ones. I'll track it down I'm sure. Do you know what the big light green wire with the inline fuse goes to? It hooks to one of the circuit breakers on the left side. Had to replace that cable and fuse holder but not sure what it powers. (green_wire.jpg) Attachments ---------------- green_wire.jpg (98KB - 356 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Hi Wizard
At the gauge cluster of my Letter only the tip of the needle for the fuel level gauge doesn't light up. At daytime (the cluster is laying in my living room) the tip of this neelde doesn't look dirty. Any idea? I'll appreciate your answer very much. Thank you.
Happy Motoring!
Dieter
BTW: your decribtion is wonderful. thank you. | ||
Board Moderator & Exner Expert 10K+ Posts: 13051 Location: Southern Sweden - Sturkö island | @ Nick, that's the wire/fuse for the rear ash tray if I remember correctly. @ Dieter, the ceramic layer has most probably a crack and thereby the tip doen't light up. I have a spare speedometer needle with this problem. | ||
NicksGarage |
Expert Posts: 1223 Location: Ramona, CA | wizard - 2016-03-27 10:21 AM @ Nick, that's the wire/fuse for the rear ash tray if I remember correctly. I'll check that out. Thought that was hooked up to the console wiring. Fortunately I had a good wire and fuse holder from my parts car to replace it with. | ||
NicksGarage |
Expert Posts: 1223 Location: Ramona, CA | Well I thought I may have found the problem but wasn't it. Search continues. (light_harness01.jpg) Attachments ---------------- light_harness01.jpg (88KB - 325 downloads) | ||
plumfloored |
Regular Posts: 54 Location: Avondale, AZ | Incredible write up. Thanks wizard. | ||
