"Make-Up" your Car! Jump to page : < 1 2 3 4 5 6 ... > Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Hood: Correctly centering the Hood without damaging the Edges was a big issue, the disposable gap on my car beeing about only 0.06* for each side. A solution for a precise and durable positioning was needed. On the rear end, the Hood was too low, when correctly adjusted at the corners. I mounted 4 rubber bumpers, modified to the needed height, left and right corner one, the other two according the picture. Now the edge from one corner to the other is and stay parallel in height. On each side of the Hood I put a Round-Head Screw, adjusting the height for exact centering with washers. To assure a good and tight fixing the original centering rubber should be squeezed as shown in the picture. Now the Hood is exact centered all around, no cracked edges and no vibrations of the hood - a perfect fitting even at very small gaps.
Edited by sermey 2008-12-25 2:04 PM (DSC02023L Hood rear before.jpg) (DSC02037L Hood rear after.jpg) (DSC02036L Positioner Hood Rear.jpg) (DSC02038L Center Positioners.jpg) (DSC02040L Positioner Sizes.jpg) (DSC02024l Hood Gap Left.jpg) (DSC02025L Hood Gap Right.jpg) (DSC02033L Positioner Left.jpg) (DSC02032L Hood Rubber Left.jpg) (DSC02042L Final Result.jpg) Attachments ---------------- DSC02023L Hood rear before.jpg (54KB - 832 downloads) DSC02037L Hood rear after.jpg (48KB - 836 downloads) DSC02036L Positioner Hood Rear.jpg (37KB - 889 downloads) DSC02038L Center Positioners.jpg (36KB - 849 downloads) DSC02040L Positioner Sizes.jpg (36KB - 863 downloads) DSC02024l Hood Gap Left.jpg (65KB - 970 downloads) DSC02025L Hood Gap Right.jpg (54KB - 819 downloads) DSC02033L Positioner Left.jpg (60KB - 831 downloads) DSC02032L Hood Rubber Left.jpg (53KB - 839 downloads) DSC02042L Final Result.jpg (62KB - 839 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | sermey - 2008-12-19 10:07 PM Mirror-Matic: No visible Cable from the Mirror-Matic to the Dashboard. Drill a duct inside the Stand (about 3.5mm) and use a high flexible isolated wire. (to know: Mirror-Matic is always ON. The OFF Switch just interrupts the Control Signal. I have a separate OFF Switch under the Dashboard to save Tube Life and Current) Another View of the Stand. Is this Mount / Foot as Original? (DSC02022L Stand Mirror-Matic.jpg) Attachments ---------------- DSC02022L Stand Mirror-Matic.jpg (78KB - 826 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | catman - 2008-12-20 11:37 PM sermey - 2008-12-20 6:44 AM Where can we get them? Do they make them for sedan models? Any web site?Sill Plates: Today there are very nice Reproductions available in Sweden, at the time not disposable. As far I saw not painted.
I just spoke to Jan Fridberg in Sweden. He manufactures Dual Air Cleaners and Sill Plates in Aluminium in a high Quality. His direct contact: janfridberg@hotmail.com | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Rear Lamps: Theses Golden "Eye-Lines" have already attracted the attention of many people, using the same golden Foil as on the Door Handles. For a Dual Tone Car the corresponding Color would match even better - and it can be removed and redone instantly, without any chemical or disassembly. Print-out the PDF-File on A4 Sticking-Sheet (will be 1:1), then stick one sample on the Color Foil (color-Side) and cut-out around accordingly. Before applying fold the sample in the center for best positioning, remove the protecting layer, and at the end the sticked sample. Good News for Dodge 59 Owners? (If your Foil is heat-resistent (Laser Printer!) you not need a Sticking-Sheet and can print directly on the protecting layer of the Foil Check first!) Later on I will put another "Rear Lamps" talking on the Light. Edited by sermey 2008-12-26 4:52 PM (DSC00035 DODGE59 Rear Lamp .jpg) (DSC00200L Rear Lamps.jpg) (Dodge59 Rear Lamp Foil copy.jpg) Attachments ---------------- DSC00035 DODGE59 Rear Lamp .jpg (47KB - 844 downloads) DSC00200L Rear Lamps.jpg (76KB - 853 downloads) Dodge59 Rear Lamp Foil copy.jpg (82KB - 845 downloads) Dodge59 Rear Lamp Foil.pdf (42KB - 845 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Screws 1: "No rusty Scews anymore!" I whished and decided to use only stainless (rustfree, 18/8) Screws where not excessive Stability is required. Most Platings (zinc, chrome, nickel, promat, etc.) on iron/steel Screws are not a Guarantee for no rust in a Temperature, Acid and all Weather exposed Ambient. The Rust is programmed as soon the Plating is damaged, what already may happen when you use them the first time. On a white painted Car as mine, any rusty Water will left visible Tracks. The stainless Screws are much more solid than standard Screws. They can be modified in Lenght and Head-Shape as you need or like it, and finally be polished, as shown when just having simple Tools disposable. Important for a nice rounded Result: the Screw and the Tool must turn in a high Speed and in 90deg Direction each to other. The first Picture shows various Screws with polished Heads I used for my Car: Row3/5 Arm Rests, Row3/6 over the Head Lamps Dodge59, Row2/6 Door Latch. Mostly used on FWL-Cars Row 3/8-9 for Interior and Mirrors. Edited by sermey 2008-12-27 3:26 PM (DSC02045 Screw Types.jpg) (DSC02054L Polishing Tools.jpg) (DSC02060L Resizing Head.jpg) (DSC02057L Polishing Head.jpg) Attachments ---------------- DSC02045 Screw Types.jpg (108KB - 860 downloads) DSC02054L Polishing Tools.jpg (83KB - 809 downloads) DSC02060L Resizing Head.jpg (53KB - 841 downloads) DSC02057L Polishing Head.jpg (73KB - 797 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13054 Location: Southern Sweden - Sturkö island | I use the same method as Serge and I can confirm the good result obtained by using a drilling machine, mounting the object in the mandrel, running high speed in 90 degree angle agains the polish dish - stainless steel comes to mirror shine. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Hoses: There are many ways to get nice Hoses, using various Materials and Colors. The simplest is just to have stainless/rustfree Clamps and polish them as done with the Screws. See the difference standard - stainless. You can invest a fortune for the Hoses using sophisticated anodized Aluminium Ends and silver metallic Hose Coats, instead of black non-metal as I used. This black Coat keep its appearance, doesn't get mat or show any black oily Tracks. It is not expensive, easy to assemble and gives a discreet Look. There are different Sizes availabe as shown in the Picture. Only the Radiator End Covers I had to make with a Rest of the stainless Exhaust Tube, because not found (cut and polish!). After first mounting the hose and then the Coat, the black adhesive Tape around is for pre-fixing and avoiding possible damage by the Clamps. The Chrome Hose End Covers comes over the Clamp, leaving the Screw and End outside. The Clamp can be re-tighten at any time without removing any Part. (DSC02124L Vacuum Hose.jpg) (DSC02122L Radiator Hose.jpg) (DSC02125L Heater-Fuel Hose.jpg) (DSC02130L Hose Clamps.jpg) (DSC02128L Hoses Covers.jpg) (DSC02134L Hose Assembling.jpg) Attachments ---------------- DSC02124L Vacuum Hose.jpg (87KB - 820 downloads) DSC02122L Radiator Hose.jpg (85KB - 854 downloads) DSC02125L Heater-Fuel Hose.jpg (116KB - 819 downloads) DSC02130L Hose Clamps.jpg (63KB - 836 downloads) DSC02128L Hoses Covers.jpg (108KB - 894 downloads) DSC02134L Hose Assembling.jpg (57KB - 845 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Wires: As for Hoses there are various Solutions to package and protect the wires. First I was suggested to use "self-merging" Tape. Then I listed up my demands for "tubing" the wires/cables on my Car: - Add and remove Wires at any time without "restarting" the job. - Adapting the diameter when starting with one and ending with multiple Wires. - Possibility to Branch off a Cable at any position. - Flexible, compact and heat-resistant, in sufficient Lenght available. The (split) Tubes I used are shown in different Sizes (the big Sizes are missing). They can lead from one Size to the next Size by overlapping. For "closed" Applications two Tubes are being twisted one into another. Easy replaceable to another Size when adding or removing Cables. To cut with a Knife. Applications to see also on earlier Pictures. I think these Tubes could also be used for Water and Fuel Hoses!?! Edited by sermey 2008-12-30 10:40 AM (DSC02135L Alternator OneWire.jpg) (DSC02136L Crossover Sizes.jpg) (DSC02153L Wire Tubes.jpg) Attachments ---------------- DSC02135L Alternator OneWire.jpg (80KB - 835 downloads) DSC02136L Crossover Sizes.jpg (74KB - 822 downloads) DSC02153L Wire Tubes.jpg (65KB - 800 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Dual Antenna Gaskets: With my Car I got a complete Set of Rubber Parts. Most of them I could not use, the Gaskets for the Dual Antennas being to big. I looked for a compatible Rubber Profile, best I could find was a wide sealing Strip (see Picture) with a useable Profile (Border Width 2.4mm, Border Height 2.25mm, Support Thickness 1.5mm). I cut this in the minimum Lenght of circumference (at Width 8mm). In the Middle of this Stripe I cutout a corner to match the front angle of the Antenna Socket. With the Antenna already mounted but not tightened, I pushed fully in the Rubber Profile around the socket. On the rear, two other 90deg angles had been cutout on the job, the Lenght adapted to meet in the Center of the rear Side. (N.B I left the mounted Gasket in Picture Start Mounting!) Important: starting with the Front, the front scew underneath has to be tighten first for pre-fixing the Rubber. At this point the Rubber should be pulled on both sides along the Socket to find the correct 90deg angle position, before cutting out. Finally the second Screw of the Socket can be tighten, as the first too. The Gasket fits all around as illustrated. The Advantages of this Gasket: For replacing or changing, no Cables nor the Socket have to be removed. The Rubber is softer than the said Gasket and assures best Protection from entering Water in the Trunk. And last but not least, it looks professional. I added the last Picture showing how to tighten the Socket, because hardly accessible (first fix a long screw, then manually tighten the wing nut, no tools!) Edited by sermey 2008-12-30 5:39 PM (DSC02170L Left Side View.jpg) (DSC02171L Right Side View.jpg) (DSC02154L Preparing Profile.jpg) (DSC02174L Cut Front Corner.jpg) (DSC02169L Start Mounting.jpg) (DSC02202L Manually Thighted Socket.jpg) Attachments ---------------- DSC02170L Left Side View.jpg (92KB - 818 downloads) DSC02171L Right Side View.jpg (66KB - 847 downloads) DSC02154L Preparing Profile.jpg (50KB - 801 downloads) DSC02174L Cut Front Corner.jpg (29KB - 809 downloads) DSC02169L Start Mounting.jpg (69KB - 850 downloads) DSC02202L Manually Thighted Socket.jpg (70KB - 854 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Rear Dual Power Antennas: Most Mopar-Owners wishes to have Rear Dual Antennas. Then, they would like to have them as Power Antennas. I must say: It is really an eye-catcher watching to these two Antennas when coming out together - each one want to be the first on Top! I felt a mess all this many parts, and thinking when must change the Antenna Bar (!), if ever a replacement is disposable. I found it easier to built-in a Power Module than to rebuild the Standard Antenna. I took two most used Power Antenna Units (new), shorted the Aluminium Tube according the Height of the Mopar Socket, drilled a bigger hole in the Mopar Antenna Socket - thats it! Mounting - easy! Hold the Power Unit in the Trunk down-up first without fixing it, insert from top the Mopar Antenna Socket and fixed it. Now the correct Position where the Antenna has to be mounted is given. It needs just one long single Screw that leads direct through the Center of the Power Unit to the Fold of the Wheelhouse in the Trunk (see Picture).The lateral adjustment to be vertical was done with washers as distance elements (right side fits exact without any additional positioner). The two Antennas have to be parallel, view from ANY Position. Now: A broken bar can instantly be replaced. Simply remove the visible Bar Nut and pull the old Bar out. When inserted, the new Antenna Bar is automatically fed in. It is in stainless / rustfree Steel, polished will be shiny (as earlier mentioned the Screws and Hose Clamps). In OFF-Position the new Bar goes more inside than the Mopar Bar. I feel this even nicer - and a smaller risk that an unhappy Guy will brake them. The Bar is a little bit shorter than the original one, therefore has a better FM reception. Both Antenna Units are controlled in parallel by a separate Switch, mounted lefthand under the dashboard. Before the Mopar Antenna was laterally weak being fixed only on the Bodys Metal Sheet by the two Screws of the Mopar Socket. Now, the second Mount by the Power Unit assures a stiff Stability all around. To know: The Dual Antennas are originally RF-connected in parallel (Y). This worked well at the time with AM. With an FM-Radio Interference could occur. I connected the left Antenna to the Original AM Radio (Center Loudspeaker). The right Antenna goes to the FM Radio in the Glove Compartment (Surround STEREO Loudspeaker). Edited by sermey 2008-12-31 5:26 AM (DSC02178L Antenna Parts.jpg) (DSC02179L Power Unit.jpg) (DSC02198L Antenna Mounts.jpg) (DSC02202L Antenna Connection.jpg) (DSC02181L Bar Replacement.jpg) (DSC02208L Bar Nut.jpg) (DSC02204L Antenna Height.jpg) (DSC02208L Antenna Full View.jpg) (DSC00195L Dual Power Antennas.jpg) Attachments ---------------- DSC02178L Antenna Parts.jpg (56KB - 841 downloads) DSC02179L Power Unit.jpg (53KB - 834 downloads) DSC02198L Antenna Mounts.jpg (90KB - 819 downloads) DSC02202L Antenna Connection.jpg (97KB - 836 downloads) DSC02181L Bar Replacement.jpg (26KB - 906 downloads) DSC02208L Bar Nut.jpg (45KB - 813 downloads) DSC02204L Antenna Height.jpg (44KB - 878 downloads) DSC02208L Antenna Full View.jpg (55KB - 827 downloads) DSC00195L Dual Power Antennas.jpg (75KB - 786 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Front Grill: Another "Make-Up" the golden anodized Front Grill. If like or not, just must see! I found otherwise too much silver. Pictures taken at US-Car Meeting when won "Best of Show": Me and my 1959 Dodge Custom Royal Lancer Convertible. Edited by sermey 2008-12-31 5:15 AM (DSC00022L Golden Grill.jpg) (DSC00037L Front.jpg) Attachments ---------------- DSC00022L Golden Grill.jpg (109KB - 801 downloads) DSC00037L Front.jpg (99KB - 809 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Exhaust Outlets: Another tricky "Make-Up" or say Show-Element are the Quad Exhaust Outlets. It remember at nice, long Blond-Hair Ladies, the Hairs being "Dummies", but we still like and look at them. I found the Dual Exhaust Outlets too much in the Center. Adding two additional virtual Outlets moves them optically to the right Direction outside. Among various available items I selected these stainless Outlets because they matched best to the rear Side-Profile of the 1959 Dodge. The mounting items, as illustrated, are also in stainless / rustfree Steel. This Mount System allows to adjust individually the Distance between the twin Outlets. Here again: this can be restored at any time to its original state! Edited by sermey 2008-12-31 6:24 AM (DSC00043L Quad Exhaust Outlets.jpg) (DSC00019L Dual Exhaust Outlet.jpg) (DSC00069L Exhaust Outlets.jpg) (DSC00013L Quad Outlet Mounts.jpg) Attachments ---------------- DSC00043L Quad Exhaust Outlets.jpg (66KB - 820 downloads) DSC00019L Dual Exhaust Outlet.jpg (97KB - 823 downloads) DSC00069L Exhaust Outlets.jpg (64KB - 796 downloads) DSC00013L Quad Outlet Mounts.jpg (74KB - 782 downloads) | ||
BigBlockMopar |
Expert Posts: 3575 Location: Netherlands | To me, that convolute tubing screams late 70s enginebay to me and I've hated it ever since I first saw it. Definitly not a "Make-UP" in my eyes Pretty much same goes for the cheap Spectre hose-wrap. Yuk! On a driver, one way to get caught with fuel-spills in de engine-bay is to put that braided stuff in there so you'll never see the condition of the fuelline underneath. The rubber usually dries up and the hoses start to develop cracks and tears and can start leaking at/on/during the most inconvenient locations. Other than that, nice info and some good tips there. Thanks for sharing! | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | BigBlockMopar - 2008-12-31 5:56 PM To me, that convolute tubing screams late 70s enginebay to me and I've hated it ever since I first saw it. Definitly not a "Make-UP" in my eyes Pretty much same goes for the cheap Spectre hose-wrap. Yuk! On a driver, one way to get caught with fuel-spills in de engine-bay is to put that braided stuff in there so you'll never see the condition of the fuelline underneath. The rubber usually dries up and the hoses start to develop cracks and tears and can start leaking at/on/during the most inconvenient locations. Other than that, nice info and some good tips there. Thanks for sharing! Nice open minded comment, Herman. You are right, many "Make-Ups" of today are crazy - not only on Cars. Some like it, other don't. My aim with this tread is to motivate many Car owners to "upgrade" their cars with moderate effort, but visible effect. Here I just present what I did on my car now 10 Years ago, and I am happy when people look at, may find something useful and / or just state comments as you. Thank you. Now to the Hoses: Yes, cannot see the condition of this hoses - nor of my veins! Today hoses are not just Rubber as 50 Years ago. These old ones cracks and tears as you correctly alerted. The Material Technology has experienced extreme Developments in the last years. According the application there are Hoses in any other Material than Rubber (PVC, Polyurethan, Silicon, Elastomer, Nitril) for Longlife use. The fuelline hose I use is especially designed for this, it has already a stuff around, wraped again for uniformity reasons. Bought recently again for my new Dual Quad Project I will report here soon. To the Spectre Hose Wrap: I liked this Design and have given my Argumets for. It was not a question of costs. Cheap doesn't mean bad. My Golden Coating on the Knights costs nothing, but is even more shiny than pure Gold. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Screws 2: Self-tapping Screws are most efficient in the manufacturing process. They are self-centering in direction and angle, in opposite to Thead-Screws. Nevertheless I have substituted most self-tapping Screws by stainless / rustfree Thread-Screws. - no damage of newly painted body (rust) - some holes got too big - option for other heads - higher precision For this I had to insert the nuts (on body before painting) using a Hand-Tool. The mirrored item is the unvisible clip used in Pic2. Some outside accessible Screws I replaced with Intra Hexagon Head Screws (?) for they cannot be removed with any pointy knife, as possible with Standard Cross Head Screws (see Rear View Mirror).
Edited by sermey 2009-01-01 1:55 AM (DSC02232L Mirror Mount.jpg) (DSC02231L Convertible Mold Mount.jpg) (DSC02233L Convertible Rear Top Mount.jpg) (DSC02230L Nut Press Tool .jpg) Attachments ---------------- DSC02232L Mirror Mount.jpg (41KB - 808 downloads) DSC02231L Convertible Mold Mount.jpg (70KB - 825 downloads) DSC02233L Convertible Rear Top Mount.jpg (48KB - 795 downloads) DSC02230L Nut Press Tool .jpg (54KB - 798 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Window Rubber: Restoring another US-Car years ago I used successfully the same method to replace the damaged and missing Window Rubber. The lower Door Windows Channel was totally rusted. On my DODGE, the Rubber of the Pivot Windows was broken, any attempt with a cutted Rubber Stripe failed, the Windows didn't hold enough, at the curves the Rubber was shrinked and looked very bad. Thus I used again my old method: I put black Liquid Silicon Gasket in the chrome channels. Then I centered the Windows inserting small wood positioners inside, on the left and right side, and re-filled the gaps around with Liquid Silicon Gasket. After minimum one week or even longer the Silicon should be hardened trough, remaining softish, ready to cut out precisely the overflowed Silicon with a Knife (not cut towards the window!) . Now, the Window is fixed all around, absolute water-proof and exact flush with the Chrome Channel, even more accurate than using the original rubber because custom-sailored. I suggest this also for Door Windows when the Rubber Profiles are not available, or for repair leaky Windshields, Remermber: Silicon Products cannot be painted! Any black Silicon Sealer can be used, should be heat resistant within -40 to +180deg, UV and all-wheather resistant (look at the Specs). Now I just found them ffrom the Producers of "Automotive Gasket" in the Internet and post it (sorry only in German). Same or similar surely available in US.
Edited by sermey 2009-01-01 2:12 AM (DSC02241L Window Rubber.jpg) (DSC02242L Cutting Out.jpg) (DSC02243L Silicon Gasket.jpg) (Automotive Gasket.jpg) Attachments ---------------- DSC02241L Window Rubber.jpg (68KB - 840 downloads) DSC02242L Cutting Out.jpg (63KB - 853 downloads) DSC02243L Silicon Gasket.jpg (54KB - 824 downloads) Automotive Gasket.jpg (109KB - 791 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Rear View Mirror Glass: Restoring my Car I had to rechrome the Rear View Mirrors too and had for this to brake out the Glasses. I bought two bigger replacement Glasses as used for Trucks and let them cut excatly fitting in the now rechromed housing. To fix them I used again the before presented black Silicon - bonded and sealed in one! (on the Picture you can as well see in black the left and right Hood Positioners) To add: I purchased two different Glasses, the one flat for the left side as used in all Mopar Mirrors, the other curved for the right side in order to get a wider viewing Angle (see Picture), as used in all todays cars. Last Month I saw such a flat Mirror Replacement for Mopars in eBay, I post the Picture. Edited by sermey 2009-01-01 3:18 AM (DSC02246L New Mirror Glass.jpg) (DSC02244L Curved Mirror Glass.jpg) (2008 eBay Mirror Glass.jpg) Attachments ---------------- DSC02246L New Mirror Glass.jpg (63KB - 811 downloads) DSC02244L Curved Mirror Glass.jpg (40KB - 839 downloads) 2008 eBay Mirror Glass.jpg (79KB - 818 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Four-Way Warning Flasher: Most FWL-Cars doesn't have the Option of a Warning Flasher, none my Car when I got it. For personal and emergency reasons this was a must and added this Feature. Four-Way means that the Flashing Signal goes in four Directions (please correct me if not): 1. to the Front Left Directional Light, 2. To the Front Right Directional Light, 3. To the Rear Left Directional (*and / or Brake) Light, 4. To the Rear Right Directional ("and / or Brake) Light. Thus, the Flasher has to provide four separate Current Lines. There will be one Input and four Outputs Connections. (* this depends if Brake Bulb is combined with Directional Signal) The same Function I realized it simpler by using a One-Way Flasher Unit and four Diodes, as connected according the hand-drafted Diagram. The Input has to come directly from the Battery +12V to assure an operation in any circumstances. The Single (switched) Output of the Unit goes to the four (twisted) Diodes. The Outputs of the Diodes are then wired to the four Directions, as described. All these 5 needed Wires are easy to found under the Dashboard - no extra long wires required! Check with an Instrument by Switching on and off the Functions (Brakes, Directional Light) and be sure you take the wires leading directly to the corresponding Bulb. The Flasher Unit should have a good visible Control-Lamp. Best I found was a Unit, mounted under the Dashboard, needind a single Hole 1/2" for mount, and pull-out for ON. The used Diodes 1N5401 (100V/3A or higher Values), Standard Types available in any (?) electronic Shop (about USD1.00). To the "Make-Up" or better to the Show-Effect: The Red Knob is the Flasher, the Silver Knob left-hand the Clock-Adjustment, and next you see the Switch S. This Swicht by-passes the Flashing (not the Diodes!!!), all Lamps around are continuous ON for "Show-Time" at evening, at Night or for Night-Pictures -Happy flashing with the Camera. (The Headlamps have to be swichted ON separately, the last Switch L add the two other Headlamps). Edited by sermey 2009-01-01 2:55 PM (DSC02279L Flasher Switch OFF.jpg) (DSC02284L Flasher Switch ON.jpg) (DSC02285L Diagram.jpg) (DSC02288L Diodes 1N5401.jpg) Attachments ---------------- DSC02279L Flasher Switch OFF.jpg (41KB - 803 downloads) DSC02284L Flasher Switch ON.jpg (42KB - 850 downloads) DSC02285L Diagram.jpg (60KB - 821 downloads) DSC02288L Diodes 1N5401.jpg (32KB - 828 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Fuel Temp Gauge: I was always used to know how many km the car will run when the Empty Fuel Alert Light went on. This I missed on my Dodge. When restoring the Instruments I added a bright Yellow LED. In the Fuel Tank I had to add an adjustable Switch and a separate wire leading to this LED. In the restoring Process this was not a big work. First I wanted design a Trigger-Circuit (2 - 3 Transistors) switching on the LED at an calibrated Resistor / Voltage Value on the existing line to the Fuel Instrument. Thinking this value could vary due to instable Main-Voltage (the internal regulator works imprecisely) I decided to go the "traditional" way. When OFF the LED is not visible. Now, the LED goes on always exactly at the same Fuel Level - in this regard happy driving and no Stress anymore! Edited by sermey 2009-01-01 5:00 PM (DSC02305L Fuel Temp Gauge.jpg) (DSC02306L Empty LED ON.jpg) Attachments ---------------- DSC02305L Fuel Temp Gauge.jpg (126KB - 844 downloads) DSC02306L Empty LED ON.jpg (83KB - 850 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13054 Location: Southern Sweden - Sturkö island | Thank you very much for your information about the 4-way flasher Serge! I have been looking after an old system for to add on my car, but with your diagram and notes it will be easy to build one. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | wizard - 2009-01-01 11:33 PM Thank you very much for your information about the 4-way flasher Serge! I have been looking after an old system for to add on my car, but with your diagram and notes it will be easy to build one. I am glad that you Swen, as one of the many highly experienced FW Lookers on this site found something useful, as I wished for all old US-Car Owners. I know, not anythig in this Thread fits the taste of the Readers, but "There's no accounting for Taste". Many issues have already been discussed somewhere, I cannot know, others are still open. Thus, go on (and all other Car-Friends) keeping inspired by reading these and next next issues to come. - SERGE - | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Head Lamp Flash: I also was used to have the Head Lamp Flash Feature, especially as alert to others in critical situations, mostly on the Highwayss. Fortunately I had already a Micro-Switch Unit I purchased "with great foresight" in double many Years ago for another US-Car. It needs one additional wire leading through the Steering Wheel Unit to a separate mounted Relais. As the Four-Way Warning Flasher this Option works at any time, by-passing all the Head Lamp Circuits. At ON all four Head Lamps (both Bulb Wires!) work together to get the maximum bright Alert Light. It is not recommended to let them ON for longer time, the bulbs may got hot and damaged. Sometimes on the way just say "Hello" and flash the Head Lamps. (DSC02307L Original Directional Lever.jpg) (DSC02310L Switch Unit Headlamp Flash.jpg) (DSC00010L Head Lamp Flash ON.jpg) (DSC00038L Head Lamp Flash ON.jpg) Attachments ---------------- DSC02307L Original Directional Lever.jpg (26KB - 854 downloads) DSC02310L Switch Unit Headlamp Flash.jpg (71KB - 812 downloads) DSC00010L Head Lamp Flash ON.jpg (58KB - 822 downloads) DSC00038L Head Lamp Flash ON.jpg (82KB - 852 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Radio: To repair a Radio is not easy when you are not familiar with nor have equipped for. Fortunately I have some Tools. What you can do: clean the Contacts and the Potentiometer using a Contact-Spray. I have soldered a shielded Cable with Cinch Connector between the Max and the Ground ot the Volume Control, in Serie with a Resistor of 100k. This is an AUX-Input (also Output without 100k) for external Audio-Devices. Can use an (portable) FM-Radio and connect it there. However the Sound Quality will not be much better due to the poor Output-Stage of the Radio. The Loudspeaker was replaced by a better Quality one. The mounts fits but a corner of the Magnet must be removed or will touch the Dashboard. As printable PDF-File post-attached the Technical Instructions with Schematic Diagramm: MOPAR Radio 856/857, 6 Pages in 3 Steps (cannot Download 500kB). Edited by sermey 2009-01-03 5:24 AM (DSC00051 MOPAR Radio.jpg) (DSC00123L Radio Top View.jpg) (DSC00122L Radio Bottom View.jpg) (1959 MOPAR Radio 856-857.jpg) Attachments ---------------- DSC00051 MOPAR Radio.jpg (82KB - 882 downloads) DSC00123L Radio Top View.jpg (93KB - 830 downloads) DSC00122L Radio Bottom View.jpg (99KB - 824 downloads) 1959 MOPAR Radio 856-857.jpg (142KB - 943 downloads) 1959 MOPAR Radio 856-857 1-2.pdf (175KB - 1034 downloads) 1959 MOPAR Radio 856-857 3-4.pdf (186KB - 926 downloads) 1959 MOPAR Radio 856-857 5-6.pdf (153KB - 890 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Curved Windshield: I was already asked if I have a Curved Windshield. Yes, I had it, but mat as sandblasted. I coudn't find anywhere a Curved one and had to take what was available. Finally I learned to like the new straight Windshield beeng more slanted. In a certain angle from side view you even can't see if it is curved or not. In my Fantasy I have modified my Windshield to various Stretched Curved Models - the last Version 7 (Double Stretched) I feel exciting! Looking at, then back to the Original, the actual one seems to be very "old-fashioned". Just to remember: it's an Oldtimer! In the Collection I left the entire Car Size to get an integrate Impression. 1. My Car today, 2. Original Curved, 3. Stretched, 4. Streched Curved, 5. More Stretched, 6. More Stretched Curved, 7. Double Stretched Curved (and additional Zoomed). Edited by sermey 2009-01-03 2:44 AM (Ross Roy-Curved Windshield.jpg) (Original Curved Windshield 1.jpg) (Original Curved Windshield 2.jpg) (Various Stretched Windshields.jpg) (Double Stretched Windshield Zoomed.jpg) Attachments ---------------- Ross Roy-Curved Windshield.jpg (70KB - 814 downloads) Original Curved Windshield 1.jpg (58KB - 867 downloads) Original Curved Windshield 2.jpg (99KB - 829 downloads) Various Stretched Windshields.jpg (190KB - 846 downloads) Double Stretched Windshield Zoomed.jpg (79KB - 925 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Seat Ash Tray: As already apllied on the Door Handles and the Rear Lamps, the Golden Sticker on the Seat Ash Tray has its own optical Effect - a (Custom) Royal feeling for Smokers sitting behind. An Interior matched Color would be nice too. Edited by sermey 2009-01-03 8:12 AM (DSC00010L Seat Ash Tray.jpg) Attachments ---------------- DSC00010L Seat Ash Tray.jpg (75KB - 854 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Bumper Bolts: Shiny polished Bumper Bolts underlines a nice restoration. In the Sun or at Spotlight they may shine as small Brillants around the car. Some are less visible, other more. There are different Types, the mostly used hardened Steel with a stainless Cover, then the rechromed and the all stainless / rustfree ones to be handeled and polished as the other Screws. For the main Front and Rear Bumpers I used the "covered" ones, on the sides and up-side the smaller rechromed ones I had already. Do not tighten to hard as I did: somewhere the Chrome of the Bumper started to brake around the Head, the Support-Arm being not exactly parallel with the Bumper. Should put a Nylon Washer for compensation. I like the last picture and post it at higher Quality. Edited by sermey 2009-01-03 9:10 AM (DSC02324L Bumper Bolts.jpg) (DSC02321L Front Bumper Bolts.jpg) (DSC02323.L Side Bumper Bolt.jpg) (DSC00006L Rear Bumper Support.jpg) Attachments ---------------- DSC02324L Bumper Bolts.jpg (71KB - 854 downloads) DSC02321L Front Bumper Bolts.jpg (56KB - 860 downloads) DSC02323.L Side Bumper Bolt.jpg (74KB - 861 downloads) DSC00006L Rear Bumper Support.jpg (140KB - 849 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Front Directional Parking Lamps: All the Insiders will have noticed that the Directional Lamps on my 1959 Dodge are not Original. The Lenses were partly broken, the Chrome-Plating on them washed-out and the Bulb Sockets corroded. (DSC00040L Old Original Lense.jpg) (DSC02315L External Directional Lamps.jpg) (DSC02317L Silicon Cement Pot.jpg) (DSC02326L Items Overview.jpg) (DSC02329L Interior Lamp.jpg) (DSC00088L New Directional Lamp.jpg) Attachments ---------------- DSC00040L Old Original Lense.jpg (82KB - 870 downloads) DSC02315L External Directional Lamps.jpg (51KB - 874 downloads) DSC02317L Silicon Cement Pot.jpg (79KB - 834 downloads) DSC02326L Items Overview.jpg (75KB - 876 downloads) DSC02329L Interior Lamp.jpg (95KB - 846 downloads) DSC00088L New Directional Lamp.jpg (113KB - 880 downloads) | ||
Rebels-59 |
Board Moderator & Exner Expert 10K+ Location: .Norfolk..Mafia.. ,England UK | I have seen the front of your 59 many times on here and NEVER noticed your Front Directional Parking Lamps where altered, They L@@K very nice,, Keep this thread going, i enjoy reading what you have done, and a few things i may also do to my 59 Coronet.. I,m not too keen on Your Finger Nail Colour Though..........LOL P.S.. I bought a Pair of NOS Non Genuine lenses a couple years back on US Ebay for $15, They are very close to the Original, Although i have,nt fitted them as mine are good, But the seller listed them as 1958, So no one Bid,, His mistake but my Gain........ Edited by Rebels-59 Coronet 2009-01-03 3:42 PM | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Rebels-59 Coronet - 2009-01-03 9:39 PM I have seen the front of your 59 many times on here and NEVER noticed your Front Directional Parking Lamps where altered, They L@@K very nice,, Keep this thread going, i enjoy reading what you have done, and a few things i may also do to my 59 Coronet.. I,m not too keen on Your Finger Nail Colour Though..........LOL P.S.. I bought a Pair of NOS Non Genuine lenses a couple years back on US Ebay for $15, They are very close to the Original, Although i have,nt fitted them as mine are good, But the seller listed them as 1958, So no one Bid,, His mistake but my Gain........ Your remarkable Comment as a 59 Coronet Owner confirms how authentic this Parking Lamp looks. One reason more to copy this in the case of a trouble with the Lenses. These Finger Nails belong to my Stepdaughter (15), I needed a third hand for show the matching Diameter in taking the picture. Not easy, because I have to take care not beeing mirrored in this shiny Chrome. Next time she must change to another Color! | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | I wrote: "Dual Antenna Gaskets: With my Car I got a complete Set of Rubber Parts. Most of them I could not use, the Gaskets for the Dual Antennas being too big." I just found these new, never used Antenna Gaskets. Now I wanted check if I am not too pedantic, taking a non restored original Antenna Socket as reference. The front Point is adjusted to fit correctly. The rear is about 3mm too long. Judge yourself! In Comparison my Gaskets are "Rolex" for nearly free. Edited by sermey 2009-01-04 1:29 AM (DSC02334L Rear Antenna Rubber1.jpg) (DSC02334L Rear Antenna Rubber2.jpg) Attachments ---------------- DSC02334L Rear Antenna Rubber1.jpg (60KB - 794 downloads) DSC02334L Rear Antenna Rubber2.jpg (56KB - 740 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Rear Lamp Gaskets: No comments to the old / original Gasket. I found High Precision Hydraulic Rings, self-centering inside, outside not overlapping at all, and they fit as tailored. The black Height of 1/4" is a nice separation between the White Body and the Rechromed Housing. Another inconspicious "Make-Up". Edited by sermey 2009-01-03 7:21 PM (DSC02339L Old-New Rear Lamp Gaskets.jpg) (DSC02342L New Rear Lamp Gasket Zoomed.jpg) (DSC00091L New Rear Lamp Gasket.jpg) (DSC00090L Left Rear Lamps Housings.jpg) (DSC00008L Rear Lamp Gaskets.jpg) Attachments ---------------- DSC02339L Old-New Rear Lamp Gaskets.jpg (36KB - 758 downloads) DSC02342L New Rear Lamp Gasket Zoomed.jpg (47KB - 716 downloads) DSC00091L New Rear Lamp Gasket.jpg (42KB - 749 downloads) DSC00090L Left Rear Lamps Housings.jpg (82KB - 758 downloads) DSC00008L Rear Lamp Gaskets.jpg (91KB - 738 downloads) | ||
wbower3 |
Walter passed away on Jul 29, 2014. We will miss you, Walt! Posts: 5358 Location: Heaven Above (Formerly Oklahoma City,OK) | Sermy, I agree with Clive, KEEP this thread going!!! Walt | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Power Window Switches: These items are very hard to find. And when you have or found them, some Main-Connectors may be missing, often very corroded, bad for a good electrical Contact needed for proper Window lift. Thus, I modificated the single Pin Connectors, also in order to match to the dicker wire in Double Diameter. There are many Single Pin Connectors available in Size and in Shape. Round Connectors offer a better electrical Contact due to the bigger surface around the Pin. Here I used the biggest Round one (Yellow). Bonding to the wire it needs a special Handtool, or best is to solder them for best Tensile Strength, especially whe a high flexible Wire is used. Then I cut the Front of the single Male Contacts and soldered them on each Pin of the Power Switch (see picture). Now the Power Window Cables can directly be connected to and removed from the Power Window Switch as any other Cable. The missing or corroded Main Socket is not needed anymore. These Single Cable are of course as before accessible outside the Door Panel, when removing the Switch. Recommended to label the Cables, the + Battery Line always to be Red. This "soldered" Pin Contacting can be used as well on the Instruments Panel. Edited by sermey 2009-01-04 5:12 PM (DSC02361L Power Window Switch Connector.jpg) (DSC02358L Round Pin Connectors.jpg) (DSC02359L Cut Male Connector.jpg) (DSC02365L Soldered Pin & Wire Connected.jpg) Attachments ---------------- DSC02361L Power Window Switch Connector.jpg (70KB - 766 downloads) DSC02358L Round Pin Connectors.jpg (55KB - 728 downloads) DSC02359L Cut Male Connector.jpg (26KB - 771 downloads) DSC02365L Soldered Pin & Wire Connected.jpg (50KB - 740 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Fuel Pump: Many of you may have encountered the same Situation. You are attending a Car Show, enjoy a nice Day, and are even Candidate for an Award. Later Afternoon you go sitting in your Car, to drive it in to the Ramp or for go Home – many people around watching you and waiting to see the Car drive away. A first attempt to start the car, a second time, a third time again, sometimes until one Minute till running – what a Disgrace in this admired Car! Firstly I decided to put a Replacement Electric Fuel Pump. Later I thought, one Electric Element more in the Pump risking to fail one day, and remembering my aim to restore at anytime to its Original when I should like. I searched for another Solution: I added a second (electric) Fuel Pump to the already existing (mechanic) Original one in parallel. It is a Round Type with axial Ports, Inlet down-side, Outlet up-side, mounted by a Hose Bracket to the lower Generators Arm. The two Inlets using a Branch Connector (Y) lead to the Fuel Tank Line. Each of the other two Outlets are provided with an one-way Valve before joining together by using another Branch Connector (Y), according the Picture “Fuel Flow Diagram”. The closest +12V ignition-switched Electric Power is diverged from the near Wire leading to the Electric Choke, the Ground (-) to the Bracket Screw. The Picture's View is Down-Up, the second Pump is hardly visible from Top. To know: As a matter of physical principle, at running engine only one Fuel Pump delivers Fuel to the Carburetor. It's the one generating the higher Pressure, forcing the other Valve to close and avoiding the Fuel to backflow. When one Pump is failing, the other Pump will take over at any instance. First switch ON the Ignition, listen to the hardly audible buzz of the running Electric Fuel Pump. When the Sound lowers in Frequency means the Carburetor is adequately supplied with Fuel and the Engine ready to start. Can see when the Glass Fuel Filter has no Air anymore. Then go on by switching to the Starter Position. Now, the Car starts immediately at any circumstances. Furthermore, the already activated and thus pre-heated Electric Choke turns the Engine earlier to the lower Idle Speed. Just start and drive away – and happy End of the Car Shows to come! Edited by sermey 2009-01-05 10:44 AM (DSC02376L Replacement Electric Fuel Pump.jpg) (DSC02375L Fuel Flow Diagram.jpg) (DSC02372L Dual Fuel Pumps.jpg) Attachments ---------------- DSC02376L Replacement Electric Fuel Pump.jpg (56KB - 778 downloads) DSC02375L Fuel Flow Diagram.jpg (48KB - 745 downloads) DSC02372L Dual Fuel Pumps.jpg (78KB - 772 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Power Windows Lift: This Option I won’t miss on a Convertible, when driving from a Land-Street to the Highway, being exposed all around the Head to heavy wind. At open Top all Windows up reduces the Inside Wind and the arising Noise considerably. On the other side they are a Show Element for Cars at this time. At Oldtimer Shows you can see many badly aligned and particularly “tired” Power Windows, as very old walking people. The rear Windows are more affected than the Front ones. This difference is mainly due to the longer electrical Wires needed, but also to the Rubber Channel’s Friction they have to overcome, notably the 1957 – 59 ForwardLook Car Versions Convertible and 2-Doors. My ambition was to achieve a Down-Up Time of less than 5 Seconds, and a Window not vibrating in any Position. After some technical Investigation I came to the Conclusion, that the Original Window Motor, being powered at the lower Limit, could just not meet my demands. I found others, bigger ones, I had to adapt them mechanically. Then I restored the small Window Rollers and all Window Channels. The Window Channels I squeezed in Height and Width in order to get a clearance of about 1mm to the Rollers. This required a precise alignment to the Doors (Front) and the Body (Rear), so as the Windows could be moved easily by Hand up and down, before installing the Motors. The Channels and Rollers I lubricated with Silicon Grease. The wires I changed to double Diameter and adapted the Pin Connections to the Power Window Switches as already posted earlier, all this for a minimum Voltage Loss due to the Higher Currents. The Main Power Supply I attached at the Convertible Top Switch Unit, after the Thermostatic Interruptor, but before the Top Switch, in order to disconnect the Circuit in Lock Situations or excessive Current drain. Now I could start the first Test: The Windows lifted up and Down like “young Dogs”, achieving my stated goal, but . . . . At the lower and upper End, as the Windows are forced to stop by the Stoppers at full Electric Power, the Motor Gear spun risking to damage the Pinion. Fortunately I found the sole correct Solution: at each End, up and down, I mounted a High Current Micro Switch (25A) with a long Lever (Picture from Internet). Instead to adjust the mechanical Stoppers for End Positions, I have accordingly only to bend the Levers of the Micro Switches to stop correctly. Now: - Fine Adjustment and precice Position of the Window at “open” and “closed”. - No excessive Current at Stop, saving the Switch Contacts - No needless mechanical Pression and thus Deformation in the End Positions. - No “stroke with a hammer” at End Stop, but smooth and soundless. - The maximum Down-Up Time is 4 Seconds. - No Time Difference on Rear Window Right, when operated with Main Driver Switch or local Switch (longest wire). But must admit that the Rear Windows upper Edge may injure the Rubber Channel when not aligned and lifting up, due to the Powerful Motor. Edge should be rounded. (Sorry that could not take Inside Pictures) Edited by sermey 2009-01-06 5:10 AM (Power Micro Switch L.jpg) (DSC02378L Windows Left Up.jpg) (DSC02381L Window up Rubber Parallelity.jpg) (DSC02383L Front Left Windows Alignment.jpg) (DSC02379L Rear Right Windows Alignment.jpg) Attachments ---------------- Power Micro Switch L.jpg (60KB - 781 downloads) DSC02378L Windows Left Up.jpg (75KB - 747 downloads) DSC02381L Window up Rubber Parallelity.jpg (70KB - 780 downloads) DSC02383L Front Left Windows Alignment.jpg (82KB - 752 downloads) DSC02379L Rear Right Windows Alignment.jpg (66KB - 746 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Horns: The rechromed Covers in Combination with the painted Body looks great, even at other Colors than Golden. This Improvement makes only sense when the Horns are mounted on the Top as shown. Otherwise they are not visible, and even may disturb the appearing of the Front Grill’s Profile when located behind. In that case the Horns are at best in Black. (DSC02386L Chrome Golden Horn.jpg) (DSC02391L Horn Positions.jpg) Attachments ---------------- DSC02386L Chrome Golden Horn.jpg (84KB - 768 downloads) DSC02391L Horn Positions.jpg (88KB - 750 downloads) | ||
wbower3 |
Walter passed away on Jul 29, 2014. We will miss you, Walt! Posts: 5358 Location: Heaven Above (Formerly Oklahoma City,OK) | Hi Serge. What kind of fuel pump relay did you install on the electric pump, and did you also install some sort of device to shut off power to the pump in event of collision or other accident? I like electric pumps but I'm concerned about accidents and fire and the electric pump continuing to run on ...... Walt | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | wbower3 - 2009-01-06 4:53 PM Hi Serge. What kind of fuel pump relay did you install on the electric pump, and did you also install some sort of device to shut off power to the pump in event of collision or other accident? I like electric pumps but I'm concerned about accidents and fire and the electric pump continuing to run on ...... Walt Walt, there is no relay nor a shut off switch. The electric pump will be off when the Ignition Switch is set to off. I don't know if a separate (automatic) shut-off is imperatively needed for the case of Collision. I was even not thinking at and never heard about this issue. It's a matter to give some thought to and start a discussion in another thread(?). Thank you for this indication. - SERGE - | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Spot Killer: You have certainly noticed the pure black Color on the Front Medaillon. This didn’t look always as nice, especially after a longer Trip. Color may be partly removed. This happens as well to other painted items of the Car. To remove this Spots “on the Road” just use a standard water-proof Felt Marker. They are available in various Colors and Sizes. If the Color doesn’t match, use the one with the darker note, will be less visible than the brighter one. Always best matched Color: Black is black! This Correction can be useful for the Exterior as for the Interior. It’s a fast way, dries instantly and doesn’t dish up. Thus, keep your Felt Marker always ready in the Car. This is verbally an “applied Make-Up”. (DSC00053L Never Spots Killed.jpg) (DSC00022L Spot Killer.jpg) (DSC02419L Water-Proof Felt Markers.jpg) Attachments ---------------- DSC00053L Never Spots Killed.jpg (43KB - 734 downloads) DSC00022L Spot Killer.jpg (64KB - 720 downloads) DSC02419L Water-Proof Felt Markers.jpg (40KB - 742 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Power Windows Micro Switch: I have found the (broken) Test Switch (25A) and post some Pictures on special Request. The Switch is mounted at the same side as the Window Channels with two Scews, on the left or on the right side, according the Windows side. The Lever is optional (the two small mounting Screws are missing in the Pics). I have added a Side Arm for the Windows Pressing. The Interruption happens within the flexible Range of the Lever, no mechanical Forces on the Switch at all, a smooth Transition. The lower existing original Positioner is to be adjusted just to touch the Windows Edge when stopped. Let there the damping Rubber anyway. The wires are connected at the Switches sides and fixed with the Screw underneath, as well known from plug connectors. The bigger flexible Wire as showed in "Power Window Switches" is correct for these Holes (tin the Ends).The yellow Meter simulates the Windows Edge, activating the Switch when lifting downwards. By bending the Lever (or moving the Switch) the Stop Position is fine-adjustable. There are two Micro Switches per Window, one for the DOWN and the other for the UP Stop. A simple and reliable Installation, and it works excellent. Good Luck. Edited by sermey 2009-01-06 11:24 PM (DSC02424l Micro Switch No Lever.jpg) (DSC02422L Micro Switch Levers.jpg) (DSC02423L Switch Side View.jpg) (DSC02425L Wire Connections.jpg) (DSC02426L Downward Switching .jpg) (DSC02430L Micro Switch Label.jpg) Attachments ---------------- DSC02424l Micro Switch No Lever.jpg (63KB - 714 downloads) DSC02422L Micro Switch Levers.jpg (68KB - 702 downloads) DSC02423L Switch Side View.jpg (48KB - 696 downloads) DSC02425L Wire Connections.jpg (63KB - 699 downloads) DSC02426L Downward Switching .jpg (35KB - 732 downloads) DSC02430L Micro Switch Label.jpg (47KB - 704 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Paint for Horns and Air Cleaner: On special Request. Golden: KRYLON Brass Metallic 2204 (is brighter than the Gold Metallic 1706) Transparent: KRYLON Clear Varnish Coating 7001 To know: The first sprayed brillant Gold will be affected by the transparent Coating. A among many Tests the best Result got with 7001, the 2204 dried out. If not transparent coated the Metallic Surface Brillancy diminishes, even may disappear when cleaning or touching. This second Layer apply at least two times, later it can be polished when get mat.
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Power Lock: This is another Feature, as the Power Window Lifts, I won’t miss in my ’59 Dodge. There are various Kits available with all needed items, including the wiring Harness. I saw even Kits including a Remote Control. What you see is a four Door Kit. The Single Units are mounted inside the Door, under the Door Lock, very easy to install. The only Handicap when there is no wiring at all to the Doors. A high flexible, floating Connection.near the lower Door Hinge helps. Thinking ahead I had already provided many supplement Cables when wiring the Power Window Lifts (for Loudspeakers, Power Lock and various Control / Switch Units when required). This Power Lock Option is not visible at all and doesn’t need any exterior Switch. All Doors unlock when the Car is being opened by the Key from Outside, or by the Inside Door Handle (Up). They lock when closing correspondingly. Thus, the Power Locks can be activated from outside at open Windows too by moving the Inside Door Handles up or down. To Know: In this Configuration all Doors have the same State, closed or opened. When disconnecting the Battery and then reconnect, for security reasons, all Locks are turned to the Closed State. Now, not a visible Improvement, but no Problems anymore with a closed Door on the other Side. And it works! (Sorry here again, could not take Pictures from inside) Edited by sermey 2009-01-07 11:27 AM (Power Lock Kit .jpg) Attachments ---------------- Power Lock Kit .jpg (84KB - 696 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Air Filter: Here the same Color Combination as the Horns. The rechromed Center would fit very well to any other Color. (DSC00070L Chrome Golden Air Filter.jpg) Attachments ---------------- DSC00070L Chrome Golden Air Filter.jpg (118KB - 695 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Emblem Studs: In Pot Metal they are damageable when mounting the Emblem using the Self Tapping Nuts another time..And what a Frustration when a Stud go broken! To prevent this I tapped Screw Threadings on any Emblem. Further more it's a smoother feeling to tighten softly. Sample shown on the Chevron Emblem. To know: Side Emblems are mostly in Duals as LH and RH. Some of them can be mounted at any Side, when drilling additional Holes. Finding later a NOS Rechromed Chevron, I drilled the additional Holes. Now there are to LH Emblems, not visible at all. Applying this way all 1959 Rear Lamps are interchangeable as well. Edited by sermey 2009-01-08 5:56 PM (DSC02482L Cut Thread.jpg) (DSC02477L LH - LR.jpg) (DSC02475L Symmetric Holes.jpg) (DSC02470L Mounts Chevron Emblem.jpg) (DSC00115L Chevron Emblem.jpg) Attachments ---------------- DSC02482L Cut Thread.jpg (71KB - 700 downloads) DSC02477L LH - LR.jpg (75KB - 672 downloads) DSC02475L Symmetric Holes.jpg (17KB - 699 downloads) DSC02470L Mounts Chevron Emblem.jpg (73KB - 694 downloads) DSC00115L Chevron Emblem.jpg (66KB - 657 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Moulding Clips: As the self-tapping Screws, these items had been designed for a fast Manufacturing, and are not suitable for an outstanding Car. They damage the Paint (as the self tapping Screws), go rusty and don’t tighten the Moulding sufficiently (rattling). The rust is programmed, the Mouldings are loosely and thus not close to the Body. And there should be no Gap at all! I found stainless / rustfree and springy Clips in various Sizes being used to fix Aluminium Covering Profiles. Adding a Screw, attached by soldering (tin), this was the ideal Solution. Now, these are not Clips anymore, but rather Clamps. Inside comes first the Grommet for sealing, then the Washer, and finally the Wing Screw, as well known from the Dual Rear Antenna, for easy fixing by Hand without any Tool. Of course all in stainless / rustfree Metal. By cutting the Sides, they can be fitted to match the Width of any Moulding in the Range, even when the Clips are asymmetric, see “Replacement Sample”. For the Wide Door Mouldings I used two opposed Clips, every 3”, enabling to mount the Moulding from Outside: Down hook in -> push up, and then Up hook in -> push down = Fixed, and adjustable Left < > Right, as Up < > Down due to the Spring Property. They can perfectly be aligned each to other and at any time (see earlier Pictures of the Car) This new Clip is to be tightened till to the Body in benefit to its curved shape and springy Attribute. No loosy Mouldings anymore, no Gaps at all, and last but not least: A very pleasant Assembling. Edited by sermey 2009-01-08 5:53 PM (DSC02439L Various Rusty Clips.jpg) (DSC02444L Clips for Alu-Profile.jpg) (DSC02445L Clips Assembly.jpg) (DSC02450L Soldered Bolts-Various Sizes.jpg) (DSC02488L Application.jpg) (DSC02489L Replacement Sample.jpg) (DSC02505L Gap Rear Fins.jpg) (Riveting Double Clips L.jpg) (DSC02510L Gap Door Moulding.jpg) Attachments ---------------- DSC02439L Various Rusty Clips.jpg (74KB - 675 downloads) DSC02444L Clips for Alu-Profile.jpg (43KB - 675 downloads) DSC02445L Clips Assembly.jpg (52KB - 685 downloads) DSC02450L Soldered Bolts-Various Sizes.jpg (57KB - 678 downloads) DSC02488L Application.jpg (50KB - 678 downloads) DSC02489L Replacement Sample.jpg (44KB - 662 downloads) DSC02505L Gap Rear Fins.jpg (46KB - 670 downloads) Riveting Double Clips L.jpg (30KB - 689 downloads) DSC02510L Gap Door Moulding.jpg (31KB - 667 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Paunched Sides: All Cars at this time had more or less paunched Sides, best visible from behind along the Car. The Side Mouldings then becomes curved too. A Correction by heating would make it even worse. I tried a mechanical Solution to reduce these Paunches. In about the Length of the Side Mouldings and under the same Position I mounted Inside a strong Steel U-Profile (W25-H12-D4.5mm). This Dimensions fitted just well behind the Rear Wheelhouse. As expected I didn’t got a straight Line, the max. Curve Retraction was about ¾ “. The Body has become very stiff and highly resistant to Stress. Paunch reduced - but Weight increased! This is not a Make-Up, rather a Cosmetic Surgery. Edited by sermey 2009-01-09 5:27 AM (DSC02459L Profile View Inside Rear Quarter.jpg) (DSC00221L Rear Side View.jpg) Attachments ---------------- DSC02459L Profile View Inside Rear Quarter.jpg (87KB - 733 downloads) DSC00221L Rear Side View.jpg (70KB - 661 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Dome Light: A visual Gadget is the “Longer Light” Feature. A two Port Electric Box is connected directly to the Dome Light Switch and to Ground, being hidden behind the lower inside Panel, near the Loudspeaker (Pic). For easy Connection remove the Switch and pull the Wires through. To know: This item can as well be connected directly to the Dome Light and the Box hidden behind the Side Panel (Convertible). Attention: Attach to the floating Ground Wire of the Lamp (has 0V when the Lamp is ON) and not to the +12V!!! Now, closing the Doors the Dome Lights fade out after about 30 Seconds. Edited by sermey 2009-01-09 8:18 AM (DSC02514L Dome Light Switch.jpg) (DSC02515L Dome Light Fading Out.jpg) Attachments ---------------- DSC02514L Dome Light Switch.jpg (132KB - 666 downloads) DSC02515L Dome Light Fading Out.jpg (46KB - 689 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Trunk Lid: The Problem of the “Half-masted Trunks..” (2006-10-16 /d500neil) has already been discussed. There I showed my Solution using two Gas-Springs, on the left and the right side, needing only two Holes to fix them. The Data and Dimensions are given there. I have already replaced them by the next stronger ones, when I covered the Trunk Lid with the same black Parket as for the Interior. Then the Trunk Lid became heavier, I had simply to replace the Gas-Springs by the next stronger ones. Just take out the Split Pin at the upper and at the lower End, then the Spring Unit can be removed and replaced by another one. This may be important when starting with too weak ones for an exchange where purchased! (the silver Screws fixing the Parket disappear when covered by black Plastic Caps, if prefered) Now, the Trunk Lid when DOWN remain slightly opened (Trunk Light OFF), or stands UP again as before and in younger Years! Edited by sermey 2009-01-10 5:06 AM (DSC02497L Gas-Springs Lenght 275.jpg) (DSC02516L Snap-On Gas-Spring.jpg) (DSC02495L Front View.jpg) (DSC02496L View Other Side.jpg) (DSC02522L Interior-Parket on Trunk Lid.jpg) Attachments ---------------- DSC02497L Gas-Springs Lenght 275.jpg (52KB - 659 downloads) DSC02516L Snap-On Gas-Spring.jpg (41KB - 652 downloads) DSC02495L Front View.jpg (45KB - 625 downloads) DSC02496L View Other Side.jpg (87KB - 661 downloads) DSC02522L Interior-Parket on Trunk Lid.jpg (82KB - 641 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Door Weather-Strips: This items on the Car are exposed and visible to anybody, often mounted inaccurately. This stands out on the spot when they are not inline to the opened Window. Usually they are clinched on the Door, not permitting any fine Alignment afterwards. This can be achieved by using Special Screws, flat as Rivets. I found black burned-in Low Profile Pan-Head Screws. Head Height 1.6mm (see on Pic the upper Screw), Diameter 7.8mm, Metric M4x10mm. The Diameter allows a mounting Hole in the Weather-Strips up to 5.5mm for an Alignment Range of over 2mm in any Direction, the low Height make it impossible to touch the Window, and the black Head disappears in the black Strip. Easiest is to use a Manual Hole Puncher for the Strips. First punch 4mm, then more Punches around in order to get the Hole bigger towards the best Position to the Door. Can have more Fixing Points as had before, but should cut at first all Threads in the Door. Now, as well simple and fast to replace them, this when the Strip is wrongly bent at the Ends or too much curved for straightening. (see Alignments of Door Weather-Strips above in Pics “Power Windows Lift”). Another visible Precision Work on your Car! Edited by sermey 2009-01-10 4:44 AM (DSC02531L Low Profile Pan-Head Screws.jpg) (DSC02532L Manual Hole Puncher.jpg) Attachments ---------------- DSC02531L Low Profile Pan-Head Screws.jpg (66KB - 683 downloads) DSC02532L Manual Hole Puncher.jpg (40KB - 608 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Slanted Rear Seats: As far I could see, all earlier Convertibles have steeper Rear Seats than the Front Seats. This is uncomfortable to sit and furthermore this looks not inviting. The Front Seats are already steeper then today Cars, the Angle to the sitting Surface cannot be adapted for best feeling, nor with the 6-Way Power Seats Option. With it the entire Seat is rotated front- or backwards. First I modified the Hinges of the Front Seat for a wider Sitting Angle. Then I moved the Cross Bar of the Rear Back Seat about 2” backward. In the Pics the fomer Original Position is still visible. In Consequence the Rear Seat Mount had moved up, the Bolt is now in an other Position and the Side Panels have been extended accordingly. The needed, interrelated Modifications at the Mechanics of the Convertible Top is reported later. (when you brighten the first Pic you will discover the Steel Profile and the Power Antenna Unit) Now, a Comfortable Sitting and more Space too for the Rear Passengers, furthermore nice Parallel Back Seats, as well known from 4-Door Cars. All around happy Passengers: Let's lean back and ride. Edited by sermey 2009-01-10 3:53 PM (DSC00058L Overview Behind Rear Back Seat.jpg) (DSC00058L Zoomed Moved Back Seat Cross Bar .jpg) (DSC00058L Zoomed Moved Back Seat Mount.jpg) (DSC00051L All Slanted Parallel Back Seats.jpg) Attachments ---------------- DSC00058L Overview Behind Rear Back Seat.jpg (100KB - 651 downloads) DSC00058L Zoomed Moved Back Seat Cross Bar .jpg (47KB - 675 downloads) DSC00058L Zoomed Moved Back Seat Mount.jpg (85KB - 667 downloads) DSC00051L All Slanted Parallel Back Seats.jpg (105KB - 630 downloads) | ||
Jump to page : < 1 2 3 4 5 6 ... > Now viewing page 1 [50 messages per page] |
