rubber driveshaft boot & clamps Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
REDRAM |
Veteran Posts: 166 Location: Massillon, Ohio USA | I know, I know I posted it in General discussion too, does anyone know where to get one for the 55-56 Dodge ball and trunion set up? Will any newer CV shaft boots work? Thanks. | ||
Shep |
Expert Posts: 3402 Location: Chestertown, NY ( near Lake George) | I used a universal outer cv boot kit for ft wheel drive cars, got it from a Carquest dealer, there are 2 sizes the small one worked perfect, 22.00. | ||
REDRAM |
Veteran Posts: 166 Location: Massillon, Ohio USA | Got the part #? I work for Advance, I might be able to order it in and get it back up to speed. Thanks. | ||
Shep |
Expert Posts: 3402 Location: Chestertown, NY ( near Lake George) | Long gone, but they only have 2 universal boot kits, large and small, you need the small one. | ||
wbower3 |
Walter passed away on Jul 29, 2014. We will miss you, Walt! Posts: 5358 Location: Heaven Above (Formerly Oklahoma City,OK) | Dorman Quickboot, part #314-531. Check with Andy Bernbaum for the rebuild kit for the ball and trunnions. He had 'em in stock last fall. See post in Gen, Discussion. Andy' srubber boots did not like being shoved through the outer-housing's small end. The Dorman boots take it a little better. If you do replace the trunnion shafts, read the proceedure in the shop manual. It says that the trunnion shaft must be balanced in the driveshaft within .006 on each end of the trunnion shaft to maintain balance of the d/shaft. I was able to remove and replace my trunnion shafts with a 12 ton jack in the press. It's awkward unless you have a helper holding up the "other end" of the d/shaft. Uncle Walt Edited by wbower3 2009-08-28 1:56 PM | ||
57plymouth |
Expert Posts: 3577 Location: Blythewood, SC | I used a two piece glue together universal CV boot. It's been on there a few years now with no issues. Go get the generic one from your local parts house. STAY AWAY FROM BERNBAUM! His rubber stuff is junk and he is a jerk to deal with. | ||
REDRAM |
Veteran Posts: 166 Location: Massillon, Ohio USA | wbower3 - 2009-08-28 1:53 PM Dorman Quickboot, part #314-531. Check with Andy Bernbaum for the rebuild kit for the ball and trunnions. He had 'em in stock last fall. See post in Gen, Discussion. Andy' srubber boots did not like being shoved through the outer-housing's small end. The Dorman boots take it a little better. If you do replace the trunnion shafts, read the proceedure in the shop manual. It says that the trunnion shaft must be balanced in the driveshaft within .006 on each end of the trunnion shaft to maintain balance of the d/shaft. I was able to remove and replace my trunnion shafts with a 12 ton jack in the press. It's awkward unless you have a helper holding up the "other end" of the d/shaft. Uncle Walt :laugh: Thanks...I'll run the part # through the criss-cross today at work and see if it's still available. As alway, thanks for the input. This site is the only one with Forward Look answers. | ||
REDRAM |
Veteran Posts: 166 Location: Massillon, Ohio USA | The part # is obsolete, I checked at Oreilly and at work(Advance)...not available. I did however find one for a 2001 Neon that looks like it'll work, almost all of the Dorman QuickBoots have been discontinued... $13 for it...now all I have to do is get to it! | ||
REDRAM |
Veteran Posts: 166 Location: Massillon, Ohio USA | Done...me & my 17yr old attacked it this motning...I did what you guys and the old Motors manual I have said and voila! she's done. | ||
imp610 |
Veteran Posts: 129 Location: Finland | REDRAM - 2009-08-29 12:04 PM The part # is obsolete, I checked at Oreilly and at work(Advance)...not available. I did however find one for a 2001 Neon that looks like it'll work, almost all of the Dorman QuickBoots have been discontinued... $13 for it...now all I have to do is get to it! Just out of curiosity, do you mean that for example Precision #7450 will fit?. Greetings from a fellow counterpro, from the other side of the globe... | ||
Expert 5K+ Posts: 8948 Location: WHEELING,WV.>>>HOME OF WWVA | this might help------ROCKAUTO.COM---------------------------------------------------------------------------------------------------later 2001 DODGE NEON 2.0L 1996cc 122cid L4 FI (C) : Drivetrain : CV Joint Boot Price Core Total RAYBESTOS Part # 8161002 {Professional Grade} Front; Outer; Universal Solid Boot $8.89 $0.00 $8.89 PRECISION Part # 7450 {CV Boot} Front; Outer $9.52 $0.00 $9.52 RAYBESTOS Part # 8168110 {Professional Grade} Front; Outer (Only 1 Remaining) $9.84 $0.00 $9.84 RAYBESTOS Part # 8168109 {Professional Grade} Front; Inner (Only 4 Remaining) $10.81 $0.00 $10.81 RAYBESTOS Part # 8161032 {Professional Grade} Front; Inner; Universal Solid Boot (Only 8 Remaining) $11.13 $0.00 $11.13 RAYBESTOS Part # 8161037 {Professional Grade #8161011, 8161026} Front; Outer; Universal Split Boot $13.72 $0.00 $13.72 DORMAN Part # 03680 {HELP! - Boxed; Solid (not split) design. Stretches to fit joints up to 3-5/8" in diameter. Kit includes boot, grease, two cLamps and instructions.} Front Outer; Uni-Fit $14.42 $0.00 $14.42 DORMAN Part # 614001 {OE Solutions} Front Outer; Uni-Fit $14.42 $0.00 $14.42 DORMAN Part # 614632 {OE Solutions #04437-20020, 04438-06020, 04438-12171, 04438-12172, 04438-16040, 04438-16060, 04438-16080, 04438-32070, 04438-35021, 191 498 203, 26015008, 26018333, 26018334, 321 498 203A, 39241-0B025, 39241-16R25, 39241-17R26, 39241-2B085, 39241-2B086, 39241-2B087, 39241-2B088, 39241-2B089, 39741-03P85, 39741-04F25, 39741-04F28, 4057 011, 4205 853, 4346 164, 4367 009, 4367 010, 44018-SR1-901, 44333-SB2-761, 44333-SB2-981, 44333-SD9-003, 44333-SF1-962, 44333-SK7-J13, 4641 038, 4641 039, 4641 164, 4762 701, 5212 858, 7701 201 452, 7844997, 7845015, 7845020, 7845031, 7845398, 7847525, 8-94313-105-0, 8350 0495, 96056783, F3XY 3A331-A, F4BZ 3A331-B, F4BZ 3A331-D, MB160657, MB176162, MB176163, MB297337, MB297338, MB526400, MB620302, MR222681, T134 8568} Front Outer; Quick-Boot $22.79 $0.00 $22.79 DORMAN Part # 614002 {OE Solutions} Front Inner; Uni-Fit $22.79 $0.00 $22.79 PRECISION Part # 7420 {CV Boot} Front; Inner | ||
REDRAM |
Veteran Posts: 166 Location: Massillon, Ohio USA | Mine was theDorman 03680. It showed it was discontinued but our local hub/warehouse store had it. I slid mine in from the backside of the housing without removing the pin, loaded it w/ grease, clamped it down and bingo - done. | ||
