55 Plymouth gas tank swap
Steppinout
Posted 2009-09-28 8:30 AM (#190452)
Subject: 55 Plymouth gas tank swap
5001002525
Has anyone ever swapped a different gas tank into a 55 Plymouth. My car has no tank and I was thinking of using a newer tank. Anyone who has had luck with something that fits without a lot of fabrication and money, your help is highly appreciated. I may be able to find a 55-56 tank but doubt it will be in very good shape unless I get lucky enough to find one that is still being used. Do all 55-56 mopars use the same tank? I was looking at a plastic tank from a Gran Cherokee and like the idea of the plastic tank but without a tank to compare to I have no idea if it will fit. Thanks for your help, John
big m
Posted 2009-09-28 8:17 PM (#190538 - in reply to #190452)
Subject: Re: 55 Plymouth gas tank swap
50002000500100100100
'55-'56 Plymouth and Dodge have tanks that will interchange, although not the wagons.
I may have a serviceable tank here that is used.
---John
